Hi Jimbob, dwl99 - followed your advice and had a go at converting one of my jogglers to SqPOS to act as the primary LMS host as discussed in Friday's posts.
Had a Sandisk Cruzer Blade 4GB usb stick available so downloaded Roobarb's external file onto it - this stick has a small form factor so would be ideal for internal install later.
Aware of usb stick issues experienced by others. Guess what? joggler wasn't having any of it, ignored stick and booted straight into PnPIII which was loaded on internal memory.
I have 2 other sticks that the joggler does seem to like. One is loaded with PNPIII which I use as a rescue stick; the other has Roobarb's reflashing tool.
Reluctant to mess with either of these and both are too large for later internal install anyway.
Finally tried it with another brand new 8GB stick which would just about fit but still no luck.
Did I miss something?
Is a straight download and copy onto stick all that is required or does the file need burning with Win32DiskImager or something?
Does the Cruzer need reformatting first?
Is the md5 file required also? - tried it with and without but joggler still wasn't having it.
Having failed with USB attempt decided to reflash SqPOS onto the internal memory instead; worked fine.
Then amended fstab, etc with your coding and finally got the joggler to recognise my LaCie NAS drive.
So at least I now know it can be done
Set LMS off scanning.
Periodically checked progress via web interface and it worked fine for about a couple of hours.
Completed music sub-directory and file scans but then fell over when scanning media directories.
Presume this was because Joggler memory got full - there are a lot of pictures on that drive as well as music
Happened because I had set fstab to look at the root of the NAS drive but did that because the music is in a "My Music" folder and I wasn't sure if linux would be happy with the space in the folder name.
So priority now is to get the usb stick option to work.
Failing that find a way to point LMS only at the music folder and not the whole disc - how does linux handle spaces? or, can I exclude the media scan in LMS?
I'm nearly there(!!) but once again would be very grateful for your suggestions.
