Thanks - I'm looking forward to itjp_hero wrote:Nice work Jazzmista. I've got a few ideas of some tweaks we can add to this. I'll test them out and get in touch.
I did try them, mustn't have mentioned it on the forums though! I have tried old versions - seeing if pre-downloading to SU binaries and pushing them to the correct place via /system/ image mount on my PC works - here's hoping!jp_hero wrote:have you tried gscript lite?jazzmista wrote:Also, for those who want a reboot widget, I've discovered a bug feature that allows you to reboot from the lockscreen. Simply slide left for the camera (instead of right to unlock), and wait for the Joggler to have a tantrum (as it has no camera) and reboot! Instant reboot as well
edit - 100th post!![]()
a custom script of
"reboot -p"
would make a normal device shutdown
and
"reboot"
would make a normal device reboot. Neither work because of the "odd" root method. We need to get the up to date su binaries installed in the right place. Have you tried old versions of superuser?
Almost certainly ADB listening for connectionsacesabe wrote: One thing I found odd was that when connected to my wireless home network, the wlano interface has 3 IP secondary addresses, one of them listening on port 5555:
You've got an OpenFrame unit? Where did you find that?!johnciaccio wrote:Has anyone tried this or any other rom on a openpeak openfram 7 (openframe 7e)? I have an old one and after looking around the internet I think the devices may be close enough to use the same methods and software as the Joggler.
http://www.linuxfordevices.com/c/a/News ... enFrame-7/roobarb! wrote:You've got an OpenFrame unit? Where did you find that?!johnciaccio wrote:Has anyone tried this or any other rom on a openpeak openfram 7 (openframe 7e)? I have an old one and after looking around the internet I think the devices may be close enough to use the same methods and software as the Joggler.
Picture, please!
acesabe wrote:For all you budding digital DJ's out there, check out DJ Controller from Market, uses midi over wifi to control your DJ mix app on your computer, works pretty good, although Joggler doesn't seem to support multi-touch, but it's a lot easier than using the touchpad or mouse!!![]()
http://yfrog.com/h0yxvzgj
http://www.linuxfordevices.com/c/a/News ... enFrame-7/johnciaccio wrote:roobarb! wrote:You've got an OpenFrame unit? Where did you find that?!johnciaccio wrote:Has anyone tried this or any other rom on a openpeak openfram 7 (openframe 7e)? I have an old one and after looking around the internet I think the devices may be close enough to use the same methods and software as the Joggler.
Picture, please!
gaffaw wrote:Hi Guy's,
Some great work going on here. What Ive seen so far looks amazing really impressed.
I've been playing with ICS for a couple of days now and wondered if anyone has managed to get the wired ethernet to work yet. If so is it a fairly easy thing to enble and get working?
I've had a play with the ifconfig command but to no avail. Is there an idiots guide maybe.
If I'm asking ahead of the game - apologies.
Gaffaw
miccheck1516 wrote:gaffaw wrote:Hi Guy's,
Gaffaw
I was told there was no support for ethernet in ICS....
