Google music on Joggler
shadow_12
Post by shadow_12 »
A few months ago I tried to get my jogglers via squeezeplay and logitech media server to use the google music service. Although I managed to install it succesfully and it seemed to work the joggler failed to produce any sound when using the google music app. After a bit of trial and error I figured it out! So I posted the instructions here: http://neuronoscillation.blogspot.co.uk/ The post is quite rough so if you have any questions post them here or on the blog.
A big thanks to all the people providing the miriads of resources for the joggler. Especially BuZz and roobarb!
Re: Google music on Joggler
I tried installing this but it bails out with an error for ExtUtils::MakeMaker
Below is the log file from /home/joggler/.cpanm/work/1423225255.22118/build.log
Any ideas?
cpanm (App::cpanminus) 1.7024 on perl 5.014002 built for i686-linux-gnu-thread-multi-64int
Work directory is /home/joggler/.cpanm/work/1423225255.22118
You have /usr/bin/wget
You have /bin/tar: tar (GNU tar) 1.26
Copyright (C) 2011 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
You have /usr/bin/unzip
Searching App::cpanminus on cpanmetadb ...
--> Working on App::cpanminus
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/App-cpanminus-1.7024.tar.gz
-> OK
Unpacking App-cpanminus-1.7024.tar.gz
Entering App-cpanminus-1.7024
Checking configure dependencies from META.json
Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.57_05)
Configuring App-cpanminus-1.7024
Running Makefile.PL
Warning: prerequisite ExtUtils::MakeMaker 6.58 not found. We have 6.5705.
Checking if your kit is complete...
Looks good
Writing Makefile for App::cpanminus
Writing MYMETA.yml
-> OK
Checking dependencies from MYMETA.yml ...
Checking if you have Test::More 0 ... Yes (0.98)
Checking if you have ExtUtils::MakeMaker 6.58 ... No (6.57_05 < 6.58)
Checking if you have Module::Build 0.38 ... Yes (0.3800)
Checking if you have ExtUtils::Install 1.46 ... Yes (1.56)
==> Found dependencies: ExtUtils::MakeMaker
Searching ExtUtils::MakeMaker on cpanmetadb ...
--> Working on ExtUtils::MakeMaker
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/ExtUtils-MakeMaker-7.04.tar.gz
-> OK
Unpacking ExtUtils-MakeMaker-7.04.tar.gz
Entering ExtUtils-MakeMaker-7.04
Configuring ExtUtils-MakeMaker-7.04
Running Makefile.PL
Using included version of CPAN::Meta (2.120351) as it is newer than the installed version (2.110440).
Using included version of Parse::CPAN::Meta (1.4405) as it is newer than the installed version (1.4401).
Using included version of CPAN::Meta::YAML (0.008) as it is newer than the installed version (0.003).
Using included version of ExtUtils::Manifest (1.65) as it is newer than the installed version (1.58).
Using included version of JSON::PP (2.27203) as it is newer than the installed version (2.27105).
Using included version of CPAN::Meta::Requirements (2.127) because it is not already installed.
Looks good
Generating a Unix-style Makefile
Writing Makefile for ExtUtils::MakeMaker
Writing MYMETA.yml and MYMETA.json
-> OK
Checking dependencies from MYMETA.json ...
Checking if you have Data::Dumper 0 ... Yes (2.130_02)
Checking if you have File::Spec 0.8 ... Yes (3.33)
Checking if you have Pod::Man 0 ... Yes (2.25)
Checking if you have File::Basename 0 ... Yes (2.82)
Checking if you have DirHandle 0 ... Yes (1.04)
Checking if you have Encode 0 ... Yes (2.42_01)
-> FAIL Can't configure the distribution. You probably need to have 'make'. See /home/joggler/.cpanm/work/1423225255.22118/build.log for details.
-> FAIL Installing the dependencies failed: Installed version (6.57_05) of ExtUtils::MakeMaker is not in range '6.58'
-> FAIL Bailing out the installation for App-cpanminus-1.7024.
Does anyone know if the Google Music plugin works with LMS running on the Joggler? Or should LMS be installed on a PC/Mac/NAS to get it working?
The Google music app is working well on the Android distro too
I don't know if I'll bother with trying to install this on LMS; I've downloaded BubbleUPnP on my phone and it allows me to stream Google Music to any (or all) of my Jogglers. If I stream to one of my Jogglers and the others are synced, it will play through all of them; I can't do that with Airplay.
