Is there a Spotify Remote App for the Native OS
verg0
Post by verg0 »
Hi, is there a Spotify Remote App for the Native OS on the joggler?
Re: Is there a Spotify Remote App for the Native OS
verg0 wrote:Hi, is there a Spotify Remote App for the Native OS on the joggler?
Not that I know of. If you're a subscriber you can use Spotify through SqueezePlay either with the official plugin or the third-party Squeezebox Server plugin from Triode (give it a Google).
roobarb! wrote:...If you're a subscriber you can use Spotify through SqueezePlay either with the official plugin or the third-party Squeezebox Server plugin from Triode (give it a Google).
The last time I tried the official plugin it wouldn't work for me. I've only had success with the (rather good) Triode Squeezebox Server one.
I connect through Squeezebox Server because there are so many great plugins compared to the squeezebox.com official ones. I couldn't do without "BBC iPlayer Extras" now.
