Debian Bullseye for OpenFrame
cszhy
Post by cszhy »
pete wrote:@cszhy
You have to utilize sudo for all of the scripts and commands. This caused me issues with the scripts that created the squeezebox user and xorg stuff anyhow.
I mentioned that I was able to get Squeezeplayer going on the Joggler. That said I cannot get it going on the OP2 (large Openpeak with two speakers) due to rights issues as I can manually run it fine using the of user.
This is using the same stick as the Joggler and creating a new stick for the OF2.
OK I see. thanks
通过我的 PCCM00 上的 Tapatalk发言
OK so starting from scratch on the OpenFrame 2 (Cisco Home Energy Controller, Telio Touch) device.
Hardware purchased.
1 - Sandisk Cruzer 32Gb USB stick - tiny USB stick
Software utilized to write image to disk using Ubuntu
2 - Balena Etcher
https://www.balena.io/etcher/
Software utilized
1 - GParted in Ubuntu to expand second partition
Steps
1 - wrote Debian Bullseye image to 32 Gb USB stick using Linux Balena Etcher
2 - expanded EXT image to using entire 32 Gb USB stick
3 - wrote / edited boot network.yaml file for wireless (even though I know it doesn't work).
4 - plugged USB stick in OpenFrame 2 (Cisco Home Energy Controller, Telio Touch) device and wired Ethernet Gb switch
NOTE: first boot doesn't show IP for the Ethernet port until it sits for a few seconds then it comes up. It doesn't show a wlan0: address because there is no driver yet for it.
5 - booted with USB stick and logged in via user of and password joggler
6 - configured time to "America/Chicago"
NOTE: I get an error when doing this but it works. Must be the way I am typing it.
[sudo] password for of:
root@openframe:/home/of# cd /usr/local/sbin
root@openframe:/usr/local/sbin# ls
of-clean   of-flash	  of-install  of-scripts.ver  of-timezone
of-expand  of-identifier  of-netplan  of-settings     of-update
root@openframe:/usr/local/sbin# of-timezone set America/Chicago
Failed to set the given time zone.
I reboot after this and ssh back in.
7 - configured password for root and adjusted ssh configuration for root access
IE:
cd / etc/ssh
nano sshd_config
change line to:
# PermitRootLogin
to
PermitRootLogin yes
8 - created a sudo pete and sudo squeezeplay user
9 - Install Broadcom wireless drivers
edit /etc/apt/sources.list and add
# Debian 11 "Bullseye"
deb http://deb.debian.org/debian bullseye contrib non-free
sudo update
sudo apt-get install broadcom-sta-source (takes a while to do this)
check to see sources
sudo dpkg-query -l | grep broadcom-sta-source *
Kept trying here until I got to this point:
root@openframe:/home/of# lspci -nn -d 14e4:
02:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM43225 802.11b/g/n [14e4:4357] (rev 01)
Hardware purchased.
2 - Balena Etcher
Software utilized
Took the Openpeak2 apart.
Easy. Used a thin screwdriver prying up on the glass touchscreen then a long screwdriver pushing on the tabs until the touchscreen lifted out.
Removed all screws holding the plastic cover on.
Replaced the mini pcie combo WLAN and BT card with an Intel 7260 which was the combo card in my Lenova laptops.
Works right out of the box. That said created new USB stick.
lspci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 02)
02:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
root@ICS-Jog-SQP-19:/home/of# lsusb
Bus 001 Device 004: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 004 Device 002: ID 04b4:1974 Cypress Semiconductor Corp. OpenPeak Touchscreen Hyup05_3
Bus 003 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 002 Device 002: ID 8087:07dc Intel Corp. Bluetooth wireless interface
Connected to wireless right away. Connected to bluetooth right away.
of@openframe:~$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-08-31 17:20:46 BST; 8min ago
       Docs: man:bluetoothd(8)
   Main PID: 277 (bluetoothd)
     Status: "Running"
        CPU: 114ms
     CGroup: /system.slice/bluetooth.service
             └─277 /usr/libexec/bluetooth/bluetoothd
of@openframe:~$ bluetoothctl
Agent registered
[CHG] Controller 80:86:F2:26:16:27 Pairable: yes
[bluetooth]# scan on
Discovery started
[CHG] Controller 80:86:F2:26:16:27 Discovering: yes
[NEW] Device 4E:9C:42:26:3D:CA 4E-9C-42-26-3D-CA
[NEW] Device 5C:1C:6D:99:9F:46 5C-1C-6D-99-9F-46
[NEW] Device 51:FF:7B:02:BF:34 51-FF-7B-02-BF-34
[NEW] Device C4:F3:12:20:FE:CD C4-F3-12-20-FE-CD
[NEW] Device 61:45:CB:92:32:6D 61-45-CB-92-32-6D
[NEW] Device FA:B4:6A:C3:67:C6 ENVY Photo 7800 series
[NEW] Device D1:39:32:37:21:29 Govee_H6062_2129
[NEW] Device 70:B5:0E:9A:C2:34 70-B5-0E-9A-C2-34
Noticed one more thing on the Openpeak 2 (with speakers in front) is that the sound when using speaker jack works out to amplifier but the sound on the built in speakers is still one with said build.
