Debian Buster for OpenFrame
________________________________________________________________
Debian Buster for OpenFrame (Kernel 3.16)
TEMPORARILY HORRIBLY BROKEN!
These images are down while I repair the build system and create some overlays which actually work.
Please use the Ubuntu Bionic images instead, which are much more up to date and functional.
Follow the instructions on this page for installing to external media,
or use the Reflashing Tool to install to internal memory.
Take a look at my post about Ubuntu Bionic if you're not sure how to use this.
Given that Ubuntu are no longer supporting 32-bit processors after Ubuntu Bionic 18.04 LTS, I thought a little work on the build system was in order to have it support straight Debian. If you're not aware, Ubuntu is based on Debian, so it shouldn't be too awful keeping both ticking over.
If you do spot any issues, please post here.
Re: Debian Buster for OpenFrame
For some reason Buster is 21 MB bigger than Bionic despite having fewer packages installed.
Here's dpkg --list for Buster:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                         Version                             Architecture Description
ii  acpi                         1.7-1.1                             i386         displays information on ACPI devices
ii  adduser                      3.118                               all          add and remove users and groups
ii  alsa-utils                   1.1.8-2                             i386         Utilities for configuring and using ALSA
ii  apt                          1.8.2                               i386         commandline package manager
ii  apt-utils                    1.8.2                               i386         package management related utility programs
ii  base-files                   10.3+deb10u3                        i386         Debian base system miscellaneous files
ii  base-passwd                  3.5.46                              i386         Debian base system master password and group files
ii  bash                         5.0-4                               i386         GNU Bourne Again SHell
ii  bash-completion              1:2.8-6                             all          programmable completion for the bash shell
ii  bc                           1.07.1-2+b1                         i386         GNU bc arbitrary precision calculator language
ii  bluez                        5.50-1                              i386         Bluetooth tools and daemons
ii  bsdmainutils                 11.1.2+b1                           i386         collection of more utilities from FreeBSD
ii  bsdutils                     1:2.33.1-0.1                        i386         basic utilities from 4.4BSD-Lite
ii  coreutils                    8.30-3                              i386         GNU core utilities
ii  cpio                         2.12+dfsg-9                         i386         GNU cpio -- a program to manage archives of files
ii  cpp                          4:8.3.0-1                           i386         GNU C preprocessor (cpp)
ii  cpp-8                        8.3.0-6                             i386         GNU C preprocessor
ii  cron                         3.0pl1-134+deb10u1                  i386         process scheduling daemon
ii  curl                         7.64.0-4+deb10u1                    i386         command line tool for transferring data with URL syntax
ii  dash                         0.5.10.2-5                          i386         POSIX-compliant shell
ii  dbus                         1.12.16-1                           i386         simple interprocess messaging system (daemon and utilities)
ii  debconf                      1.5.71                              all          Debian configuration management system
ii  debconf-i18n                 1.5.71                              all          full internationalization support for debconf
ii  debian-archive-keyring       2019.1                              all          GnuPG archive keys of the Debian archive
ii  debianutils                  4.8.6.1                             i386         Miscellaneous utilities specific to Debian
ii  diffutils                    1:3.7-3                             i386         File comparison utilities
ii  dmidecode                    3.2-1                               i386         SMBIOS/DMI table decoder
ii  dmsetup                      2:1.02.155-3                        i386         Linux Kernel Device Mapper userspace library
ii  dosfstools                   4.1-2                               i386         utilities for making and checking MS-DOS FAT filesystems
ii  dpkg                         1.19.7                              i386         Debian package management system
ii  e2fsprogs                    1.44.5-1+deb10u3                    i386         ext2/ext3/ext4 file system utilities
