Music on usb stick
Music on usb stick
Okay - very basic.
Music is on usb stick - how do I access this. Is the usb drive automounted? If so, where is the mount point?
Re: Music on usb stick
Which OS are you using?
SQPos 1.9
I honestly can't remember if 1.09 had usbmount installed on it. If it did, it'll appear in /media/usb<some_number>, if it didn't:
sudo apt-get update && sudo apt-get install usbmount
JimbobVFR400
Post by JimbobVFR400 »
My 1.09 SqPOS installation certainly has the folder structure present so chances are good it did have usbmount included, unfortunately my 1.09 Joggler is buried in a false wall and already has all ports taken so I can't test it.
