Plex Media Server on the joggler
Re: Plex Media Server on the joggler
I guess you are referring to
echo 'deb http://plex.r.worldssl.net/PlexMediaServer/ubuntu-repo lucid main' >> /etc/apt/sources.list.d/plexmediaserver.list
From what I can tell, the plex.r. server isn't working or doesn't exist !
On fact, I've no idea why his line is necessary
Did the dpkg line go okay - no errors
If so try the service start line
Sorry yes but it didn't work , so I backtracked and I noticed I hadn't re named my sources file to take the .txt off and rename to .list , I've done that now and ran the update and its worked now .
Thx
Sent by SlimKat FirePhone
So - it seems to have installed okay?
I sthere an easy way to test it's working?
Not quite there yet ,using the link i previously posted it seemed to be installing but unfortunately i got an error "dependancy problems prevent installation of plexmediaserver " then something about avahi utils which i thought i already installed ....
Tomorrow is anouther day ;-)
Fresh head in the morning .
Thanks for all the help .
Hmm ... the old dependency hunt!
You could end up chasing your tail as you resolve one issue as another appears!
I tried a simulated install of avahi-utils - went okay, no errors.
I suspect it's all bound up with that huge package list - which you may need to install.
Nothng to lose - I'd copy that list carefully, then paste into putty and hit the return key. Wait until it finishes. Then run the dpkg again.
SUCCESS 8-)
Thanks again everyone who has had input with this , you know who you are ...
So I did the avahi utils thing then went back to try and install plex using these instructions
The mistake (or one of them ) I was making was the # at the front of each instruction was already there and I was just copy and pasting so once I dropped the # all went well .
I logged in to the newly installed PMS via the web server on my tablet and skipped sign in , my already mounted music folder came up and I pointed it to that .
At this point I left it working and went for some zzzzz .
This morning I installed the trial version of Plex app on my Android phone and all seems to be good , no skipping or freezing up of tracks .
One of the first things it said on my phone was plex server needs updated for certain features to work so this will probably be because of the old guide I used ; I will try and update that today if I can work out how , would the update all thing we did earlier work ?
I do need to try and access my stuff outside the house though , and will do that before buying the full version of the app .
Oh and the Squeeze play Os is still working on the same Joggler , I just checked that .
All looking good :-)
Excellent!
Oops I didn't even see the hash - it really just means 'type the following at the command line', that convention is not commonly used.
It's also used to indicate comment lines in scripts.
Updating - it should just work. To update you need a later plex file - see below for instructions, each on a new line
service plexmediaserver stop
wget https://downloads.plex.tv/plex-media-server/0.9.16.4.1911-ee6e505/plexmediaserver_0.9.16.4.1911-ee6e505_i386.deb
dpkg - i plexmediaserver_0.9.16.4.1911-ee6e505_i386.deb
service plexmediaserver restart
The plex above is the latest (22 april 2016)
Cheers :-)
painting kitchen today , will try at some point , thank you kindly sir .
Enjoy! Need to do the same, but ......
It says I need 9.12.3 or newer so that will be fine :-)
A couple of photos of what's kept me from Joggling ...
My little helper ,
There's a Joggler in the kitchen , what am a gonna do ....
Revo corner
Back to Joggling
Yay! Good Job!
Chilling now .... when i do the update above , it works great until i get to the
then i get
root@openframe:~# dpkg - i plexmediaserver_0.9.16.4.1911-ee6e505_i386.deb
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
root@openframe:~#
did i mess up ?
It should be: (you put a space after the - )
dpkg -i plexmediaserver_0.9.16.4.1911-ee6e505_i386.deb
Linux, eh!
Just got back from animal hospital .... knackered (problem solved)
Oh no ,I hope all is ok , was it your pet ?
That was it with the space :-) I just copy and pasted ha ha ;-) it must be obvious what I've done wrong to an expert , but I have not much of a clue with this stuff ..
No - not an expert! Just spent hours fiddling. If things go really wrong then I'm clueless - usually start again from scratch.
So, are you all set up with Plex? Does it start automatically if you reboot?
Pet dog (spaniel called Turron - which means marzipan in Spanish) had a sudden ear problem - needed to check it wasn't a grass spike down the ear (which can be difficult to extract if left). Seems it was a normal inflammation. Have to say vets here are more sympathetic than most of the doctors!
Hmmm I thought it had updated fine but now when I play a track I know worked before , I get . Media player error , re setting .
So I tried to stop then start plex media server using what I did before and it says .
plexmediaserver start/running ,process 3220.
Does that mean its still updating ? If so how do I know when its finished .
No - it must have updated when you did the dpkg thing (no errors?). The message means it's working.
what does this do:
Could be that the latest plex is incompatble with ubuntu 14.
May need to try a earlier version.
It says
plexmediaserver stop/waiting
I will have a Google about and see if the latest is compatible .
Try a reboot of Joggler.
That message seems a common error from mainly android users.
I suggest a new install of an earlier version - hang on I'll find a link