ii  fdisk                        2.33.1-0.1                          i386         collection of partitioning utilities
ii  findutils                    4.6.0+git+20190209-2                i386         utilities for finding files--find, xargs
ii  fontconfig                   2.13.1-2                            i386         generic font configuration library - support binaries
ii  fontconfig-config            2.13.1-2                            all          generic font configuration library - configuration
ii  fonts-dejavu-core            2.37-1                              all          Vera font family derivate with additional characters
ii  gcc-8-base:i386              8.3.0-6                             i386         GCC, the GNU Compiler Collection (base package)
ii  gdbm-l10n                    1.18.1-4                            all          GNU dbm database routines (translation files)
ii  gpgv                         2.2.12-1+deb10u1                    i386         GNU privacy guard - signature verification tool
ii  grep                         3.3-1                               i386         GNU grep, egrep and fgrep
ii  gzip                         1.9-3                               i386         GNU compression utilities
ii  hostname                     3.21                                i386         utility to set/show the host name or domain name
ii  htop                         2.2.0-1+b1                          i386         interactive processes viewer
ii  i2c-tools                    4.1-1                               i386         heterogeneous set of I2C tools for Linux
ii  ifupdown                     0.8.35                              i386         high level tools to configure network interfaces
ii  init                         1.56+nmu1                           i386         metapackage ensuring an init system is installed
ii  init-system-helpers          1.56+nmu1                           all          helper tools for all init systems
ii  initramfs-tools              0.133+deb10u1                       all          generic modular initramfs generator (automation)
ii  initramfs-tools-core         0.133+deb10u1                       all          generic modular initramfs generator (core tools)
ii  iproute2                     4.20.0-2                            i386         networking and traffic control tools
ii  iptables                     1.8.2-4                             i386         administration tools for packet filtering and NAT
ii  iputils-ping                 3:20180629-2                        i386         Tools to test the reachability of network hosts
ii  isc-dhcp-client              4.4.1-2                             i386         DHCP client for automatically obtaining an IP address
ii  isc-dhcp-common              4.4.1-2                             i386         common manpages relevant to all of the isc-dhcp packages
ii  klibc-utils                  2.0.6-1                             i386         small utilities built with klibc for early boot
ii  kmod                         26-1                                i386         tools for managing Linux kernel modules
ii  less                         487-0.1+b1                          i386         pager program similar to more
ii  libacl1:i386                 2.2.53-4                            i386         access control list - shared library
ii  libapparmor1:i386            2.13.2-10                           i386         changehat AppArmor library
ii  libapt-inst2.0:i386          1.8.2                               i386         deb package format runtime library
ii  libapt-pkg5.0:i386           1.8.2                               i386         package management runtime library
ii  libargon2-1:i386             0~20171227-0.2                      i386         memory-hard hashing function - runtime library
ii  libasound2:i386              1.1.8-1                             i386         shared library for ALSA applications
ii  libasound2-data              1.1.8-1                             all          Configuration files and profiles for ALSA drivers
ii  libasyncns0:i386             0.8-6                               i386         Asynchronous name service query library
ii  libatomic1:i386              8.3.0-6                             i386         support library providing __atomic built-in functions
ii  libattr1:i386                1:2.4.48-4                          i386         extended attribute handling - shared library
ii  libaudio2:i386               1.9.4-6                             i386         Network Audio System - shared libraries
ii  libaudit-common              1:2.8.4-3                           all          Dynamic library for security auditing - common files
ii  libaudit1:i386               1:2.8.4-3                           i386         Dynamic library for security auditing
ii  libblkid1:i386               2.33.1-0.1                          i386         block device ID library
