THINGS TO TRY IF DATE/TIME/INTERNET DON'T WORK
Re: THINGS TO TRY IF DATE/TIME/INTERNET DON'T WORK
Sorry for bumping this but there seems to be a few more new members recently having the classic connection issues!
Alera
Post by Alera »
Mine wont work through dhcp. It connects with manual settings but no net access.
try rebooting once you've popped in your settings.
dave64k
Post by dave64k »
O2 posted me out some new software on a USB stick which has solved this problem. They have said that they will make available to the O2 Joggler Forum.
dave64k wrote:O2 posted me out some new software on a USB stick which has solved this problem. They have said that they will make available to the O2 Joggler Forum.
EDIT 14th JUNE 2012 - THE NEW OPENPEAK REFLASHER FROM THIS POST SHOULD FIX THESE ISSUES
Edit 2: Hmm, it appears PnP III may break it again!
Edit 3: And I might have worked out why...
I can now confirm that it was the updating of busybox in PnP III that broke the fixed Networking from the new OpenPeak reflasher. PnP III v3.038 is now uploading and fixes this issue by reverting to the standard busybox on the Joggler.
