Ah , cheers for that , I'll find out that info and get back to you .
What I mean by a screen is just to see what's going on with media etc in the LMS to help set up different hard drives etc .
Sorry for quoting this old post but... are we allowed to upgrade the Ubuntu packages without SqueezePlay OS to break? I have 165 updates waiting... I can't recall updating before.Finchlean wrote:I also had problems with SqPOS v3.03 and wireless access to LMS, wired network was fine.
Fixed by updating (SSH to Joggler) and type:
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
Now wireless works fine
hansel wrote:Sorry for quoting this old post but... are we allowed to upgrade the Ubuntu packages without SqueezePlay OS to break? I have 165 updates waiting... I can't recall updating before.Finchlean wrote:I also had problems with SqPOS v3.03 and wireless access to LMS, wired network was fine.
sudo apt-get clean
sudo apt-get update
I might give it a go , so once its running , what would I do to install LMS ?castalla wrote:max2play is okay - you access it via its webpage.
But it's easy to set up LMS on a joggler running sqpOS - just a few commands to type in (or paste and copy)
That way you have a joggler as a player and a LMS server.
If your music is on the router, you just need to know the hdd IP address, eg. \\182.158.0.1/diskdrive (or whatever it is)
hansel wrote:I know how to fix the apt-get command (to find correct sources). But is it save to install all of the updates?
wget http://downloads.slimdevices.com/nightly/7.9/sc/b7dfc80/logitechmediaserver_7.9.0~1459712283_i386.deb
Man in a van wrote:Managed to do a quick install last night, using a stick with v301 internal OS.
I was not able to connect the Squeezeplay via either Wireless or Ethernet for some reason. I gave up as it was getting late.
So: SqueezePlay installed;
Filesystem mounted on /dev/mmcblkOp2
Size Used Avail Use%
935M 577M 310M 66%
LMS i386.deb installed (no Plugins)
935M 780M 107M 88%
Apparently I did this in January this year (according to another thread).
Come one, this all basic stuff. I suggest you carefully read Roobarb's opening post and the links to his dedicated pages on his website. And read a basic Linux tutorial.hawsey wrote:How to you log in as root please , what do you type ?
