Coreboot and SeaBIOS
inaxeon
Re: Coreboot and SeaBIOS
Post by inaxeon »
danfoshizzle wrote:what version of the rom you guys using?
Oh oh. I've actually been looking forward to the day when someone would finally ask this question of someone.
Dan: There is only one version that has a chance in hell of booting W7: 0.4 and that's the last one I uploaded. Have you not been following this thread? :P
Dan, The one that inaxeon just posted a few minutes back (don't know really know cuz I am in chicago right now) and I just logged on to the forum.
I thought it was updated this morning from yesterday's post. Apologies. I updated the ROM again from the link a few minutes ago.
I have acopy of win 7 that has been slimmed alot. Imade it a while ago.
going to give it a go in a minute lol
been following must have missed it :)
Just wrote a "tiny7" installation ISO to the boot stick and replace the ZIF with an SSD USB stick. Started but graphics are looking a bit wierd; but I see them anyways.
Just finding the slimmed win 7 in my archives, then will proceed with pwboot, onto a 250gb usb hard drive. its quite fast too this drive, around 40mbps, so should run ok!
The only time I have managed to get things booted fully was on a PWBooted HDD that had already been fully installed and booted to the desktop first on another machine.. My first attempt was with the USB keyboard/trackpad. No boot, getting as far as disk.sys in safe mode. Without the keyboard plugged in, it boots as far as the 'please wait', much further. I'm leaving it for a while as there are intermittent disk access flashes.
inaxeon
Post by inaxeon »
Mevi wrote:The only time I have managed to get things booted fully was on a PWBooted HDD that had already been fully installed and booted to the desktop first on another machine.. My first attempt was with the USB keyboard/trackpad. No boot, getting as far as disk.sys in safe mode. Without the keyboard plugged in, it boots as far as the 'please wait', much further. I'm leaving it for a while as there are intermittent disk access flashes.
I think we're all stuck on the same problem here. I'm looking into it.
pete_c wrote:Just wrote a "tiny7" installation ISO to the boot stick and replace the ZIF with an SSD USB stick. Started but graphics are looking a bit wierd; but I see them anyways.
Tiny7 has no tablet pc stuff in it so touchscreen probably won't work
Just trying an install onto the pata ssd, so far its going OK. (FINGERS CROSSED)
Well giving it another few more minutes, itdid get to the desktop, however it failed to create the desktop, start the server services and no page file, probably due to the 'size' of the vanilla Win7 I'm using, no slimming. Oh, no warm boot either. Is that last item due to acpi?
Thanks mickchip.
Yes; so removed the SSD drive from the Asus Netbook. (Originally just disabled it but easy to take out).
Connected the USB ZIF drive to it and booting right now with the fully loaded do all W7 configuration disk.
Will build it on this Asus connected ZIF drive then copy over the boot disk to a directory on the same ZIF drive and try that while inaxeon looks at the "issue".
inaxeon
Post by inaxeon »
PATA is where it's at. My Joggler is working awesome from PATA. Not to rub it in or anything but I even ran the full install process onto PATA - no problems at all.
inaxeon
Post by inaxeon »
Not that it's hugely relevant but...
Dan/Mevi - If you want PATA ports on your Jogglers, feel free to post a Joggler to me and I can fit one, no probs...
Yep I agree, takes a while though mine is just onto finalizing your settings.
inaxeon
This reminds of of the services provided by the old linuxhacker site many many years ago.
So if I posted a Joggler over to you from Chicago; could you fit a pata on it too? Probably could just send the motherboard sans case, etc...
inaxeon
Post by inaxeon »
pete_c wrote:inaxeon
Not likely. The return postage would be killer. That and, Royal Mail would probably make me pay VAT on it.
There must be a lot settings to finalize it's been doing it for 10 minutes
edit were now on to preparing the desktop
That could be a way forward, would you mind if I sent just a motherboard lol
inaxeon
Post by inaxeon »
danfoshizzle wrote:That could be a way forward, would you mind if I sent just a motherboard lol
If you don't mind unsoldering all of the other stuff attached to it, that'd be better
If its a better way, then why not, anyone know of a source of cheapish pata hard drives/ssd's?
inaxeon
Post by inaxeon »
I use this:
http://www.ebay.co.uk/itm/New-Sandisk-S ... 43aedcd2a9
mickchip is using an almost identical 16GB SSD.
The ribbon cable supplied with that would be useless though. You need a flat cable, that one is a rollover.
mickchip: Your input here? I'm using ribbon cables I already had. Where did you get your ribbon cable. Did you use a top contact or bottom contact FPC connector?
