Jogglers forum only Openframe 1.0 sale
Re: Jogglers forum only Openframe 1.0 sale
Hi Pete
Could you upload the contents of the EFI chip from one of these please, I am presuming its slightly different to the standard jogglers.
Yes; the boot EFI flash chip contents eh?
It would be from the Verizon Joggler II device which is the Openframe 1.0 device.
BTW - the original Verizon EFI boot partition on the MMC looks totally different; as it has a recover boot setup on it.
Today goofing around a bit; wrote the base Ubuntu build on an SSD USB device. Installed XBMC on it.
I had to edit the grub.cfg file a bit. It does show up in the EFI boot menu as the first device and it boots fine. Still no luck though with the MMC boot partition stuff.
Pete
Yes thats the one, would like to have a look at it and see what the differences are, when you get chance could you upload a copy please.
Thank-you Mick for having a look.
Attached is the EFI boot flash for the Verizon Joggler II.
vz.zip
(565.72 KiB) Downloaded 385 times
Thanks Pete
Will take a look, when I get chance
Playing a bit with some EFI stuff today.
http://www.rodsbooks.com/refind/installing.html
