SqueezePlay OS for Joggler
Locked
Finally got found to giving this a go on my Joggler with clapped-out internal memory. Installed on an 8Gb HP stick, used Ubuntu to expand partition via gparted and off I went with no problems.
I also installed Logitech Media Server via terminal via Putty on my PC - needed to add it to the depository list first though.
This has allowed me to switch my Jogglers around the house to get a PnP III one on the computer desk. I was running ICS on the knackered Joggler there but I actually prefer the simplicity and speed of my PnP III Jogglers for what I want them to do.
Many, many thanks for all your hard work on Squeezeplay!
BuZz wrote:roobbarb wasn't actually referring to the sudo but the lack of the command "install" - "Invalid operation mplayer-nogui" happens as roobarb said - if you forget to use "install" "remove" or one of the apt-get commands.
It was a copy and paste job from LMS, I did actually use the install command. The error I posted was the wrong one - it was actually "couldn't find package mplayer-nogui" the previous error I posted was from an accidental execution as I was fiddling around with install options.
Despite roobarb's insistence that 'sudo apt-get install mplayer' works... it doesn't. Not sure why.
what error do you get ? there is indeed no mplayer-nogui package in ubuntu - there is however an mplayer package and it should install ok.
shadow12
Post by shadow12 »
thanks a lot for your work, sqpOS is much faster then ubuntu full.
but I have a problem with SqueezePlay OS v1.03, sound disappears after a few hours, sound will back to normal after reboot sqpOS or re-launch squeezebox player
I have found same issue here(http://www.jogglerwiki.com/forum/viewto ... 460#p10514), but it's not a solution for sqpOS.
Street
Post by Street »
Awesome, I don't check these forums for a month or so and a whole new SqueezePlay OS comes out! Going to have to stick it on my Jogglers tonight and try it out.. Thanks! :)
Ah, you'll need to do an apt-get update before installing. There are no cached apt files on sqpOS when you download it.
roobarb! wrote:Ah, you'll need to do an apt-get update before installing. There are no cached apt files on sqpOS when you download it.
That did the trick mplayer-nogui now installed. Now I just need to find out how to install Logitech Media Server and I'm sorted. Thanks roobarb.
Check the comments on my website - there's a fella on there who's got it working.
Setting up LMS and mPlayer
Here's what I did to get my SqueezeOS up and running with Logitech Media Server and mplayer etc.
First of all, I did a full reformat of an 8Gb HPv165w memory stick using the HP reformatting tool, before using WinDiskImager to write SqueezeplayOS v1.03 via Windows.
Then, before booting it, I used my Ubuntu install (on a Joggler) via a hub to run GParted to resize the main partition to use the whole stick. I had to tell it to unmount the partition first.
Anyway, then I actually booted into SqueezeOS (via my additional USB port which I added by soldering a cable to the mainboard as detailed elsewhere).
I set it to connect to my wireless (which it did first time), it rebooted, and then enabled SSH access via Settings->Advanced->Additional Installation (or whatever the option was). It rebooted again when completed.
At this point Squeezeplay OS was quite happy to connect to Logitech Media Server on any of my other Jogglers.
Now I was able to install the other bits and pieces via Putty on my PC.
First I updated the sources list via
sudo nano /etc/apt/sources.list
and added the line
deb http://debian.slimdevices.com stable main
to the end of the file.
I then refreshed the repositories with
sudo apt-get update
This took a little while to complete.
Now I was in a position to install Logitech Media Server with
sudo apt-get install logitechmediaserver
Again, this took a little while to finish.
Logitech media server was now accessible via <JOGGLER'S IP ADDRESS>:9000
I took a moment to set this up, including the server name (default is joggler) and the player name.
To enable all streams to play I then added the BBC iPlayer, BBC iPlayerExtra, PlayReal, PlayWMA plugins in Logitech Media Server Settings->Plugins.
Finally I needed mplayer and the lame codec. These were easy to add via
(took a few moments) and
sudo apt-get install lame
This enabled me to play all streams that I have tested (including Sky Sports News at last!), although there is a few seconds delay before they kick in.
I hope that this is useful to those looking for full Squeezeplay/Logitech Media Server/play all streams functionality on their Joggler. Remember that this takes up more space than the initial SqueezeOS install. I use an 8Gb stick, but perhaps a 4Gb stick could do it.
EDIT: 1st June 2012 - Use nano instead of vi - it's easier!
You beat me to it! I've just installed Logitech Media Server on SqueezePlay OS, mainly using instructions from this page:
http://www.havetheknowhow.com/Install-t ... erver.html
I just replaced squeezecenter with logitechmediaserver in the install command.
