Joggler take apart and CPU recooling endeavor
Re: Joggler take apart and CPU recooling endeavor
Remote control startup for the vehicles ,love that , hadn,t even heard of that before .
It is popular here to pre-heat or pre-cool your car if its sitting outside with the extreme temps in the midwest.
Did you ever get a joggler wall mounted ?
Still waiting on the mini CF card holder. Meanwhile testing the 12/7 combo WLAN card / USB SSD stick thing on one Joggler. Might redo the antenna thing for the WLAN card as the wireless connection is not consistent. I had the same issue with the Chumby's internal WLAN card.
Relating to the wall mounting might see if I can get a plastic frame made such that I can leave the back open.
For whatever reason I cannot get the combo CF/ZIF card to work. LED illuminates but no device is seen on the USB list of devices. Might be better to purchase an external one and rip it a part to make its footprint smaller. I wonder if its really just a ZIF drive card with a CF card piece which is not connected?
