Hi all!
Hopefully you can help me with this one - I'm having install issues with both Squeeze play and server via PnP. Everything else seems to load fine (iPlayer, Opera etc) but the installer seems to crash on the PnP webpage during install of Squeeze play.
It installs an icon on the joggler that does nothing at all, and refreshing the PnP page then shows it as installed. When I then try to install squeeze server nothing happens, the page hangs and nothing is installed.
As usual of course the only thing I actually wanted to use was squeezeplayer!!!
Cheers,
WW
Weird PnP install issue
Re: Weird PnP install issue
