Imagewerx
Post by Imagewerx »
So can anyone give me a bit of help with this SSH thing please?
Install WinSCP on your PC. This will allow you to access the Joggler - list the filesystem - edit individual files.
You will need to edit the file asound.conf located in the /etc directory.
BUT
Have a look at this post:
http://www.jogglerwiki.com/forum/viewto ... dif#p22031
Imagewerx
Post by Imagewerx »
castalla wrote:Install WinSCP on your PC. This will allow you to access the Joggler - list the filesystem - edit individual files.
BUT
Ok thanks for that,all switched on,SPDIF socket installed and a nice flashing red light behind it :mrgreen: .
But.........the what ever it was you gave me to get it working with Flirc,how do I use it/where do I put it?
You need to install the Flirc Gui program for Windows - you use this to load the cfg file and program your remote. You do all this on your PC with the flirc dongle attached to the PC. Then simply plug the flirc into the Joggler. Do a reboot. Your original Touch remote should work/
Get the Gui program from flirc.tv
Imagewerx
Post by Imagewerx »
castalla wrote:You need to install the Flirc Gui program for Windows - you use this to load the cfg file and program your remote. You do all this on your PC with the flirc dongle attached to the PC. Then simply plug the flirc into the Joggler. Do a reboot. Your original Touch remote should work/
Thanks once again.So do I just load that file into the Flirc GUI and not program from my remote? If so I get volume up/down and play/pause working properly on the Joggler.On the Squeezebox,the forward and rewind buttons would give me track forward and track back or fast forward or rewind depending on how long I held them down for.Using it with the Joggler I only get fast forward and rewind.
Edit.....got that working,now it's only the main power/shutdown button that doesn't work.
I'm not sure of it works for other remotes - it works with the Touch remote. Just program the flirc dongle.
It basically just acts as a 'keyboard'. You can add commands by programming the remote directly using the gui program if you need to.
edit: correct. The power off doesn't work.
Imagewerx
Post by Imagewerx »
Ok thanks.Although it's not essential to have the power button working,this seems odd as it's included on the Flirc GUI?
Imagewerx
Post by Imagewerx »
Ok,mostly working now.I can't get it to automatically play the next track in a playlist.It only ever plays one at a time even though I've selected to play next.I have to do it manually every time,which isn't really ideal.
Also the time slider doesn't move when a track is playing and it doesn't show the elapsed and remaining times,unless I force it to a later position on the track from my phone,then it picks up the position to put the slider and the different times etc.
Go to settings in the LMS gui.
Select Player tab
Make sure the Play other songs is selected.
No idea about the time slider - does it work on the actual Joggler display?
Imagewerx
Post by Imagewerx »
castalla wrote:Go to settings in the LMS gui.
Select Player tab
Thanks for another answer,people will thing we've got a thing going on here :P !
You can never account for the numbnuts factor of accidentally pulling the power lead out while it's booting up.As well as what I mentioned,I also lost ALL audio from it.A quick reflash and it's all up and working again.
The only thing I can't get to work is a custom wallpaper.Did it the recommended way using LMS and it got as far as accepting the image,but I couldn't get it to save it to the Joggler.
Imagewerx
Post by Imagewerx »
Ignore that,found this......
To use one of your photos as your wallpaper:
1 Go to Settings > Image Viewer > Start Slideshow
2 When the photo you want to use is displayed, touch and hold the screen until a context menu is displayed
3 Select "use picture as wallpaper"
Select Player tab
There are so many settings to mess up !
jim_lewis1
Post by jim_lewis1 »
ain't that the truth. I might finally start making a dump of a set up to save myself the agro each time.
SteveC
Post by SteveC »
Just dusted off my Joggler to give this a go and it looks good. However, how do you manually configure the address of the LMS? Mine is on a different subnet (wired and wireless are firewalled apart), so the multicast/UDP autodiscover won't work, I need to manually add the server address (I have the same problem with Plex devices).
Cheers,
Steve
SteveC wrote:Just dusted off my Joggler to give this a go and it looks good. However, how do you manually configure the address of the LMS? Mine is on a different subnet (wired and wireless are firewalled apart), so the multicast/UDP autodiscover won't work, I need to manually add the server address (I have the same problem with Plex devices).
You'll need to do it from the command line, but it's pretty straightforward. Get the current IP address from Settings > Network (address is shown at the top) and then log in using PuTTY or other terminal app - username and password are 'joggler'. Then:
sudo nano /etc/network/interfaces
You should see something like:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet dhcp
Whichever interface you're using (I'm going to assume wired (eth0) but the same applies for wireless (wlan0)) edit it to look like this:
auto eth0
iface eth0 inet static
address 192.168.0.10
netmask 255.255.255.0
gateway 192.168.0.1
Obviously, leave your network name and key in there if you're on wireless and use addresses appropriate to your network. Then CTRL-X, say 'Y' to save, and just reboot.
SteveC
Post by SteveC »
auto lo
auto eth0
auto wlan0
auto eth0
gateway 192.168.0.1
Thanks for the reply, but sorry, I meant can I manually enter the address of my existing LMS server into the Joggler client? (My Joggler is on the network fine, and so is the server (but on a different network) I don't want to use the server on the Joggler itself).
JimbobVFR400
Post by JimbobVFR400 »
Settings > advanced > network > remote libraries
SteveC
Post by SteveC »
