FFXP My New XP release (vhd link in first post finally!!)
jpearn
Re: FFXP My New XP release (link in first post finally!!)
Post by jpearn »
Dan, I've added the output from chkdsk for both partitions here. The program autostarted, but I think everything hung as I left it for 15 minutes . . .
I only ran it in read-only for the txt files, in fix it recovered 4 orphan files on the EFI partition and a few on the main partition.
Chkdsk.zip
(2.16 KiB) Downloaded 252 times
jpearn
Post by jpearn »
This is as far as it's going, the auto script is showing in the background then a USB Mass Storage device pops up behind the Inscribe keyboard.
Same here.
Just tried something else; too many steps though.
I extracted the files from the EFI and NTFS directories saving them to separate directories using Paritition Guru. I then went to GParted and wiped both of the partitions. I then created an EFI and NTFS partition. I then deleted the EFI partition and copied the NTFS partition files over to the newly created NTFS partition; then again to GParted I made it bootable and recreated the EFI partition. I then copied all of the files over to the EFI partition.
Booting now (with the above mentioned USB stick) I get it stopping at the "ffire.sys" piece of the boot process; so it went further just putting in the pieces of the script and DLL's above as you mentioned JP and rebooting the original image that way.
BTW the original read to check with GParted showed errors on both the EFI and NTFS partition (unfixable in Linux). I did fix the EFI parition in Windows and it created an orphaned file directory. I though though maybe this was my USB memory stick though.
Dan, thinking maybe to delete Hotfile links eh? Or would it be better to wait for more folks to give it a try?
is usb mouse not working?
Here the hub or no hub doesn't boot with a hub (and keyboard / mouse)
jpearn
Post by jpearn »
I can boot with hub, but USB mouse / keyboard isn't working.
Sorry fellas reimaging tonight, Don't understand what's up though its working beautifully on mine,
Dan,
Do you me to remove it from Hotfile?
Interesting only three downloads. You are "da boss".
Yeah delete from HF, will try a few fixes tonight before reuploading though could be something easy I am missing lol
Done.
cheers Pete for reuploading though :)
Not an issue Dan. Let me know whenever for the update and will post to HF.
ok mate will do gonna shrink an vhd of the same build and see if that fixes things...
Wow vhd files compress to really small sizes, 600mb in total, jus gonna test in a hdd and will report back
touch now works on my hdd, will upload the new vhd file tonight, signed up for my own dropbox too lol
Great news Dan!
Yes; like the compression sizes of VHD versus the IMG file.
Are you using an HDD versus a USB memory stick? I didn't think of trying the image on an HDD; just the USB memory stick was all I tried it on.
yeah i only own one stick and one hdd, no poiint retrying on my stick as that will just be the exact same hardware id, it should be ok now
and compression sizes are awesome, i now see mevi's thinking lol
and cheers pete as always my top feedback giver lol
new links will be ready tonight, have now backed up entire build into a vhd file, compressed to just 617mb, unrar then write the vhd file to your ntfs partition, should be ok then, i have only been able to test on my usb micro sd and my hard drive but they both picked up all drivers fine.
Re: FFXP My New XP release (vhd link in first post finally!!
await to hear from a tester, sleep for now lol
only just downloading the newer version now and will put it through it's paces. Have 2 free sticks i can image.
I'm still trying to fix the odds and ends on my build. Audio still giving me a headache. Hopefully, I can pilfer new improved drivers from your build. :D
