Follow the instructions in the first post on this thread:
"telnet (or SSH) into joggler, then
cd media
mkdir iPlayer
cd iPlayer
wget ftp://aero.exotica.org.uk/pub/mirrors/exotica/joggler/files/iPlayer.tgz
tar xvf iPlayer.tgz
rm iPlayer.tgz
chmod +x iPlayer.cgi (VERY IMPORTANT, this makes the file executable, without this it will NOT work)"
I ignored spoyser's bit about using 'vi' because it's a bit clunky. Instead I used WinSCP which looks like a dual pane file manager and allows you to edit files by double-clicking them - very simple but Windows only.
There are guides on how to use WinSCP at http://winscp.net/eng/docs/guides
BBC iPlayer/Live/Podcast/Categories Player - UPDATED June 15
Re: BBC iPlayer/Live/Podcast/Categories Player - UPDATED Jun
I did it exactly as in the first post , its at the very end it dont work for me , I just cant seem to get out of vi applications.xml
and save settings
Got it now , was just typing x and not entering the : , sheesh
and save settings
Hello
Is there a way to get proper full screen with this?