ii  libbsd0:i386                 0.9.1-2                             i386         utility functions from BSD systems - shared library
ii  libbz2-1.0:i386              1.0.6-9.2~deb10u1                   i386         high-quality block-sorting file compressor library - runtime
ii  libc-bin                     2.28-10                             i386         GNU C Library: Binaries
ii  libc-l10n                    2.28-10                             all          GNU C Library: localization files
ii  libc6:i386                   2.28-10                             i386         GNU C Library: Shared libraries
ii  libcairo2:i386               1.16.0-4                            i386         Cairo 2D vector graphics library
ii  libcap-ng0:i386              0.7.9-2                             i386         An alternate POSIX capabilities library
ii  libcap2:i386                 1:2.25-2                            i386         POSIX 1003.1e capabilities (library)
ii  libcap2-bin                  1:2.25-2                            i386         POSIX 1003.1e capabilities (utilities)
ii  libcom-err2:i386             1.44.5-1+deb10u3                    i386         common error description library
ii  libcryptsetup12:i386         2:2.1.0-5+deb10u2                   i386         disk encryption support - shared library
ii  libcurl4:i386                7.64.0-4+deb10u1                    i386         easy-to-use client-side URL transfer library (OpenSSL flavour)
ii  libdaemon0:i386              0.14-7                              i386         lightweight C library for daemons - runtime library
ii  libdatrie1:i386              0.2.12-2                            i386         Double-array trie library
ii  libdb5.3:i386                5.3.28+dfsg1-0.5                    i386         Berkeley v5.3 Database Libraries [runtime]
ii  libdbus-1-3:i386             1.12.16-1                           i386         simple interprocess messaging system (library)
ii  libdebconfclient0:i386       0.249                               i386         Debian Configuration Management System (C-implementation library)
ii  libdevmapper1.02.1:i386      2:1.02.155-3                        i386         Linux Kernel Device Mapper userspace library
ii  libdns-export1104            1:9.11.5.P4+dfsg-5.1                i386         Exported DNS Shared Library
ii  libdw1:i386                  0.176-1.1                           i386         library that provides access to the DWARF debug information
ii  libedit2:i386                3.1-20181209-1                      i386         BSD editline and history libraries
ii  libelf1:i386                 0.176-1.1                           i386         library to read and write ELF files
ii  libestr0:i386                0.1.10-2.1                          i386         Helper functions for handling strings (lib)
ii  libexpat1:i386               2.2.6-2+deb10u1                     i386         XML parsing C library - runtime library
ii  libext2fs2:i386              1.44.5-1+deb10u3                    i386         ext2/ext3/ext4 file system libraries
ii  libfastjson4:i386            0.99.8-2                            i386         fast json library for C
ii  libfdisk1:i386               2.33.1-0.1                          i386         fdisk partitioning library
ii  libffi6:i386                 3.2.1-9                             i386         Foreign Function Interface library runtime
ii  libfftw3-single3:i386        3.3.8-2                             i386         Library for computing Fast Fourier Transforms - Single precision
ii  libflac8:i386                1.3.2-3                             i386         Free Lossless Audio Codec - runtime C library
ii  libfontconfig1:i386          2.13.1-2                            i386         generic font configuration library - runtime
ii  libfreetype6:i386            2.9.1-3+deb10u1                     i386         FreeType 2 font engine, shared library files
ii  libfribidi0:i386             1.0.5-3.1+deb10u1                   i386         Free Implementation of the Unicode BiDi algorithm
ii  libgcc1:i386                 1:8.3.0-6                           i386         GCC support library
ii  libgcrypt20:i386             1.8.4-5                             i386         LGPL Crypto library - runtime library
ii  libgdbm-compat4:i386         1.18.1-4                            i386         GNU dbm database routines (legacy support runtime version)
ii  libgdbm6:i386                1.18.1-4                            i386         GNU dbm database routines (runtime version)
ii  libglib2.0-0:i386            2.58.3-2+deb10u2                    i386         GLib library of C routines
ii  libgmp10:i386                2:6.1.2+dfsg-4                      i386         Multiprecision arithmetic library
ii  libgnutls30:i386             3.6.7-4+deb10u2                     i386         GNU TLS library - main runtime library