Bluetooth is working fine for keyboards and mice now. Only thing not working is audio bluetooth out. Found out that I have to use BlueAlsa which is old and I have been trying to install it and have been unsuccessful.
https://github.com/Arkq/bluez-alsa
Sorted a few basic boot things today, the latest 5.10.141 image is a little less verbose and has a working caret again.
For those that like to hide the cursor at boot you can with
vt.global_cursor_default=0
in /boot/grub.cfg.
Thank you Andy!!!
So tried the build 5.10.141. It works except for:
1 - no speaker output; only audio jack output.
2 - constant static on little front speakers
3 - Squeezeplayer power off and reboot do not work and only restart Squeezeplayer
My quickie fix got ride of the static but still only sound via the audio jack. For me this is better than sound coming from both speaker and audio jack.
sudo nano /etc/modprobe.d/alsa-base.conf
and added this which got rid of the static.
options snd-hda-intel model=generic
shutdown via command line works fine.
Hey, @pete - is this on the Joggler type, the OpenFrame 1 with DECT or the OpenFrame 2?
Its a OpenFrame 2 (Cisco Home Energy Controller, Telio Touch) device with the two speakers in front. Thinking that that has DECT and Zigbee chip. This one like the little ones are labeled OpenPeak. It originally came with a DECT phone. It came new in a black box with an OpenPeak logo, serial number on the box and well packed. I was able to get the OpenPeak DECT phone to sort of work with my Panny DECT phone system. I could pick up and did hear a dial tone but could not dial out. It does have a battery and RTC that works. With the Realtek chip updated it will sleep and wake with a magic packet.
Here is the manual of the few Openpeak devices I got new many years ago.
https://usermanual.wiki/OpenPeak/OPOF2H ... 147094.pdf
Here are pictures of another one that looks like an Openpeak 2 except that inside it was stripped of many chips and labeled O2 #1 with a marker.
viewtopic.php?f=4&t=2315&p=25339&hilit= ... ECT#p25339
I was able to pull the screen off to replace the combo WLAN / Bluetooth card using a plastic wedge (two of them). Popped right off.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@ICS-Jog-SQP-19:~# hwclock
2022-09-08 22:13:42.825913-05:00
The RTC never loses its time when I disconnect the power.
I see both the Realtek MAC (that I wrote to it) and a new MAC.
root@ICS-Jog-SQP-19:~# ip a s eth0 | grep ether
    link/ether 02:f7:51:34:50:32 brd ff:ff:ff:ff:ff:ff permaddr 80:c8:62:24:42:19
I changed the mac address in the boot yaml file to the permaddr.
    link/ether 80:c8:62:24:42:19 brd ff:ff:ff:ff:ff:ff
root@ICS-Jog-SQP-19:~# sudo lshw -class network
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eth0
       version: 02
       serial: 80:c8:62:24:42:19
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.10.141op latency=0 link=no multicast=yes port=twisted pair
       resources: irq:16 ioport:e000(size=256) memory:d0100000-d0100fff memory:fef00000-fef0ffff
root@ICS-Jog-SQP-19:~# cat /proc/asound/cards
 0 [MID            ]: HDA-Intel - HDA Intel MID
                      HDA Intel MID at 0xd02c0000 irq 16
root@ICS-Jog-SQP-19:~# lspci | grep -i audio
00:1b.0 Audio device: Intel Corporation US15W/US15X/US15L/UL11L SCH [Poulsbo] HD Audio Controller (rev 07)
root@ICS-Jog-SQP-19:~# lsmod | grep -i audio
ledtrig_audio          16384  1 snd_hda_codec_generic
sota
Post by sota »
I tried installing bul-ext2-1028-43-bullseye-5.10.143op.img.gz on my OpenFrame1 (Joggler) and I got as far as of-expand OK but running sudo apt update & upgrade, I get this:
Processing triggers for initramfs-tools (0.140) ...
ln: failed to create hard link '/boot/initrd.img-5.10.143op.dpkg-bak' => '/boot/initrd.img-5.10.143op': Operation not permitted
update-initramfs: Generating /boot/initrd.img-5.10.143op
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125b-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/regulatory.db for built-in driver cfg80211
W: Possible missing firmware /lib/firmware/regulatory.db.p7s for built-in driver cfg80211
Any thoughts on what is causing this?
sota
Post by sota »
To answer my own question, it seems that the /boot partition is formatted as vfat which does not support hard links. I started again and expanded the USB drive and then just ran sudo of-install squeezeplay. This failed with:
2022-09-20 16:57:12 (530 KB/s) - ‘/tmp/squeezeplay-7.8.1-1002.tgz.md5’ saved [64/64]
1333777a3406d52ec915c46bc26f5f4f
Checksums match, continuing...
useradd: invalid shell 'bash'
chown: invalid user: ‘squeezeplay:audio’
sudo: unknown user: squeezeplay
sudo: error initializing audit plugin sudoers_audit
Cannot find user 'squeezeplay'.
