Newly aquired Joggler has update problem
wudang
Post by wudang »
Just picked up a Joggler off Gumtree (note to self check next time if house is smoke free - I need Nicorette patches everytime after use)
It's running 6853 firmware (boots with OpenPeak splash ) but won't auto update to the latest firmware - seems to be a not unusual issue. I've installed P'N'P primararily to run SqueezePlayer but I know I'll be tempted to add more apps once I've got over my first problem.
Although SqueezePlay is showing as installed nothing has been added to the home screen. I reckon I should have sorted out the old firmware issue first but the link I've found to re-image is dead. Does anybody know where I can find a live link.
The dead link is; http://o2.openpeak.co.uk/firmware/app-o ... eimage.tgz
Thanks in advance.
Avman
Re: Newly aquired Joggler has update problem
Post by Avman »
hi,
did you get anywhere with this as I am having a similar pronlem.
J
BTW
Post by BTW »
Hi Guys,
all the links to app-o2flash-24514.8353-S2-f1-reimage.tgz seem to be dead now. It's not clear whether they have simply timed out or if there is some sort of copyright issue.
Can anyone help with with a link to app-o2flash-24514.8353-S2-f1-reimage.tgz (or a later version) ?
In the longer term I'd be happy to mirror the file if this helps others.
Solved:
Found a later version here:
BTW
It's likely that OpenPeak have just killed those versions off now - that later version is the only one I'm aware of that works these days.
