Ubuntu Bionic request .
Re: Ubuntu Bionic request .
Thanks for trying Pete :-) I appreciate it .
Must be the fluctuating power stuff on the USB port. Not sure is a powered USB hub would make any difference. I could maybe by pass the hub by plugging in the stick internally to the wireless USB port and the keyboard wireless dongle on the side USB port?
No issues at all using the ZIF SSD drive (and much faster to update). I can though say that the updating of the USB stick took over 12 hours and wondering now if it is because I used an 8Gb stick. I did make the efi boot partition larger at around 150 Mb shifting over the partitions and the stick did boot up fine.
Writing about the EFI stuff cuz here upgraded a PipoX7 to boot in either Windows 10 or Ubuntu 18.04 for use with KODI. Tinkering with it over the last few years created some 6 more EFI boot things in the BIOS which trashed the boot went to efibootmanager here and just deleted all of the bios booting EFI partitons until there was only two; one for Windows 10 and another for Ubuntu 18.04, Not sure if you can utilize efibootmanager with the Joggler. Never tried. You can run it fine via ssh and the command line.
Thanks for all the efforts :-) I'm struggling on myself and managed to install some of the Amature Radio software I wanted on 14.04 but have now decided to upgrade to 16.04 , wish me luck :-) .
Afterwards I will look at Bionic .
Good Luck Gary.
Try maybe not using a hub and using the internal USB port for your USB stick and the external USB port for your combo keyboard / mouse stuff.
Here utilize a Logitech K400 wireless keyboard and mouse. It even works with the EFI blind typing stuff.
Well it looks like I broke my build going up to 16.04 , it tries to boot but then brings up emergency mode .
If I hit enter I get root@joggler is there any easy way to fix? :-)
Maybe try ..
systemctl default or control D
or
Boot up with a working Ubuntu stick and check the other stick..
sudo -i
fdisk -l
umount /dev/sdb1
fsck -y /dev/sdb1
poweroff
(check to make sure other not booting stick is sdb1.)
shadow1901
Post by shadow1901 »
Hi all
Has someone an working bionic image for my Openframe2 device?
I tried to upgrade but always same problems with emergency mod menu and not working network
shadow1901 wrote: Wed Feb 27, 2019 1:24 pmHas someone an working bionic image for my Openframe2 device?
I need to take a look at this, but it'll be a couple of weeks before I get chance now. It's on the list! ;)
@Gary,
Resurrected the network on my modded Openframe box such that I have XUbuntu 18.04 running fine now with the Gb ethernet port and Wireless.
Webmin shows:
I installed current version of KODI on it and it works fine. Also installed SqueezePlayer and it works but doesn't save my settings and wondering why.
KODI works but it is not using hardware acceleration rather VMWare drivers for Video.
This is what I see with video:
root@ICS-Jog-UBT-16B:/home/joggler# lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation US15W/US15X SCH [Poulsbo] Graphics Controller (rev 07)
root@ICS-Jog-UBT-16B:/home/joggler# sudo lshw -C display
*-display UNCLAIMED
description: VGA compatible controller
product: US15W/US15X SCH [Poulsbo] Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 07
width: 32 bits
clock: 33MHz
capabilities: pm vga_controller bus_master cap_list
configuration: latency=0
resources: memory:d0100000-d017ffff ioport:f070(size=8) memory:c0000000-cfffffff memory:d0180000-d01bffff
Updated Intel drivers to opensource just to see if it works.
I installed Squeezeplayer from the Squeezeplayer repository as tried using Andy's but it would not work with Ubuntu 18.04.
It must be some setting with Squeezplayer as I configure for full screen on the Joggler and it sees all my other Jogglers BUT when I exit it never saves the settings and I have to reconfigure it. I do not now what I am doing wrong. And now the player screen works but never comes up. I have installed it some 3 to 4 times now with the same results. Might be missing something here in the settings. Are the dynamic settings stored some place other than the /opt/squeezeplay directory?
Tell me the exact links to your SDR application such that I can try installing it. I have a few of these little SDR sticks / antennas around from my tinkering here.
Note that I want to install the SDR application and not an image for an OS.
The plan would be to take the SSD image over to a USB stick partition by partition here.
That's great Pete , great progress :-) thank you .
The SDR software was Gqrx
http://gqrx.dk/download/install-ubuntu
Although I wouldn't mind if it was a different one if Gqrx is no good to install .
Ok started...see this right now with updating...
Err:18 http://ppa.launchpad.net/myriadrf/gnuradio/ubuntu cosmic Release
404 Not Found [IP: 91.189.95.83 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/myriadrf/gnuradio/ubuntu cosmic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Installed GNURADIO / GNU Radio version 3.8.x with Python 3 support:
sudo apt install git cmake g++ libboost-all-dev libgmp-dev swig python3-numpy \
python3-mako python3-sphinx python3-lxml doxygen libfftw3-dev libcomedi-dev \
libsdl1.2-dev libgsl-dev libqwt-qt5-dev libqt5opengl5-dev python3-pyqt5 \
liblog4cpp5-dev libzmq3-dev python3-yaml
Using one of those NOOElec USB to test. Works fine directly and via VNC.
Got Squeezeplayer to work fine now. Saves configuration and I see it on the Squeezeplayer website as a registered device with my custom mac address.
Player MAC Address:
XX:XX:XX:00:00:01
Player Firmware Version:
7.8.0-r1116
Great work Pete , well done :-) let's hope it works from Usb , fingers crossed . I can get an SSD but it will be usb boot still .
Yes... next steps here will be to remove the SSD drive and do an external partition copy to a USB stick using my laptop....not sure if it'll work.
That said the original installation to SSD came from Buzz's USB XUbuntu image...copying it over to the SSD drive and redoing the EFI boot partition.
Note that the video driver working is not the Joggler GPU stuff rather it is whatever Ubuntu 18.04 configured as posted above.
It works fine for the SDR radio graphics.
shadow1901
roobarb! wrote: Thu Feb 28, 2019 2:32 am
Hi roobarb
Do you have any updates?
I tried some upgrades and nothing works correct.
Do you have an working actual image with desktop?
Regards shadow1901
shadow1901
shadow1901 wrote: Thu Apr 18, 2019 8:09 am
Hi roobarb
Regards shadow1901
Hi all
No updates?
I tried any times install an desktop os, but always I have problem with "no space left on device".
Has someone an working image for the openframe2 device with desktop environment?
Regards Shadow1901
