Would that make a difference, as I thought there were issues with Telnet post the update!butch_uk wrote:As a non-techie, re the telnet problem, have you checked the obvious and made sure that a firewall or AV isn't blocking port 23?
I've got it back to the original state, and it now allows me to Telnet in via my IP address. However, it only allows me to enter username; letmein, but not password, as it wont let me enter in the password via the computer keys. Any thoughts as I'm trying to upgrade to PnPIII. Thanks
When you type the password in telnet it doesn't display anything.
EDIT: Oops. Wrote time instead of type. Watching Monaco qualifying whist typing!
Yes, that's right. It doesn't allow me to type in anything?offbeatdave wrote:when you time the password in telnet it doesn't display anything.
Sorry, that was a statement, not a question! Even though nothing is being displayed, the password is still being entered.stephen m wrote:Yes, that's right. It doesn't allow me to type in anything?offbeatdave wrote:when you type the password in telnet it doesn't display anything.
Just rebooted the Joggler - now wont let me Telnet in - what !!!
No probs guys - all sorting now with PnPIII up and running. Thanks
I have installed pnp iii but cannot get angry birds to work or baseball any ideas
try rebooting. sometimes the bits they need fail to load on startup
stephen m wrote:Would that make a difference, as I thought there were issues with Telnet post the update!butch_uk wrote:As a non-techie, re the telnet problem, have you checked the obvious and made sure that a firewall or AV isn't blocking port 23?
The new username is 'root' not 'letmein'.
'letmein' and not 'root' give me access!butch_uk wrote:stephen m wrote:Would that make a difference, as I thought there were issues with Telnet post the update!butch_uk wrote:As a non-techie, re the telnet problem, have you checked the obvious and made sure that a firewall or AV isn't blocking port 23?
Oh, reading back it seems you're running PnP III on the original o2 software so yes, letmein is the telnet login. Sorry.stephen m wrote: 'letmein' and not 'root' give me access!
thanks offbeatdave, I have rebooted a couple of time still angry birds not working, not overly fussed just nice to have the joggler back to how it was befor the update with radio etc, but would like to know why angry birds isn't working.
Useful links now in the 1st post
Update
For those wanting to customise the YouTube app feeds, it's original thread containing the instructions for this is now linked via the 1st post. I've also linked other useful threads in my 1st post.
Forgive my naivety if this is a dumb request, but any chance of a simple firewall for PnPIII so I can keep OpenPeak out of my Joggler and stop them trashing it again?
Thanks in advance.
Thanks in advance.
I might just be being naive, but thought i'd ask
I've managed to work out how to use Notepad++ to remove all the unwanted games from the new PnP III updated, but was wondering if there's anyway to get rid of apps like sky news, sky sport etc. which i think were standard from the original O2 software.
Thanks in advance
Thanks in advance
Are you running PnP III on the original o2 system or the updated OpenPeak system?i-mouse wrote: I've managed to work out how to use Notepad++ to remove all the unwanted games from the new PnP III updated, but was wondering if there's anyway to get rid of apps like sky news, sky sport etc. which i think were standard from the original O2 software.
Just a heads-up to say that v3.034 is now available from the first post.
It's not worth re-installing if you're running a recent version to be honest as it just removes the Sky News app (which no longer updates) and incorporates roobarb's most recent squeezeplay (which is update-able in existing versions anyway).
offbeatdave wrote:Are you running PnP III on the original o2 system or the updated OpenPeak system?i-mouse wrote: I've managed to work out how to use Notepad++ to remove all the unwanted games from the new PnP III updated, but was wondering if there's anyway to get rid of apps like sky news, sky sport etc. which i think were standard from the original O2 software.
Erm it crashed out on me last night, so have had to reset it via the birdslikewires site, so it's currently on the old O2 system. Hoping it'll update itself to the new O2 system, as I like the way the PnP III looks on the new system (oddly, there is a difference!), then I'll reload PnP onto my Joggler.
But a guide for either would be nice - i'm sure i'm not the only one who doesn't like sports
On the pre-update o2 version, there isn't a reference to the Sky Sports app in the pnp3o2.shx script as it on the machine by default. You could edit the o2-applications.xml file in the o2applicationstweak.tar archive to remove the line referring to the Sky Sports app. You could also edit this file after installation where you'll find it located in the /openpeak/gui directory.i-mouse wrote:I've worked out how to use Notepad++ to remove all the games, I just couldn't see where the sky sports etc. was in the scripts - might just be me being a typical blond as usual!
On the post-update OpenPeak version the reference to the Sky Sports app is under the section titled #ADD SKY SPORTS NEWS (MAY ONLY WORK TEMPORARILY) in the pnp3op.sh script
