Re: PnP III: Enhance the standard OS - DOWNLOAD IT HERE!
actually the New York thing has stopped, maybe just a default if no file present?
it seems to work ok, so is the modified second line just it's way of showing the last shown location?
Yes, it seems to default to New York if you mess up the xml. Glad it works fine.
Thanks. I've attached the icon and script for the ad-blocker if you wish to use it.offbeatdave wrote:Yeah. Will try to find time to look at this during the week. My focus is currently delving into the workings of Android systems at the moment but you've done all the hard work on this - thanks! It won't take me long to pop this in if you want it.
- ad-block.zip
- (11.97 KiB) Downloaded 508 times
Wow! Thanks. Will look at this soon!
Thank you, Accuweather fix working great!
Hello
Is it possible to exit Squeezeplay but leave it running in the background? If so, how?
Yes. You need squeezelite. Search this thread-it's in here somewhere!smythey wrote:Hello
I can't get squeezeplay to update to v.1.58 in pnpIII - tried both the most recent version and an older version of pnp. Has something fundamental changed?
Edit: update to v1.59 worked fine.
Last edited by ilovemyjoggler on Fri Nov 07, 2014 5:25 pm, edited 2 times in total.
Any chance of an update please with the Accuweather fix included? I realise you're busy, but this would save me having to dig out the vi hack every time my Joggler needs a reflash! Thank you.
Sorry I haven't had time to implement any of the fixes detailed above into PnP III.
I'm afraid life (work, kids, other techy projects, eating, sleeping etc) is rather occupying my...erm...life at the moment. I still keep an eye on this forum to see what folk are getting up to with their Jogglers. I honestly don't know when the next tweak of PnP will be arriving though. Heck, I haven't even gotten around to updating two of my Jogglers to sqpOSv3 yet!
Loving all the tinkering that is still going on though!
anyone know if the iplayer app can be fixed? I have ubuntu base with xbmc working for iplayer radio/tv catchup but not llive feeds. I would really like to have it working under the o2 apps - anyone got any ideas?
Is it also possible to run PNPIII of an USB stick? Instead of writing the image to the Joggler itself?
No it is not possible unfortunately
Hello there: I have a problem with the clock. It's not able to sync with the time server after install PNPIII. It was ok when in the clean 30300 version. How can I fix this problem? Thanks
Hmm. Not sure why there's an issue. Syncing after a reflash here. Sorry - I know that doesn't help.
Is it possible to install upnp in the squeezeplay os? Thanks
No. But why would you need it? Essentially, squeezeplay OS gives you a squeezebox player which then connects to Logitech Media Server which then provides access to music libraries and internet radio services, etc.cszhy wrote:Is it possible to install upnp in the squeezeplay os? Thanks
Actually I don't know how to access the hard disk which connected with the router as my media server through LMS , is there any guide for that?castalla wrote:No. But why would you need it? Essentially, squeezeplay OS gives you a squeezebox player which then connects to Logitech Media Server which then provides access to music libraries and internet radio services, etc.cszhy wrote:Is it possible to install upnp in the squeezeplay os? Thanks
What file system is there on the disk? Fat, nfs, etc. ???
Also, what device is running LMS ?
