Breaking free from PC
zedthegreat
Post by zedthegreat »
Hello all
I have recently taken delivery of an O2 Joggler after reading what can be done with it and installing Squeezeplay OS. I have installed Squeezplay OS on an external USB drive, following the instructions on http://birdslikewires.co.uk/articles/squeezeplay-os . I also installed Logitech Media Server (LMS) on my PC as well as Triode Spotify and BBC apps. This is working well, however I am missing one piece of info which I am sure must be out there but I cannot find for the life of me – so please feel free to point me to any pre-written resource (I have searched).
In an ideal world I would be able to access Spotify without having my PC on. Is there a way to do this so that LMS is contained within either my Joggler or the USB stick, or an alternative? I will eventually buy a NAS drive also (not purchased as yet) so would want to be able to access the music that will be on that too. Beyond Spotify / NAS access any extra functionally is purely a bonus for me.
Any assistance in breaking free from having my PC on appreciated.
PS – I believe LMS can be installed on a NAS, but it may be many moons until the finances allow that purchase.
PPS – I am not massively technical so start easy, if you can help.
Re: Breaking free from PC
zed,
Welcome to the Joggler forum. This is the Joggler center of the universe; much information here. Enjoy your visit.
You can also install Logitech Media Server on the O2 Joggler per instructions here: http://birdslikewires.co.uk/articles/squeezeplay-os
Additional Features -
Settings > Advanced > Additional Features
-AirPlay
-Logitech Media Server
-Network Mount Point
-Secure Shell
I run LMS concurrent with my MythTV box. They work fine together. The NAS is a different box. They are though on 24/7 today.
Currently also remoting the SP player from the automation mothership which oversees a bunch of stuff in the house.
Sometimes though "she - AKA computer Mothership" has a mind of her own and makes the Joggler do stuff which causes a low WAF (wife acceptance factor).
If you have root access via PuTTY, then an alternative LMS install is:=
wget http://downloads.slimdevices.com/nightly/7.8/sc/9913704/logitechmediaserver_7.8.0~1391513846_all.deb
then
dpkg -i logitechmediaserver_7.8.0~1391513846_all.deb
This will install the latest nightly LMS build - it takes ages to install, so patience is required!
The latest LMS 7.8 builds are always at:
http://downloads.slimdevices.com/nightly/?ver=7.8
I've taken to using the nightly builds at the moment - they seem to do what I want them too (access music on my shared storage connected to my router).
Get another Joggler and use it just as a LMS server, connect this to your NAS via your network, or use a NAS on which you can install LMS and just use the Joggler for Squeezeplay.
Anyway, buy another Joggler (you know you want to) :lol:
atb
Ronnie.
zedthegreat
Thanks all, I can confirm that I have LMS now installed on my Joggler.
Pete - It was right beneath my nose!! I knew I had seen it somewhere.
So working to an extent with being able to stream BBC / TuneIn, but getting an error with Spotify....tonights games I think :)
Ronnie - you are a bad influence!
Thanks again
JimbobVFR400
Post by JimbobVFR400 »
Have you installed Triodes 3rd Party Spotify plugin? If you're using the Joggler as a player it will let you install the Official App but it won't actually work.
zedthegreat
Yeah I have the Triode Spotify app. It worked when I got home from work, but I have been playing with settings so have rebooted a few times, and occasionally received the same error. It has cleared after another reboot though, so I think it is working, just not 100%. If it only requires the occasional reboot then I am happy enough.
castalla wrote:If you have root access via PuTTY, then an alternative LMS install is:=
then
Thanks for this Castalla, simple instructions for numpties like me ( :ugeek: not )
atb.
Ronnie.
