Have you got a USB wifi card installed in your Joggler? Might sound like a stupid question but I was tearing my hair out with a similar issue, until I discovered the 'betting shop' ebay Jogglers don't have Wifi cards.
Andy.
Andy.
you're joking! Why on earth would they remove them?andyf wrote:Have you got a USB wifi card installed in your Joggler? Might sound like a stupid question but I was tearing my hair out with a similar issue, until I discovered the 'betting shop' ebay Jogglers don't have Wifi cards.
Andy.
- JimbobVFR400
Maybe they had them booting from a USB key installed in place of the card, that's what I do with SqPOS on my Joggler that runs LMS. Another possibility is removing any vectors for dodgy attacks on the terminals.dwl99 wrote:you're joking! Why on earth would they remove them?andyf wrote:Have you got a USB wifi card installed in your Joggler? Might sound like a stupid question but I was tearing my hair out with a similar issue, until I discovered the 'betting shop' ebay Jogglers don't have Wifi cards.
Andy.
Just checked mine, as I have not really used it yet, only to make sure it worked
(Mine does have a wifi card)
Weird. both of mine are missing their wifi cards.
Hi Andy mine (3 devices) do have a internal wifi card.andyf wrote:Have you got a USB wifi card installed in your Joggler? Might sound like a stupid question but I was tearing my hair out with a similar issue, until I discovered the 'betting shop' ebay Jogglers don't have Wifi cards.
Andy.
Did you open your joggler to check if the card is present (or do you just guess because there is no driver loaded)?
SqueezeOS (Version 2) for OpenFrame/O2: USBIP
Hi all,
I installed USBIP on my joggler to share the USB device to other systems:
http://usbip.sourceforge.net/
Unfortunately its not working.
Both USBIPD (daemon) and USBIP (client) are reporting errors.
@roobarb!: Is there any chance to have those parameters enables in some future release of SqueezeOS?
sudo apt-get update
sudo apt-get install usbip
joggler@openframe:~$ sudo usbipd -D
usbip err: stub_driver.c: 33 (open_sysfs_stub_driver) usbip_common_mod.ko and usbip.ko must be loaded
** (process:2426): ERROR **: driver open failed
With reference to this thread: https://bugs.launchpad.net/ubuntu/+sour ... bug/900384 the kernel needs to be changed.joggler@openframe:~$ sudo usbip --port
/sys/bus/platform/drivers/vhci_hcd is not found
load usbip_common_mod.ko and vhci-hcd.ko !
Did anyone of you succeed installing USBIPD?The Ubuntu Kernel Team's config policy is to disable experimental options until it is requested they be enabled. Based on the information requested in this bug, I have enabled the following in the Precise 12.04 kernel:
CONFIG_USBIP_CORE=m
CONFIG_USBIP_HOST=m
CONFIG_USBIP_VHCI_HCD=m
Hi again, guys ..... ok, I am struggling a little bit with this .....
I have sqpos and LMS running on internal usb with ext hdd attached to ext usb .... I do most of my computing on a windows machine and want to simply add more music files via my network to the ext hdd on the joggler BUT ..... this is where my knowledge of Nfs or samba runs out ....
help please what are the simple steps to setting this up .....
roughlychiron wrote:Hi again, guys ..... ok, I am struggling a little bit with this .....
I recommend using a ssh capable program like WinSCP http://winscp.net/
there is no need to struggle around width NFS an/or samba.
- JimbobVFR400
I was going to suggest similar as a quick and simple option, however if it was me I would get Samba setup because then I could also use the files on my PCs and other devices and access them as a share directly with utilities like mp3tag.palindrom wrote:I recommend using a ssh capable program like WinSCP http://winscp.net/
Sadly I don't have any pointers for doing this as I don't use a drive connected to my Joggler.
I followed this guide and set up a share with guest access. Works a treat. http://www.howtogeek.com/howto/ubuntu/i ... on-ubuntu/
And the tweaks from this to enable guest access http://amazingrando.wordpress.com/2007/ ... word-easy/
Great, thanx guys .... I tried winscp and whilst I was able to copy from the hdd attached to joggler so far I am denied permission to copy to the hdd ..... am I missing a simple thing?
will look at the other suggestions also ....
cheers
cheers
If logging in as a user, you'll need that user to 'own' the folder structure, else you can't write to it.
If you harddrive is mounted as /media/exthdd and the user is joggler the command would be:
sudo chown -R joggler /media/exthdd
Tried your suggestion Andi ..... 'Operation not permitted'
What file system is on your external HDD?
And if it's NTFS, have you installed and setup NTFS-3G or not?
(If not - there's your problem - Linux supports NTFS as read only. You need to add NTFS-3G from the apt-get repository and configure the drive to mount using that instead.. Will await your reply to give details though).
it's a 2tb reformatted to fat32 .... which I hoped would simplify everything lol
How have you mounted it? Did it do it automatically or did you add it to fstab ?
Actually never worked with FAT32 under Linux as the 4Gb is too limiting for me so have always used ext4 or NTFS!
Are you using winscp as sudo?
Andi - I think it mounted automatically as I simply plugged it into the side and browsed straight to it in LMS
ilovemyjoggler - I am a complete Linux noob and not quite sure what you mean ... I installed winscp on my PC and it connected to the joggler ok and will allow me to copy music from joggler to PC but not the other way around
clear as mud haha
clear as mud haha
