Best USB 2.0 connections on CPU side of Motherboard
Re: Best USB 2.0 connections on CPU side of Motherboard
Even though the WLAN card and USB SSD card are adjacent to each other; heat buildup inside of the case is still more from the CPU. That said will be looking now to cool the CPU and ventilate the case a bit more.
I'm doing a second Joggler tapping into the next USB port as mentioned above. I've been using the "extra" wire I have left over from a small TS/USB hub that I purchased for the Asus Netbook.
Just wondering though about a source of say 24 guage or higher wire.
