roobarb! wrote:most of these issues really do boil down to a USB device problem. I build everything using an external desktop hard drive connected over USB - do you have anything else you could try running the software from?
Thanks for the reply. This is my second Joggler, and I'm a real novice, but I've gathered they can move in a mysterious way...
It wasn't booting when I got it, but I've successfully flashed it with PnPIII and it's working well. So it looks like it's capable of taking a flashing from a USB stick. But the Kingston & Sandisk sticks that worked for PnPIII don't work for SqueezeplayOS.
I do have an external USB drive that I can use to experiment with. So I guess I'd just use WinDisk Imager to write the image to the external drive, just as if it were a great big USB stick? I'll give that a try tonight.
I'm really just tinkering at this point - I want the Joggler to be a Squeezeplayer attached to my lounge stereo. In that respect PnPIII will work fine, using your Squeezeplay app that's already built in (and which is great, by the way). But the compulsion to tinker is a strong one...
cheers!
Simon
