SqueezePlay OS + XBMC on emmc...
Re: SqueezePlay OS + XBMC on emmc...
Turned on SSD booting Openframe 1 with PATA port.
It is using an Ayava boot EFI bios. (which has the PATA boot stuff). I think I had issues though.
Note that its been a while since I have looked at it.
Boot directory is:
:~# cd /boot
boot# ls
boot.nsh
grub.efi
System.map-3.2.58joggler1
config-3.2.58joggler1
initrd.img-3.2.58joggler1
unicode.pf2
grub.cfg
startup.nsh
vmlinuz-3.2.58joggler1
boot# fdisk -l
Disk /dev/sda: 16.4 GB, 16391208960 bytes
255 heads, 63 sectors/track, 1992 cylinders, total 32014080 sectors
Disk identifier: 0x00056e1a
/dev/sda1 * 2048 126975 62464 e W95 FAT16 (LBA)
/dev/sda2 126976 626687 249856 82 Linux swap / Solaris
/dev/sda3 626688 32012287 15692800 83 Linux
boot# cat grub.cfg
loadfont /unicode.pf2
terminal_output gfxterm
set timeout=5
menuentry "Xubuntu 14.04 LTS (Trusty) - 3.2.58joggler1" {
linux /vmlinuz-3.2.58joggler1 root=LABEL=linux-root ro quiet splash
initrd /initrd.img-3.2.58joggler1
