Running Logitech SqueezePlay from command line
jambrose
Post by jambrose » Sun Sep 02, 2012 5:37 pm
I am trying to find a way of running the Logitech SqueezePlay through the command line, so that I do not have to touch the SqueezePlay icon on the Joggler.
I have found the location of the executable:
/media/launcher/apps/SqueezePlay/trigger.cgi
However when running this, it wants you to set up all the configuration again. Where is the configuration for the Joggler Icon way of running SqueezePlay installed.
The long term plan is to have an Android Application which turns the SqueezePlay app on, on the Joggler, and then use the SqueezeBox app within Android to control it.
Jon
