joggler@joggler:~$ sudo lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation System Controller Hub (SCH Poulsbo) [8086:8100] (rev 07)
Subsystem: Intel Corporation Device [8086:8119]
Flags: bus master, fast devsel, latency 0
00:02.0 VGA compatible controller [0300]: Intel Corporation System Controller Hub (SCH Poulsbo) Graphics Controller [8086:8108] (rev 07) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d0200000 (32-bit, non-prefetchable) [size=512K]
I/O ports at f070 [size=8]
Memory at c0000000 (32-bit, non-prefetchable) [size=256M]
Memory at d0280000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at <unassigned> [disabled]
Capabilities: [d0] Power Management version 2
Capabilities: [b0] Vendor Specific Information: Len=07 <?>
Kernel driver in use: gma500
Kernel modules: gma500_gfx
00:1b.0 Audio device [0403]: Intel Corporation System Controller Hub (SCH Poulsbo) HD Audio Controller [8086:811b] (rev 07)
Memory at d02c0000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation System Controller Hub (SCH Poulsbo) PCI Express Port 1 [8086:8110] (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: d0100000-d01fffff
Prefetchable memory behind bridge: fef00000-feffffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [90] Subsystem: Intel Corporation Device [8086:8119]
Capabilities: [a0] Power Management version 2
Kernel driver in use: pcieport
00:1c.1 PCI bridge [0604]: Intel Corporation System Controller Hub (SCH Poulsbo) PCI Express Port 2 [8086:8112] (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: d0000000-d00fffff
Prefetchable memory behind bridge: 80000000-801fffff
00:1d.0 USB controller [0c03]: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #1 [8086:8114] (rev 07) (prog-if 00 [UHCI])
I/O ports at f040 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller [0c03]: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #2 [8086:8115] (rev 07) (prog-if 00 [UHCI])
Flags: bus master, fast devsel, latency 0, IRQ 17
I/O ports at f020 [size=32]
00:1d.2 USB controller [0c03]: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #3 [8086:8116] (rev 07) (prog-if 00 [UHCI])
Flags: bus master, fast devsel, latency 0, IRQ 18
I/O ports at f000 [size=32]
00:1d.7 USB controller [0c03]: Intel Corporation System Controller Hub (SCH Poulsbo) USB EHCI #1 [8086:8117] (rev 07) (prog-if 20 [EHCI])
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at d02c4000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci-pci
00:1e.0 SD Host controller [0805]: Intel Corporation System Controller Hub (SCH Poulsbo) SDIO Controller #1 [8086:811c] (rev 07) (prog-if 01)
Memory at d02c4600 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: sdhci-pci
00:1e.1 SD Host controller [0805]: Intel Corporation System Controller Hub (SCH Poulsbo) SDIO Controller #2 [8086:811d] (rev 07) (prog-if 01)
Memory at d02c4500 (32-bit, non-prefetchable) [size=256]
00:1e.2 SD Host controller [0805]: Intel Corporation System Controller Hub (SCH Poulsbo) SDIO Controller #3 [8086:811e] (rev 07) (prog-if 01)
Memory at d02c4400 (32-bit, non-prefetchable) [size=256]
00:1f.0 ISA bridge [0601]: Intel Corporation System Controller Hub (SCH Poulsbo) LPC Bridge [8086:8119] (rev 07)
Subsystem: Intel Corporation System Controller Hub (SCH Poulsbo) LPC Bridge [8086:8119]
Flags: fast devsel
Kernel driver in use: lpc_sch
00:1f.1 IDE interface [0101]: Intel Corporation System Controller Hub (SCH Poulsbo) IDE Controller [8086:811a] (rev 07) (prog-if 80 [Master])
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [size=1]
I/O ports at f060 [size=16]
Kernel driver in use: pata_sch
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 02)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller [10ec:8168]
Flags: bus master, fast devsel, latency 0, IRQ 40
I/O ports at e000 [size=256]
Memory at fef10000 (64-bit, prefetchable) [size=4K]
Memory at fef00000 (64-bit, prefetchable) [size=64K]
Expansion ROM at d0100000 [disabled] [size=64K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/2 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=2 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Network controller [0280]: Broadcom Corporation BCM43225 802.11b/g/n [14e4:4357] (rev 01)
Subsystem: Broadcom Corporation Device [14e4:04db]
Flags: fast devsel
Memory at d0000000 (64-bit, non-prefetchable) [disabled] [size=16K]
Capabilities: [58] Vendor Specific Information: Len=78 <?>
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [d0] Express Endpoint, MSI 00
Capabilities: [13c] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-ff-ff-29-78-e4
Capabilities: [16c] Power Budgeting <?>
