PNPIII - trying to get NAS mounted for LMS - SUCCESS!!
Re: PNPIII - trying to get NAS mounted for LMS
I read somewhere that there has to be a 'dummy' location - it could be called anything. Very strange syntax!
Yep - can confirm the mount works in that boot file!
May be the way to go!
Hmmm, it doesn't return an error or confirmation but neither my command promt:castalla wrote:SUCCESS!!!!!
Ignore all above!!!!
Here's the command you need to mount the fileshares .....
mount -t cifs Muziektest /media/media/media-share1 -o user=Joggler,password=Joggler,unc=//192.168.0.13/Muziek
This should just return the command prompt. No errors or confirmation.
When i <ENTER> the code the cursor moves 1 line down but nothing else happens. I can type whatever I want but nothing happens.
login as: joggler
joggler@192.168.0.12's password:
# mount -t cifs Muziektest /media/media/media-share1 -o user=Joggler,password=Joggler,unc=//192.168.0.13/Muziek
ls
ks
ls
Oh buggeration!
Type cntrl-c - or try exit
Try
mount -t cifs Muziektest /media/media/media-share1 -o user=Joggler,password=Joggler,unc=//192.168.0.13/Public
Try
Make sure the command is all on one line -
Also, give it a minute or so to complete - depends on how many files you have on the NAS
Arrggghhhh!
yeah i noticed something indeed, after a while i did see the command promt again??? So it might just have succeeded?? Because of the extra caracters I exited putty, enter it again and do the first mount command again. I now lack the command prompt, just like earlier.castalla wrote:Make sure the command is all on one line -
Also, give it a minute or so to complete - depends on how many files you have on the NASCode: Select all
There are 218 folders with 3830 Music files. How long should that normally take?
I've got only 1000 tracks on my share - the command returns the prompt almost immediately.
However, I also note that I have to use the top of the share tree to get access -
So, 192.168.1.1/share works but 192.168.1.1/share/usb1_1 (which actually contains the files) doesn't
The only way we can test the Seagate nas is to install the Squeezeplay OS (on a usb stick), then we'll get a 'standard' linux where we can use the mount command (without all this Busybox stuff!).
I suppose we could try the command using
/bin/busybox.new mount .....
I hate to be defeated on this!
It could just be a slow read!
Please do
ls /media/media/media-share1
Anything listed?
If nothing, reboot the Joggler - enter the command again - let it run until you see the prompt.
Then do the ls
Please do
Anything listed?
Then do the ls
yes I'm trying that, letting it rest until I see the command prompt again. So far without luck.
Hm bad luck. no # yet..
I have to go to bed.. it's one o'clock now here
tomorrow my kids..... you know...
Thanks for all the help to this point! I really appreciate it.
login as: joggler
# Muziek
-sh: Muziek: not found
Did you do
yes did do that and it returned the prompt. So no read files I suppose?
So, just to be clear - you did the mount - you got the command prompt back after a while, without any error message? Then the ls returns nothing?
Okay ...
Let's try again tomorrow .
No problem.
No problem.
Let's try this;
Reboot
login
DO
mkdir TEST
mount -t cifs Muziektest /TEST -o noperm,user=Joggler,password=Joggler,unc=//192.168.0.13/Muziek
Wait for command prompt
ls TEST
Reboot
login
DO
mkdir TEST
ls TEST
Well I have to reflash from the beginning again because it hangs at the O2 logo.......
What's wrong with this thing!
Nah I don't think there is anything wrong. The O2 Joggler is very resilent. Literally was developed and designed not to break.
The boot flash 1 Mb chip is replacable. The constant RW's though on the 1Gb flash could cause issues.
still waiting but is doesn't return my command prompt?castalla wrote:Let's try this;
Reboot
login
DO
mkdir TEST
ls TEST
@error
If you are prepared to test it out. We need to see if the problem is at the Seagate ....
The quickest way to test this would be to use the SqpOS on usb method. This will boot the Joggler to a version which uses a standard linux where we can test the mount command. Doing this will leave the PnP in place. Everthing runs from the usb stick.
If you want to try this: write the image to a usb stick - http://birdslikewires.co.uk/download/jo ... 109.img.gz . Extract the .img file and write to usb.
Restart the Joggler with the new usb in place - it will boot to the SqpOS - go to Settings and set up the wifi AND then Settings > Advanced > Additional Features to enable SSH login.
Don't bother with any other settings at this point.
Check that you can PuTTY login - joggler + joggler. Once you have terminal access, simply type:
sudo mkdir /srv/TEST
If you can confirm you have access, then we can try out a mount of the NAS again using the normal mount syntax:
sudo mount -t cifs //192.168.0.13/Muziek /srv/TEST -o user=Joggler,password=Joggler
Wait for prompt
if it doesn't work, then do
sudo mount -vvv -t cifs //192.168.0.13/Muziek /srv/TEST -o user=Joggler,password=Joggler
This should return the various steps it tries to mount - maybe there's a clue there?
Wait for prompt
I noticed the following on the server:
Workgroup
Mode: [x] Workgroup [] Domain Member
Workgroup Name: WORKGROUP
Does that have anything to do with the Joggler not getting access?
Will try the sqpOS-on-a-stick-solution as soon as i have time to do that.
I will get back.
Workgroup
I will get back.
