Poll : What OS are you running?
What OS are you running on your joggler(s)?
Stock O2 OS
66
31%
Ubuntu
53
25%
Mint Linux
10
5%
Android 2.2
42
20%
JoliOS
11
5%
Meego
0
No votes
Other
32
15%
Total votes: 214
Mc-Po
Re: Poll : What OS are you running?
Post by Mc-Po »
Sorry, shoudlve check first
God this place is still quite active, I wouldve though it would have died by now
Old Post
At the moment Android is the most stable, JoliOS, burnt the joggler up within second of being turned on, and would crash if you tried to do anything.
Im wanting to try Meego, Is the one on the wiki
http://www.jogglerwiki.com/wiki/MeeGo
Still the latest
Also is the one there Handset UX or notebook.
Need something to play Grooveshark, as Opera/Android doesnt support Flash and the Full flash version of grooveshark has been removed
jolios runs fine. I use it one two jogglers. You just need to read about throttling. it's not jolios burning up the joggler, it's just that jogglers run hot and have a throttle temp that is too low considering the lack of cooling. increase this and it works nicely.
one mint user? well I suppose I should release the new linux mint I have almost ready then :)
Make that 2 Mint users. I play around with all the images and don't stick to a single distro. In my house the Joggler OS preferences are:
Wife: stock Joggler OS
Myself: Ubuntu or Mint or JoliOS - I tend to use Ubuntu most of the time but use Mint a lot when I'm trying out new things. I'm more familiar with Mint because I use it on my PC (I'm a convert from OpenSuse) so when I have everything working as I want in Mint, I transfer the knowledge to Ubuntu. My only reason for preferring Ubuntu on the Joggler is to give myself more Linux experience outside the Mint environment. I like a lot of web apps on JoliOS too and boot into that for particular tasks.
My kids: JoliOS or stock Joggler OS
As you can see, I would have chosen more than 3 distros if the poll had allowed - and Mint would have another fan at least.
P.S. I'm still tinkering with Android too but only occasionally. It's more of a toy than a toolbox to me at the moment.
aamp
Post by aamp »
JoliOS and testing Android
maloney
Post by maloney »
Hi all,
My wife & 2 year old like the Joggler OS, just for the radio and iplayer apps. (I find it both incredibly scary and amazing that my 2 year old knows to hit the iplayer app and then the cbeebies channel, sign of the times i suppose!)
I've had abit of tinker with Ubuntu. But that's about it really. Having read through this thread I think I might try JoliOS and Mint out sometime.
I've been following the Android threads and really fancy giving that a go - just a shame it doesn't handle Flash.
I'm a long time lurker here, but just wanted to register to pipe up and say how much i appreciate everyones efforts and work so far.
windows xp!
show-off!
lol sorry i got excited, wont happen again promise
roobarb! wrote:If I get time at some point, I'd like to give JoliOS a bit more of a test. I've messed about with it on the web a little, but I really don't think I've 'clicked' with it yet. But I keep coming back to it...
Click! Joli OS is the one for me, I think! More finger-friendly than Ubuntu's Gnome desktop, the simple launcher-style interface is great, with some nicely redesigned file browser elements and better support for smaller screens. Can't believe I neglected it for so long!
inzimam
Post by inzimam »
Hi roobarb,
are there any things that you can't do on JoliOS?
Also is the squeezeplayer as updated as the one for the native one?
inzimam wrote:are there any things that you can't do on JoliOS?
Nope, Joli OS is Ubuntu with a different UI on it, so you get all of their web apps as well as access to anything you install locally. Local apps are in a separate folder on the interface, but that's it. SqueezePlay is installed and works in the same way as Ubuntu, but appears under the Local Applications -> More Apps folder, IIRC. You can choose to move it 'up' into the Local Applications folder using the interface, but, in this version at least, you can't have it side-by-side with the webby ones.
So far as I know...
yeh such apps can only appear there, and there is no way to get them onto the main menu. perhaps with the next version of jolicloud (the interface not the os), they will do something about that. still, two clicks isnt the end of the world :)
inzimam
Post by inzimam »
Thanks roobarb
I will give it a go tonight.
Just one question about the audio config file I need to change to get sound out of the USB, is this a local file and not part of the memory stick with Joli. As in, if I were to ammend the file on the native OS, will i still have sound out of the USB when using JoliOS?
You need to add the file to the stock OS AND the stick if you want USB sound from both.
Also, on the stick make sure to choose the USB card as the default sound output in the sound preferences. Even though I'd added the modified asound.conf file, I was still getting sound through the 3.5mm socket until I chose the correct card.
XP Pro SP3!! :D
Ditto XP Pro SP3
Mevi wrote:XP Pro SP3!! :D
Windows. It's just wrong. ;)
Yeah but what other device can you load four (3) different Operating systems?
The "ultimate" little PC; Joggler...who would have thought that?
I remember "playing" with the Amiga and running Helios on it showing a friend how easy it was.
It ran circles around first gen Windows; even IBM's OS2 warp was nicer than Windows 95...
Whoa; showing my age here now....geez forgot I'm a grandpa now....
rapunzel
Post by rapunzel »
windows xp
