Hi I am having problems with my 02 joggler it is used with squeezplay loaded onto memory stick.
It has spdif & optical conversion out which works fine.
Every now and then it crashes blowing the usb stick.
Sometimes it lasts a few months other times just a few days.
The screen gets lots of lines across it i get a screeching noise & it crashes.
I have tried a new power supply but same fault.
When I try to reload i just get squeezeplay on display & it dont load.
When I plug memory stick into my computer what ever size memory stick was before it only shows as being 30mb.
I have tried re formating memorry sticks but still only shows 30mb.
I have tried it through optical out so no physical connection to dac but same fault.
Any help please because its costing me a fortune in memory sticks.
Joggler
Re: Joggler
Here you go dave , the file you need is the HPUSB one
This happened to me to at first , don't worry , using this tool will sort it
https://www.dropbox.com/sh/f2792g7f1e2k ... 97kQa?dl=0
Your sticks will be restored , fingers crossed .
Re: Joggler
Thank you it worked its fixed 6 usb sticks but ive probably thrown out 10 or more usb sticks.
Re: Joggler
That's great
I think I only threw out one before I asked the question .
