Squeezeplay - setting presets
In Settings, Advanced there are Beta Features which allows you to set up presets. This works on the Touch, but I can't get it to work on Squeezeplay.
Any insights, suggestions?
JimbobVFR400
Re: Squeezeplay - setting presets
Post by JimbobVFR400 »
Not sure, I've used favorites for a few different things but how would you select the preset on the touch that would be different from choosing a favorite?
It's a routine accessed via Settings, Advanced - Beta Features. It's there in Squeezeplay, too. You get a stream assigned to a number key. It's fiddly - first set IR Hold 6, then set Press to select, get stream on Now Playing, press and hold key 6, popup confirms preset is set, go back to IR Hold 6, change to Play on Press.
The Squeezeplay keyboard has 0-9 keys listed as Favourites, but I can't see how to set them.
Semi-solved as a kludge .... the trick is to add new key mappings in InputToActionMap.lua.
There's an example keymap in the file to use ! to set preset 1. Modify and add to increase the preset keys.
