Android on Joggler
Android on Joggler
Hi, I'm new to all this so please excuse my ignorance. My son recently gave me a joggler and I've been looking how to install Android onto the internal memory. I found the reflash tool but I have no idea how I create the os in .img.gz format and how do i get the .img.gz.md5 file. If anyone can help with simple instruction or send the files I would be very grateful. Thank you in anticipation.
Re: Android on Joggler
This might help http://www.jogglerwiki.com/forum/viewtopic.php?t=504 although ive not tried this method myself .
Why not try writing Android to a USB stick first which will be easier , then if you like the results progress to internal , have a look here
http://www.jogglerwiki.com/forum/viewto ... ndroid+ics
If you post in the above thread it will keep everything together
Have fun and good luck
Gary
Gary
