Did I really brick my Joggler? Any help?
gforums
Post by gforums »
Hi there guys,
I'm sitting here in front of a joggler which I tried to upgrade yesterdays.
As booting from usb didn't seem to work, I applied PnP III direclty to the Joggler (using telnet), without deleting any old files from me before that.
I got some status messages that indicated that the space on the joggler was full and after that, I didn't get any Interface.
I tried many USB keys on this device now. While they are recognized by my other Jogglers, this one doesn't recognize them.
So either, the device will hang up with the o2 boot logo (when trying to get in the boot loader manually (like fs1:boot...) or after some seconds, I get a short flashing up screen and then it darkens again with no funcionality.
Any idea what I could try?
I thought pressing "ESC" while booting up and then manually typing "fs1:boot" could work...but it doesn't :-(
any help appreciated!
thanks,
Christian
gforums
Re: Did I really brick my Joggler? Any help?
Post by gforums »
another EFI chip solved it... :-)
So I could flash trough usb while the old efi chip is again booting correct from internal storage.
In the past I've had to use a variety of numbers with the fs... boot thing. I think bizarrely I needed to use fs6 once!
Edit: Ah, you got a solution as I posted!
:? BTW I hope you approve of PnP III!
gforums
Post by gforums »
it's all working now incl. pnp III :)
writing this from the joggler's opera.
thanks!
christian
