I know what you've done. You've written the MMC version of SqueezePlay OS to a USB stick and are trying to boot from it, aren't you? That won't work - you need to write the Reflashing Tool (see sig) to the USB device, then follow the instructions on writing an alternative OS to internal memory (basically, just copy the sqpos105mmc.img.gz and sqpos105mmc.img.gz.md5 to the reflash directory that you'll see).Fishy wrote:Hello again - thanks for quick response and warm welcome to the forum.
Error messages - On boot up it says the following amongst others in this order (please bear in mind this list isn't comprehensive and it does scroll very quickly but hopefully can give you an indication of how far it gets before looping)
No DMI BIOS year
Cannot read MAC address
Wifi - it makes 5 attempts, each with ipconfig SIOCGIFFLAGS - no such device wmm
ra0 no private ioctls
DHCP - another 5 attempts
Mongoose started
Then super rapid scrolling with brief breaks where you can only read a couple of words!
Amongst these I have seen Fatal Server Error and giving up !!!
What's happening at the moment is that sqpOS's boot system is trying to boot the original operating system from the internal memory - which fails for numerous reasons.
Use the Reflash Tool to write sqpos105mmc.img.gz and you should be good to go.
