Well I can only think of this, which I have not tried on a legacy installation
viewtopic.php?f=2&t=5141
I mostly use external sticks (for the OS) nowadays and a usb hub if I want to use an external usb DAC.
ronnie
dan1502
Post by dan1502 »
Thanks. Weirdly, I just turned it on in the order I usually do and it worked. I'll see how it goes.
shadow1901
Post by shadow1901 »
Hi all
I have unfortunately not managed to install Squeezeplay with the instructions so far. Is there a detailed guide? My problem so far is that I run of-install squeezeplay, but after the reboot there is only a black screen. When I log in via putty and start Squeezeplay, it opens, but the touch does not work afterwards. I have the Joggler with built-in speakers. The goal would also be to write it to the internal memory. If I do that, I get the same errors as from the USB stick.
If I use the Squeezplay OS, the problem is that at the beginning of the setup, it wants to connect to the server, which no longer exists. Couldn't the OS be adapted or a version created that runs?
Thanks for the help.
shadow1901 wrote: Wed Dec 18, 2024 9:40 am Hi all
Which OS versions are you using ?
shadow1901
I used bullseye but the same problem with bookworm
I don't know what to suggest
If you have tried three different OS, Bookworm, Bullseye and SQPOS and none work, something must be wrong, but I have no idea where the error is situated.
Is the Squeezeplay available as a player in your local server (time to update to LyrionMusicServer, although should not have any effect)
If you want to trouble shoot, you need to stick to one OS and describe exactly what you do
ronnie
shadow1901
Hi Ronnie
The only one that should work is SQPOS but at start they want connect to the Squeezebox Server.
I used always the images from roobarb!
The best solution for me should be the SQPOS -> https://birdslikewires.net/squeezeplay-os
I doesn't use an LMS Server at home. My goal is that I can use my OF2 device as an internet radio with clock functions
shadow1901 wrote: Wed Dec 18, 2024 4:21 pm Hi Ronnie
For nearly a year now it has not been possible to use mysqueezebox dot com
If you want to use Squeezeplay you have to run the LyrionMusicServer somewhere on your network
Cheapest option is a slim client computer or a raspberry pi.
ronnie
shadow1901
thanks for answer
So its possible that I can install "LyrionMusicServer" direct on SQPOS with putty and apt get install?
shadow1901 wrote: Wed Dec 18, 2024 4:52 pm thanks for answer
NO
This was possible at one time but was always 'flaky' and very slow in operation
If your joggler has 1GB ram there is not enough room
If your joggler has 2 GB ram then it is, in theory, possible, but whenever I have tried to expand the filesystem (sudo of-expand) it has failed.
shadow1901
the expand doesn't work, I know
Here's the space:
joggler@openframe:~$ df -h
/dev/mmcblk0p2 1.9G 401M 1.4G 23% /
udev 246M 4.0K 246M 1% /dev
none 192M 20K 192M 1% /tmp
tmpfs 100M 356K 99M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 248M 0 248M 0% /run/shm
none 256M 0 256M 0% /var/cache/apt
none 256M 0 256M 0% /var/lib/apt/lists
none 16M 404K 16M 3% /var/log
/dev/mmcblk0p1 31M 10M 21M 33% /boot
But after step welcome the want connect to Libraries.
Its not possible this feature to disable?
shadow1901 wrote: Wed Dec 18, 2024 6:17 pm the expand doesn't work, I know
Here's the space:
I can't answer that question
It was possible to use the Ubuntu imager on a usb stick, put it into the joggler and boot from that.
https://jwills.co.uk/projects/joggler-xubuntu/
Then install gParted and use that to expand the files system on the internal ram
I did this over 12 months ago but when I tried it earlier this year it did not work
sixedup
Post by sixedup »
shadow1901 wrote: Wed Dec 18, 2024 6:17 pm But after step welcome the want connect to Libraries.
I used to run SQPOS on the internal flash of my Jogglers, but they were becoming increasingly unreliable as that image was over a decade old, and many things have changed in that time (including the closure of the public MySqueezebox servers, software fixes, etc). To upgrade them, I replaced SQPOS with Debian Bullseye and a more recent version of Squeezeplay. It provides a good SqueezePlayer OS replacement.
In terms of step by step instructions for installing the software on the Joggler, these are the instructions that I followed. They were intended for Joggler with a USB-connected DAC, but should still give you a good starting point. Read through the instructions and make sure you're comfortable with them before you start!
I'd suggest avoiding Bookworm if you intend to install on the Joggler's internal flash, as the install of Squeezeplay and its graphics dependencies run out of memory on Bookworm, and fails to complete. You then have to fix the partially installed software manually, which is not fun.
Finally, don't forget that you will still need a version of Lyrion Music Server installed somewhere on your network too. Using something like a Raspberry Pi 3 and a USB key (to hold your music) should be fine to get you up and running, though if you have a very large music collection you may need something with more storage space.
shadow1901
I have installed everything.
I was even able to enlarge the partition.
My biggest problem is that after the off-install squeezeplay, it does not start after reboot.
Only the prompt appears.
So far, I haven't figured out how to get it to start automatically.
It would also be cool if there is a variant where I can plug in the USB stick and then it installs everything automatically.
Just like in the past with SQPOS with the reflash.
I have the LMS running on my Synology NAS in Docker.
Although, I could try to install it on the internal memory as well.
I did expand it.
Here are the instructions on how I did it:
sudo apt update
sudo apt install -y parted
sudo parted
resizepart 2 100%
quit
sudo resize2fs /dev/mmcblk2p2
sudo reboot
PS: Just so you know, it doesn't work for me with of-update...
It can't find the program.