No home directory found for user 'squeezeplay'.
cp: cannot stat '/opt/squeezeplay/share/plymouth/*': No such file or directory
Configuring splash theme 'squeezeplay'... updating initramfs... done.
Enabling 'grubquiet'... done.
Installation of SqueezePlay completed.
It has trouble creating the user squeezeplay. I ran sudo useradd squeezeplay -m and reinstalled squeezeplay successfully.
Paul Webster
Post by Paul Webster »
sota wrote: It has trouble creating the user squeezeplay. I ran sudo useradd squeezeplay -m and reinstalled squeezeplay successfully.
viewtopic.php?p=33195 for the solution that I went for.
sota
Post by sota »
This all started 10 hours ago when I tried to install Wireguard on my Joggler so we could use it when travelling. The install keeps choking here:
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.10.0-18-rt-686-pae
gzip: stdout: No space left on device
E: mkinitramfs failure gzip 1
update-initramfs: failed for /boot/initrd.img-5.10.0-18-rt-686-pae with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Has anyone got this working? I thought Wireguard was built into the kernel, so it should be a straightforward install :lol:
sota
Post by sota »
Paul Webster wrote: Tue Sep 20, 2022 5:21 pm
Thanks, Paul. I haven't used my Jogglers for a long time so I'm not up to date with all the posts about the updated software.
sota wrote: Tue Sep 20, 2022 10:30 am I tried installing bul-ext2-1028-43-bullseye-5.10.143op.img.gz on my OpenFrame1 (Joggler) and I got as far as of-expand OK but running sudo apt update & upgrade, I get this:
The firmware stuff is unnecessary and the driver works fine without it - you can install linux-firmware to remove the warnings, but it's fairly chunky (which is the reason it's not installed by default). The link as you discovered is due to the FAT format of /boot. It's initramfs trying to create a link that the format doesn't support and is again unnecessary. I think the Pi also uses a FAT /boot partition - if anyone knows how they correct or suppress this error it'd be nice to add.
sota wrote: Tue Sep 20, 2022 5:29 pm This all started 10 hours ago when I tried to install Wireguard on my Joggler so we could use it when travelling. The install keeps choking here:
Errr...
...whose kernel is that? :lol:
I'm guessing your
sudo of-expand
went okay, but I don't know where this kernel has come from, and if that's been installed it'll be chewing up all the space left on /boot, which is likely where your "No space left on device" error is coming from.
Decided to try bul-ext2-1028-43-bullseye-5.10.145op on Openframe 2.
Tried via USB stick and on eMMC. Same error on both ...file missing while booting...never saw this before...had no issues writing to USB stick or eMMC.
Not fast enough...saids file: not found
Just boots to a blinking cursor and gets no ip. It is Gb wired to home network.
Will take a picture of boot...
trying
bul-ext2-1028-43-bullseye-5.10.144op next...
Wrote it to a USB stick. Did not expand it.
Just a blinking cursor...
trying bul-ext2-1028-43-bullseye-5.10.143op next...
Settled on back to bul-ext2-1028-43-bullseye-5.10.143op. I had issues with bul-ext2-1028-43-bullseye-5.10.144op and bul-ext2-1028-43-bullseye-5.10.145op.
bul-ext2-1028-43-bullseye-5.10.145op would write to eMMC and or USB stick except when booting it would say file is missing. Tried this a few times.
bul-ext2-1028-43-bullseye-5.10.144op would just error out when booting either from USB stick or eMMC.
Thanks, @pete - I'll check out the logs.
Thank you Andy.
Oh, looks to have been an issue with the Debian repositories. Don't know if they moved or changed something but some packages were 404, which preventing most things from installing, which broken everything that came after. :lol:
There's been a new kernel release, 5.10.147, so it's just compiling that and it'll try again with an image build.
UPDATE: Kernel built fine but apt is still looking for some .deb packages which don't exist. I'll clear all the caches and run it again.
Installed new kernal release 5.10.147 on an O2 Joggler. Works great Andy!! Thank you.
Also installed it on the Openframe 2. Sound did not come out of the speakers but earphone jack works fine.
