Need help with the fuse(s)
mrparp
Post by mrparp »
Hi, over voltaged one of my Jogglers (missus laptop plug fitted nice..doh).
Where exactly are the smd fuse(s) needing replaced?
There are a lot of smd capacitors and other components near the psu, most have no markings.
Anyone been thru this before and can describe the location or PCB labels nearby?
Ta
Chris
Re: Need help with the fuse(s)
I have replaced them on the O2 and the 7e. I don't remember now where I saw them on the O2. That said they were burnt and easy to find.
On the 7e its on the opposite side where the power wires are soldered to the motherboard.
Looking at one now; its got burn marks on it making it difficult to see. Looks like D21 and C and A on either side of it.
