PNPIII - trying to get NAS mounted for LMS - SUCCESS!!
Re: New to Joggler. best option?? how to do that?? n00b here
You must be so frustrated that you can't get it working. :x
I don't have a fully-fledged NAS myself, but my router (Linksys x3000) simulates one when a USB hard drive is attached to it. It shows up like a NAS on pretty much every gadget.
To mount it on a Joggler for Logitech Media Server to find I fill out the following in the webserver:
IP Address: I just put in 192.168.0.1 (the IP of the router)
Shared folder: Music (no / \ or anything else. Music is the simple name of the share which I have configured in the router settings. I presume it is case sensitive.)
Username: joggler (I set up a user in the router settings)
Password: joggler
Mountpoint: media folder 1 (or whichever number you choose. I have set up each joggler in the house to work with a different folder. Don't know if that improves things/prevents/causes problems, but it works for me.)
I then click 'Add Data' to set it up.
I then access it in LMS -> Settings -> Basic Settings -> /media/media/media-share1 (as long as the media-share number matches the folder number set as the mountpoint). I wonder if the problem is not pointing it to media-share1 in the /media/media folder (or 2, 3 etc depending on which media folder is configured).
Hope this helps solve your problem!
Error
Post by Error »
well yes and no, I configured it exactly how you say you did:
- My NAS is on IP 192.168.0.12
- Share is called Muziek (Music)
- Made user Joggler
- with passw Joggler which has Administrator rights on the NAS
- mounted it to folder 1. (Been trying to mount it in another folder but that doesn't help either.)
Add data : It says its mounted/modified
Set it up in LMS to media/media/folder1. Then let it scan but it returns no files, nothing, all is returned as zero and/or empty. It's just as if it's not mounted at all..
Would rebooting the Joggler help? I don't kwow?
Could it have something to do with DHCP?? Don't think so but you never know? The Joggler has internet (WiFi) which works, so that can't be it?
As I said - try putting in
Public/Muziek
have you got PuTTY installed? Login to Joggler; Type
dir /media/media/folder1
What do you get?
Can you confirm that you can PuTTY into the Joggler? I think this is the only way we can get some idea of what is happening.
Error
Post by Error »
castalla wrote:PuTTY - http://www.chiark.greenend.org.uk/~sgta ... nload.html
This will let you login to the joggler - you'll see a command line prompt. Just type: dir /media/media
Note what is returned - post results here.
I start PuTTY; type in the address of Joggler which is 192.168.0.12
login next with joggler, passw = joggler.
Then a line with #
I type dir/media/media
and the return is
-sh: dir/media/media: not found
When I add .../folder1 the answer is the same..
It's not folder1. It's shared-media1
Hmmm - what do you see if you just type:
dir /media
We need to see if the correct folder is being mounted.
Also, we still need to discover where the Muzeik folder is on your NAS .... can you discover a path when you look at Muzeik via Explorer - something like /Public/Muzeik
Yeah, think this may be the cause. My 'Music' is the name of my partition located on 192.168.0.1
Error
Post by Error »
I Putty'd: 192.168.0.12 = the Joggler.
Dir/media
dir/media/media
dir/media/media/media-shared1
dir
But all my options return: not found.
192.168.0.13 = the Server
When I try to Putty in the Server I get the message "Network Error. Connection Refused"
Eehm.. say what :shock: Like it can't see it?
I tried mounting LMS again
- IP of the server (which is ...013, I said ...012 earlier but that is the Joggler)
- share = Muziek
user and passw = Joggler
And again; the weel keeps turning and nothing happens.
So I'm getting the feeling it doesn't see my NAS at all.
Address of server is \\Peekserver\Muziek which is reachable via Windows Explorer
I AM however able to play music via Upnp on the Joggler so it cán see it!
Another option is to buy a big USB stick and put all my music on there? but I can't stand why its not wanting to work!
Re: PNPIII - trying to get NAS mounted for LMS
We can try the following as a test:
login via PuTTy to Joggler.
type
mkdir Muzeik
(this creates a new folder called Muzeik)
Now type
mount -t cifs //192.168.0.13/Muzeik /Muzeik -o username=Joggler,password=Joggler
If there is no error message, then type dir /Muzeik - you should see the music files
Note the above is just a test. If it works then we can move on further.
Error
Post by Error »
I get the message:
"can't find /muziek in /etc/fstab"
So there it looks then?
Errr ... no
No idea why it's returning that!
Let's try again - login to Joggler. But this time, use username root and pass joggler. If it doesn't let you in, then use joggler - joggler
Type dir
What do you see?
You should see Muzeik listed (if you did mkdir Muzeik earlier)
Error
Post by Error »
Well I see
-sh: dir: not found
I did mkdir earlier on..
I tried making Muziek again (mkdir Muziek) and then it says
mkdir: cannot create directory Muziek: file exists
But dir/Muziek does return
-sh: dir: not found
It's
dir /Muzeik
There's a space
edit: see below
Ooops --
type
dir Muzeik
Error
Post by Error »
doens't make a difference.. tried all varieties, Capital M, slashes, whatever... all return 'not found'
Okay - this is bizarre.
Login again. At prompt simply type dir
If the Muzeik folder exists then it should simply be listed.
If not, then mkdir TEST
Then do dir
Do you see the TEST folder listed ?
I want to try a modified approach.
Login.
At prompt: sudo mkdir /mnt/TEST
then
dir /mnt
Do you see the folder TEST listed ?
If yes, then:
sudo mount -t cifs //192.168.0.13/Muzeik /mnt/TEST -o username=Joggler,password=Joggler
dir /mnt/TEST
Error
Post by Error »
login as: joggler
joggler@192.168.0.12's password:
# dir
-sh: dir: not found
# mkdir test
# dir
-sh: dir: not found
# dir/
-sh: dir/: not found
# /dir
-sh: /dir: not found
# dir/test
-sh: dir/test: not found
Error
Post by Error »
castalla wrote:I want to try a modified approach.
Login.
then
dir /mnt
If yes, then:
dir /mnt/TEST
well eeehm...
login as: joggler
# sudo mkdir /mnt/TEST
-sh: sudo: not found
# dir /mnt
-sh: dir: not found
Could there be something wrong with PuTTY?? I guess not but who knows??
