ICS X86 Source Out!
Re: ICS X86 Source Out!
When peeps have said edit the grub to lang =eng how do you do that ?
Do you need a program to open or edit the grub file ? When I click on it nothing opens .
Probably me being a noob lol but would be greatful for any help
johnnygal
Post by johnnygal »
Just open it with any editor e.g. notepad, wordpad, vim. It's the grub.cfg file. It currently has lang=zh. Change the zh to en. Windows probably doesn't have any default program assigned to .cfg files. Open your editor, then goto File->Open and browse to the grub.cfg file.
tangye
Post by tangye »
Unfortunately I couldn't get it to work. Just hangs on the following screen:
Any thoughts?
Are you using a hub?
tangye
Post by tangye »
No - not using a hub. The joggler does have plug n pimp on it though (in case that makes any difference).
Does the stick you are using work with Buzz's images or the 1.2.3 android image?
I know this is a work in progress so just a few observations
Wireless keyboard an mouse offof revo ,keyboard fine,mouse not working.
Bluetooth dongle not recognised so not working (the above are ok on 1.2.3)
Usb hub working fine
Audio out muting main speakers and working fine .
Thats it for now ;-)
tangye
Post by tangye »
The stick works for Buzz's images and the 1.2.3 android image.
hmmm so i used the hp utility to sort out my stick and format with fat32 and then the file i downloaded i extracted straight to the stick ...
When I get a moment, I'll check it on the other Jogglers and see if internal Flash makes a difference. I can re-flash the O2 Joggler that it wouldn't boot on and see if boots ICS afterwards.
If buzz's images work this should also. I would try redownloading both the files, first the 99mb file should be written to the disk and then the extracted easy package, merging folders if asked
johnnygal
Post by johnnygal »
hawsey wrote:I know this is a work in progress so just a few observations
Bear in mind this image is not produced by anyone on this forum, so maybe best posting on Mijuu's blog (http://tinyurl.com/7v6ugxu)
tangye
Post by tangye »
danfoshizzle wrote:If buzz's images work this should also. I would try redownloading both the files, first the 99mb file should be written to the disk and then the extracted easy package, merging folders if asked
Ok so unzip the "ICS_Joggler_4.0.3_Alpha.zip" file first, then the "Easy_to_use_package_Usbdisk(ICS).zip" file.
So this means the grub.cfg file that will be left on the USB stick will be the one from the "Easy_to_use_package_Usbdisk(ICS).zip" file, as that file is unzipped last. Is that correct?
Cheers johnnygal ,
Might just do that but am a bit feared that google translate might be disrespectfull in the mix :-) some of the translations we get are a bit strange to understand this end lol .
I know mijuu is still working on this so it was just observations really .
Here's to the next build
Mijuu is a top bloke for doing this
Happy joggling
Ahaaaa that's better , language set to english , wireless , browser etc retaining settings.
I was only using the ics image and not the easy installer one !!
Thanks for the help with editing the grub to set to lang=en :D when I tried notepad it was just jibberish so I opened with word and it all became clear .
Just having probs now with the market that comes installed , any advice on installing the market would be great
Thanks in advance
Yeah that sounds about right
belrik
Post by belrik »
Hey there, anyone got the market working yet? Currently loading stuff with ES file explorer from a LAN share....
I must say, the release seems good so far and very easy to set up. Congrats :)
Simple instructions for everyone, just load up a command line or gparted and create the following partitions on your usb drive:
/dev/sdX1 - your boot partition, fat32 350MB (dump all the files from the large release zip in here)
/dev/sdX2 - your data partion, ext4 1gb+
/dev/sdX3 - your SDCARD partion, fat32 as big as you like.
Then just edit grub.cfg on /dev/sda1 to change lang=en.
Simple!
tangye
Post by tangye »
OK, I finally got this to boot by doing the following:
- Formatted the USB stick using the HP format utility,
- Unzipped the "Easy_to_use_package_Usbdisk(ICS).zip" first,
- Then unzipped the "ICS_Joggler_4.0.3_Alpha.zip" file second, and over wrote the grub.cfg file.
This way, the grub.cfg file that ended up being on the USB disk was the one from the "ICS_Joggler_4.0.3_Alpha.zip" file.
Funnily enough, the joggler will only boot off the USB stick on every second reboot. Weird....
Anyway, I just wanted to say a big thanks to everyone for helping me to get this working.
DaveJoggler
Post by DaveJoggler »
tangye wrote:OK, I finally got this to boot by doing the following:
Pretty sure you should be doing the 'Alpha' followed by the 'Easy' zip. The grub from the 'Easy' refers to the img files for the sdcard etc.
That is what I did, from the mijuu instructions. Do you have an sdcard showing in the storage section on ICS?
tangye
Post by tangye »
There was no SD card showing in the storage section. I'll try again using the order you mentioned, and see if an sdcard shows up .
