DECT Openpeak Handset Manufacturing Tests Menu
Charged up a new Openpeak DECT handset yesterday and decided to give a try to getting to the Manufacturing Tests Menu.
Easy. This is the way I did it.
1 - Settings menu I went to Settings
2 - Settings to Firmware Version
3 - Press the "#" key
4 - Press the "*" key while still pressing the "#" key
5 - remove your finger from the "#" key while still pressing the "*" key
6 - press back to go back to the Main menu
7 - press settings and now you have a new menu called Manufacturing Tests
8 - Manufacturing Tests menu shows
- DECT Settings = =>
a - CURRENT Settings
1 - Shows Mode, and a bunch of status lines.
b - Set Mode for US, EU, Brazil, LATAM, RESET Test Mode
- Enter Burn Test
- Tone 1K -> SPK
- Tone 1K -> EAR
- Tone Stop
- Loopback (MIC->SPK)
- Loopback (MIC->EAR)
- Loopback (NONE)
- Reboot
- Power OFF
- LCD Test -> goes to just a white screen
- Reset UI
- Exit Test Mode
