Locked
cbredfred
Post by cbredfred »
BuZz wrote:it doesn't act like a harddisk. it is a block device supported by linux.
I just assumed that with commands like "fdisk" which report back in heads, sector, tracks and cylinders that some kind of translation was happening.
BuZz wrote:it isn't a 1gb ic. it is 2x 512mb flash chips - http://www.jogglerwiki.com/wiki/File:HiRes13.JPG
I was going off what must be incorrect information in the last post of this thread:
http://hackthejoggler.freeforums.org/hi ... s-t13.html
and the first post in this thread:
http://hackthejoggler.freeforums.org/ch ... -t136.html
I'll have to do some reading about "block device".
Thank you for your reply Buzz.
cbredfred
Post by cbredfred »
Are you sure that they are not the RAM chips including U6, U7, U8 and U9?
could easily be actually. i forgot about the ram ;-) im not a hardware guy really heh. (yeh they are, just checked. i must have totally misread the part number earlier).
I suppose block devices are like hds in the fact they use blocks and they probably do show a device geometry, although something like cylinder size wouldnt be applicable to a flash device. although sector size is relevant for partitioning tools etc.
as you said, it seems to have a single chip. as mentioned on the other forum i was unable to locate any info about it.
Off a bit on a tangent; on the Chumby the original 2Gb microSD had four partitions. The first boot one I could never read; just copy. The 2nd and 3rd were duplicates of each other and had the main Linux OS on them and the 4th was was just for storage and additional widgets. The 2nd, 3rd and 4th were EXT2 partitions. This was noted taking the microsd out of the device and looking at it on a Linux OS with GParted.
That said Joggler #5 has only been configured for booting into XP at this time via a USB stick or USB SSD stick. I did initially boot it into the Joggler OS. It initially booted fine. Last time though I tried without the USB sticks; it hung at the O2 screen. I used Roobarb!'s application to bring it back to O2 Joggler life.
cbredfred
Post by cbredfred »
Buzz, is it your belief that mmcblk0 takes up all the storage space of the 1GB chip?
What command in Linux would be used to create the partitions in mmcblk0?
What command would be used to create/define/name mmcblk0 itself?
Would any of those commands show the total size of the 1GB chip?
Sorry if these questions don't even make sense. I guess I'm still struggling to try and fit this into my past experiences.
mmcblk0 is the raw device, so it should be all of it yeh. not sure what you mean by create. mmcblk0 is the device. any partitions will show up as mmcblk0pX - reading from mmcblk0 should image the entire disk. try "sudo blockdev --getsize64 /dev/mmcblk0" to get the size in bytes.
cbredfred
Post by cbredfred »
I final got around to googling "mmcblk0" and have now learnt that this name/designation is used on other devices than the joggler!!! :oops:
So mmc refers to Multi Media Card or flash memory devices?
I tried "sudo blockdev --getsize64 /dev/mmcblk0" in a Putty SSH session to my Joggler booted into Tango and got:
# sudo blockdev --getsize64 /dev/mmcblk0
-sh: sudo: not found
Am I doing something wrong or should my mother have just held her water and drowned me at birth??? :)
that means the "sudo" command was not found. you are already root, so no need to sudo, however you may or may not have the blockdev command. I hadn't intended my instructions for the build in linux anyway, but a full linux distro. boot ubuntu and try it. cat /proc/partitions may already have the cached size of the device in it.
cbredfred
Post by cbredfred »
Ok now I'm with you.
It reports 1028128768 which is the same as the fdisk command reports.
cbredfred
Post by cbredfred »
After reading some of the previous comments in this thread that talk about having to reflash 6 or 7 times before it finally works I decided that I'd sit and watch the telly whilst repeatedly reflashing my jogger, giving it 30 minutes to reboot after each reflash.
After 3 reflashes it still stuck on the O2 logo screen. However I did notice that the number reported at the end of " rebuilding boot partition" changes each time. I had 0+1949, 0+1950 and the last reflash (it had to recreate the partition layout) it came up with 0+1944.
Shouldn't this number remain constant seeing as its reflashing the same content/files each time?
New version complete (System v1.07, Script v1.11). Tested on all the Jogglers in the house and it's working great for me.
The system, when run without the reflash script, now gives the option to press a key for a login screen, making it more useful for troubleshooting. I've also done some tidying up to the reflash script, adding a short pause before checking the flash memory, making sure network settings aren't carried over between units. The filesystem scan is also disabled by default now.
Uploading (slowly) now, so should be available from 7pm.
As noted elsewhere, I've just tested this version (System v1.07, Script v1.11) on two previously problematic machines and all is hunky-dory!
Many thanks (again!)
samjog
Post by samjog »
Hi there,
Did anyone ever figure out how to get past the old 'All updates have downloaded, will now reboot' loop that some other people seem to have had?
I've used the reflash tool which seemed to work really well but I'm still just stuck with this loop problem :(
Any advice is much appreciated.
Cheers :)
samjog wrote:Did anyone ever figure out how to get past the old 'All updates have downloaded, will now reboot' loop that some other people seem to have had?
Yup, I wrote a patcher that fixed that problem last year. Posted a thread on it and everything. :)
Have a read of the thread (well, post, actually), or just hit the 'various tools' link in my sig and look for 'Update Control for Joggler'.
samjog
Post by samjog »
Cheers roobarb, I found it earlier this morning actually :)
Will give it a go tonight and let you know how I get on!
samjog
Post by samjog »
Top one, nice one, sorted!
Ta roobarb :)
samjog wrote:Top one, nice one, sorted!
That's what I like to hear! :)
Turvey
Post by Turvey »
Well it certainly worked for me ;) http://www.jogglerwiki.com/forum/viewto ... ?f=2&t=410
I've even got things working now that weren't working when I first got the Joggler :D :D :D
Thank you for your time and dedication.
Small question though, where does the 'birdslikewires' name come from? :?
Turvey wrote:Well it certainly worked for me ;) http://www.jogglerwiki.com/forum/viewto ... ?f=2&t=410
That's okay - can't count how many lunchtimes and evenings I've spent on Joggler stuff, but I've learned a lot and this is one of the nicest little tech communities around, I think. :)
Turvey wrote:Small question though, where does the 'birdslikewires' name come from? :?
I like birds. And I like wires. ;)
Locked
