If you're seeing the yellow 'O2 Joggler Reflash Tool' message, then it's definitely found the stick and is loading the initial ramdisk. However, if it's then failing, it's usually because it can't then find the root partition. Does it move on at all from the yellow writing, or just stick there?simonaldrich wrote:Hi hawsey, thanks for the warm welcome
I have been using roobarb!'s Linux (dd) instructions for writing the image to the various USB devices I've tried so far.
After writing the joggler_reflash_109.img file to the device I'm then able to successfully mount both the first FAT16 partition (rfl-boot) and the second ext2 partition (rfl-root) off the USB device. This makes me think that the image write has been successful.
I'm going to try writing the image to a portable USB harddrive this evening to see if that helps at all.
Think I'm going to need all the luck I can get!
Both the reflash tool and sqpOS search for the root partition by label, so make sure the label 'rfl-root' isn't being messed with and let us know how it goes with the USB hard drive. If you still have no luck, you could try changing the text 'root=LABEL=rfl-root' in the grub.cfg file on the rfl-boot partition to 'root=/dev/sda2'. This really shouldn't be necessary, though.
