tapatalk
Please post any ideas / changes / or help requests regarding the forum here. Announcements relating to improvements etc will also be posted here.
tapatalk
Can the forum be made compatible with tapatalk? http://www.tapatalk.com/
Re: tapatalk
I shall have a look
Re: tapatalk
BuZz wrote:I shall have a look
Did you think that this would be feasible?
dps5pt
Re: tapatalk
Post by dps5pt »
Resurrecting an old thread here, I'd also like the forum to work with tapatalk please.
Re: tapatalk
+1 for Tapatalk .
This would be great if possible , i know it works on the XBMC4XBOX forum
If it isn't too much work to set up for this site it would be a great addition IMHO ,
it would make it much easier to check the threads when out and about .
Re: tapatalk
@Buzz did you have a look at this, Buzz , if so what did you think of it ?
I had a little look on the tapatalk web site http://www.tapatalk.com/index.php and it looks like it would work for our forum which is phpBB as it is listed , also it seems that the basic option is FOC if i read correctly .
A possible downside would be the page views of the forum would not count whilst using it....
Re: tapatalk
I had a quick look. if it isn't closed source or obfuscated (so i can review it), and doesn't put adverts on the site I would be ok with it.
Re: tapatalk
Sounds promising BuZz, that would be great if you could.
Re: tapatalk
should be enabled now.
Re: tapatalk
Thanks BuZz you are a star ...writing this possible first tapatalk enabled post ...
dps5pt
tapatalk
Post by dps5pt »
Many thanks buZz! Made my day :-)
Re: tapatalk
Had never used it before, but it works really rather well. :)
dilfred
Re: tapatalk
Post by dilfred »
ooh, did not notice that this forum was now on tapatalk, shall add it tonight on my tablet.
Thanks guys
Re: tapatalk
@BuZz do you remember what you had to do to enable this? Another forum I use tapatalk has been requested but it has been said it is not possible as it requires "advanced hosting " and will cost about 70 pounds a year, is that correct?
Re: tapatalk
It involves some phpbb modifications. I can't help on a specific web host, but web hosting usually involves you being to able access / change files. A google search suggests to me that they are probably using some free phpbb/forum hosting, and the advanced hosting sounds like what most web hosts offer by default.
Re: tapatalk
Thanks BuZz just the info I needed
Sherlock71
Re: tapatalk
Post by Sherlock71 »
I've been using Tapatalk HD on iOS with this forum since joining a couple of years back...
Re: tapatalk
Weird graphics of the joggler on the front page icon for the forum happening here .
Anybody else seeing this , the joggler looks like it was edited with a Spectrum 8-)
