Joggler Windows XP or other windows builds :)
bobzin
Post by bobzin »
Hi im new to this joggler thing im looking for a windows xp or some sort of windows os build so i can use some software to run in my car, iv spent hours looking for download links but all older posts links are dead and i would like to get xp to run om my joggler can some one pm me the links or the files thanks.
Re: Joggler Windows XP or other windows builds :)
I can't vouch because I've not tried it - but are the instructions and links on this forum post any good?
bobzin
Post by bobzin »
Hi thanks for the replie but i tried them links i can download the image in bits the 3 files then u go to unzip them they are corrupt, anyother ideas thanks.
bobzin,
Uploading to dropbox. It will be in a few 250Mb links. The image is called: joggler-xp-mevi-16.12.11.img
I only have 2Gb of space such that will remove the links probably in a few days. The following link will give me storage credit with dropbox if you register with them.
I will then start keeping files there for Joggler forum users.
https://db.tt/TmLX5jSB
Links:
1 - https://www.dropbox.com/s/tit3ugpmuroq4 ... 11.zip.001
2 - https://www.dropbox.com/s/kxfzt2v1ruw8b ... 11.zip.002
3 - https://www.dropbox.com/s/puao346vy0335 ... 11.zip.003
4 - https://www.dropbox.com/s/ogfs8yvehtxt2 ... 11.zip.004
5 - https://www.dropbox.com/s/mlo4jhpbjexzm ... 11.zip.005
jahonix
Post by jahonix »
Hi there,
could somebody please guide me to a place with the necessary WinXP files for the Jogglers. All links here or in the Wiki seem to be dead.
I could provide drop-off space if needed.
Just recently I learned about the Jogglers and while I have most of my 7 devices running SqueezePlay OS (Thanks a zillion for providing the image!) I'd like to use a couple with WinXP and test some stuff. Crestron X-Panel among others, which is the GUI to Crestron control programming. Should be fun!
Chris
Will repost xp images in drop box.
Yup here migrating over to mostly Linux based and OS running Jogglers. That said I do run Leviton / HAI Omnitouch wintel software just fine on a few of the Jogglers and Homeseer's HSTouch. BTW HS also runs on Linux these days and the HSTouch software runs on Linux, Android, Apple and Wintel.
The Joggler's on steroids (Openframe 1.0's on up) also have DECT chips and Zigbee energy chips in them. Here I installed a Broadcom Crystal HD card in the Openframe 2.0 devices for streaming live HD TV (1080).
fh_
Post by fh_ »
I recently got a joggler. A nice device. I would like to use XPSP3 on it. There is also a howto in the wiki.
Unfortunaltely all links for the files you need are dead. Also all links on the images in this forum I tested did not work anymore.
Can anyone help me?
Thank's
fh
