Re: release: xp on joggler foshiz edition (image up)
sorry torrent is bad guys give 5 minutes apologies
SuperSaf
Post by SuperSaf »
Happened to stumble across the forum yesterday and saw your posts about XP, had to come back and register. Browse the forum sometimes but not been on for a while!
I'm downloading the image from the filefactory link you posted, unbelievably slow but it's chugging along. Downloaded 950mb @ 127.6KB/sec... Got about 1 hour and 20 mins left!
Ah well, got some stuff to do anyway, so once it's downloaded, I'll give it a go and let you know how it works. :)
Thanks for all your work,
Saf
The first one "finished" downloading but I don't think its complete. It won't let me open it. Its at 191,009 Mb. I thought the original size was 1.5 Gb.
I'll try a bit later.
damn all the hard work done but the uploading is the staller lol
try this
SuperSaf
Post by SuperSaf »
Got 1gb downloaded off the original jogglerfull.rar, just half a gig to go. I'm sure once a few people have it, we'll be able to upload it back using torrents or other hosting sites so it's all a bit faster (with your permission of course) :)
Virgin upload speed is poor though, I'm on 20mb and even with the latest 'speed update' it's about a 2mb upload line. Guess it's better than what it used to be...
hope it finishes mate keep me posted!
L11
Post by L11 »
Just downloading now, will let you know how I get on! THis is exactly what i need though as I've been trying to set my joggler up as DLNA server and I'm finding ubuntu so uneccesarily complicated. With windows XP i'll just need to download sabnzbd, ps3 media server, mkv2vob and i'll be done!
SuperSaf
Post by SuperSaf »
Got it. Just finished downloading. Extracting it from the RAR. How do I go about putting the img onto the USB stick? Just the same as it's done with joli/ubuntu/android etc? dd the img on using terminal? Hmmm, wonder if it'll work if I restore the img onto USB using Disk Utility (mac).... I'll give it a go :)
i do with win32 disk imager
Another application which I use for the image to USB stick is called USB Image Tool. You can get it here:
http://www.alexpage.de/usb-image-tool/download/
I'm currently at 820 Mb (55%) of the download. Transfer rate here in the midwest, US is 126Kb/Sec.
SuperSaf
Post by SuperSaf »
I'm having more problems trying to transfer the damn image from one computer to another! Transferring through network, should be done in a few minutes hopefully :)
off out to play darts now guys keep posting your progress if you can chums
FyodorNinian
Post by FyodorNinian »
Can somebody please recommend a torrent program for windows - haven't used torrent for years. Thanks :-)
Edit: I've downloaded uTorrent. Seems to be fine. :-)
I just googled an online torrent program and found one. I'll post the file to Hotfile and Rapidshare shortly.
I'm at 1.33 Gb on my download of 1.50 Gb.
Dan, I used to play darts in the 1990's. Enjoyed the game. I was referred to as a "sight shooter". Here though we can only play with plastic tipped darts.
SuperSaf
Post by SuperSaf »
I've got it, imaged it to an 8GB using win32imager.
BUT it doesn't work :( Put USB in, plug power in and the O2 boot logo comes on, takes a little longer than usual I think, then goes straight into the normal O2 software.
Any help? Did you have it connected to a hub? any extra info please?
Hope you have better luck Pete! Let me know how you get on. Mine downloaded at exactly the same speed, they cap it ridiculously low for free users!
SuperSaf wrote:I've got it, imaged it to an 8GB using win32imager.
I downloaded this at the same speed as you guys. I just used Win32Imager to pop it on an 8Gb mini HP stick, stuck it in the Joggler and away it went first time!
FyodorNinian wrote:Can somebody please recommend a torrent program for windows - haven't used torrent for years. Thanks :-)
Personally I've never had any problems with uTorrent.
markeh
Post by markeh »
arse it's not working for me either
probably the usb - sandisk cruser blade thing 8gb, worked with android and linux with joggler though
SuperSaf
Post by SuperSaf »
markeh wrote:arse it's not working for me either
Same here. Thought it'd probably the USB but Android and Linux worked fine...
I'm giving the imaging another go. Instead of win32imager, using dd on mac instead this time. Second time lucky :) Not got anything else to put it on if it doesn't work :(