After an hour or so of play, I have to say that SqueezePlay OS with LMS and Mplayer is the best implementation on the Joggler. It is absolutely awesome! Full re-encoding from WMA to FLAC for stations that still broadcast in WMA - even BBC WMA streams play well.
There is a little delay to the start of the each WMA stream due to being re-encoded before play.
Next project - mount and scan a share on my NAS, but not tonight.
guidows
Post by guidows »
Be carefull with LMS and the permisions if you want to use a music folder in a NAS.
For me it worked (I use an Apple Time Capsule with SMB shares) adding this line in /etc/fstab
//10.0.1.1/Data /mnt/capsule cifs password=mypassword,iocharset=utf8,file_mode=0777,dir_mode=0777,rw,mand 0 0
and apt-get install smbfs
is possible you need to use also an user option in your fstab line, the important thing to LMS is the mode=0777 to mount it with no problems.
Also, if you want to recover disk space, you can remove the other architectures in LMS
cd /usr/share/squeezeboxserver/CPAN/arch/
cd each version
rm -rf arm-linux-gnueabi-thread-multi/ powerpc-linux-thread-multi/ x86_64-linux-thread-multi/
Thanks guidows. I may have to read up on using samba with the command line.
My music share isn't password protected. Is the 'mypassword' bit in the fstab line a default, or should this be replaced with a real password?
Someone else warned about database size when scanning large shares. It keeps crashing on the stock OS during a scan and this may be a space limitation. I've resized SqueezePlay OS to fill a 16GB USB stick, so hopefully this won't be an issue.
I'm not sure if ofbeatdave has removed stuff for other architectures in LMS on the stock OS but I might check that tonight, if I get the time.
guidows
Post by guidows »
I don't believe is a concern the space in the joggler when use LMS. I have some like 11000 mp3 tracks and works with no problem with squeezeplay, server, and apache-mysql-php installed and I still have 100mb free (I'm talking of the internal disk of 1000mb). The only thing I miss, is to have a swap file o partition, but at the moment I don't see any problem with the joggler.
about the fstab, I believe you have to drop the password instruction. but with all the space you have, you could install webmin to manage all the things in your joggler using just a web brownser. In my case, my main concern is to have a childprof joggler server ;-)
gegs wrote: I'm not sure if ofbeatdave has removed stuff for other architectures in LMS on the stock OS but I might check that tonight, if I get the time.
Yeah, I think I have removed just about everything that I can!
I have set the wireless IP address of my Squeezeplay OS Joggler manually (it survives a reboot) by Putty-ing in and typing
sudo nano /etc/network/interfaces
and changing the contents of the file to
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet static
address 192.168.2.97 <-- my chosen IP address
netmask 255.255.255.0 <-- all my usual network stuff
network 192.168.2.1
broadcast 192.168.1.255
gateway 192.168.2.1
wpa-ssid "[none of your business!]"
wpa-psk "[none of your business!]"
I saved and closed the file before restarting the network with
sudo /etc/init.d/networking restart
This appeared to hang but I just exited the Putty window and was then able to Putty in with the new IP.
Hmm. Something's not right with my setup. I seem to disconnect from Logitech Media Server occasionally and need to reboot to get it going again. It could be a USB stick issue I suppose, but is there any other reason why LMS would stop.
Further to this, it appears to shut down it's SSH capabilities too as I can't SSH in unless I reboot.
EDIT: Just rebooted again and apparently I have fs errors so I'm guessing the USB stick isn't in top condition.
Wilberforce
Post by Wilberforce »
offbeatdave wrote:Hmm. Something's not right with my setup. I seem to disconnect from Logitech Media Server occasionally and need to reboot to get it going again. It could be a USB stick issue I suppose, but is there any other reason why LMS would stop.
What you need is some sort of network monitoring daemon like wicd or NetworkManager. A simple solution would be to set up a cron job to ping your router and if it fails run " /etc/init.d/networking restart".
You might want to check out my applet for wicd. If you use this I'd recommend you run a version of wicd newer than 1.7.2.2 (if SqueezeOS is based on ubuntu 12.04 then the one provided by the package manager should be fine).
All seems to be going fine for extended period on a different USB stick so I believe that the file system errors were caused by the rogue stick.
danynero
Post by danynero »
This OS is fantastic! Thanks a lot for your job.
Now I discovered that you can not install the system in the internal memory.
I would do without the USB stick because I want to connect the interface UCA202 Behringer because I use the Joggler with my amp and the audio is very poor, and increased volume generates a kind of noise on the right channel.
For now use the installed PnP squeezeplay Mk. III
Greetings from Italy
Daniele
Locked
