Mounting a NTFS USB drive
papaiannis
Post by papaiannis »
I attached a USB hard disk to my joggler running native OS + PnP III.
The drive is not auto-mounted at boot, and I am not able to mount it manually. I suspect that the problem is in the type of filesystem, which in my case is NTFS.
Does the joggler support NTFS devices? If yes, what are the options for the mount command?
If it is not currently supported, where can I find the kernel module for NTFS?
Thanks for help.
Alekos