ii  libgomp1:i386                8.3.0-6                             i386         GCC OpenMP (GOMP) support library
ii  libgpg-error0:i386           1.35-1                              i386         GnuPG development runtime library
ii  libgraphite2-3:i386          1.3.13-7                            i386         Font rendering engine for Complex Scripts -- library
ii  libgssapi-krb5-2:i386        1.17-3                              i386         MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii  libharfbuzz0b:i386           2.3.1-1                             i386         OpenType text shaping engine (shared library)
ii  libhogweed4:i386             3.4.1-1                             i386         low level cryptographic library (public-key cryptos)
ii  libi2c0:i386                 4.1-1                               i386         userspace I2C programming library
ii  libice6:i386                 2:1.0.9-2                           i386         X11 Inter-Client Exchange library
ii  libidn11:i386                1.33-2.2                            i386         GNU Libidn library, implementation of IETF IDN specifications
ii  libidn2-0:i386               2.0.5-1+deb10u1                     i386         Internationalized domain names (IDNA2008/TR46) library
ii  libio-socket-ssl-perl        2.060-3                             all          Perl module implementing object oriented interface to SSL sockets
ii  libip4tc0:i386               1.8.2-4                             i386         netfilter libip4tc library
ii  libip6tc0:i386               1.8.2-4                             i386         netfilter libip6tc library
ii  libiptc0:i386                1.8.2-4                             i386         netfilter libiptc library
ii  libisc-export1100:i386       1:9.11.5.P4+dfsg-5.1                i386         Exported ISC Shared Library
ii  libisl19:i386                0.20-2                              i386         manipulating sets and relations of integer points bounded by linear constraints
ii  libiw30:i386                 30~pre9-13                          i386         Wireless tools - library
ii  libjack-jackd2-0:i386        1.9.12~dfsg-2                       i386         JACK Audio Connection Kit (libraries)
ii  libjim0.77:i386              0.77+dfsg0-3                        i386         small-footprint implementation of Tcl - shared library
ii  libjson-c3:i386              0.12.1+ds-2                         i386         JSON manipulation library - shared library
ii  libk5crypto3:i386            1.17-3                              i386         MIT Kerberos runtime libraries - Crypto Library
ii  libkeyutils1:i386            1.6-6                               i386         Linux Key Management Utilities (library)
ii  libklibc:i386                2.0.6-1                             i386         minimal libc subset for use with initramfs
ii  libkmod2:i386                26-1                                i386         libkmod shared library
ii  libkrb5-3:i386               1.17-3                              i386         MIT Kerberos runtime libraries
ii  libkrb5support0:i386         1.17-3                              i386         MIT Kerberos runtime libraries - Support library
ii  libldap-2.4-2:i386           2.4.47+dfsg-3+deb10u1               i386         OpenLDAP libraries
ii  libldap-common               2.4.47+dfsg-3+deb10u1               all          OpenLDAP common files for libraries
ii  liblocale-gettext-perl       1.07-3+b4                           i386         module using libc functions for internationalization in Perl
ii  liblognorm5:i386             2.0.5-1                             i386         log normalizing library
ii  liblz4-1:i386                1.8.3-1                             i386         Fast LZ compression algorithm library - runtime
ii  liblzma5:i386                5.2.4-1                             i386         XZ-format compression library
ii  libmad0:i386                 0.15.1b-10                          i386         MPEG audio decoder library
ii  libmnl0:i386                 1.0.4-2                             i386         minimalistic Netlink communication library
ii  libmount1:i386               2.33.1-0.1                          i386         device mounting library
ii  libmpc3:i386                 1.1.0-1                             i386         multiple precision complex floating-point library
ii  libmpdec2:i386               2.4.2-2                             i386         library for decimal floating point arithmetic (runtime library)
ii  libmpfr6:i386                4.0.2-1                             i386         multiple precision floating-point computation
ii  libmpg123-0:i386             1.25.10-2                           i386         MPEG layer 1/2/3 audio decoder (shared library)
ii  libncurses6:i386             6.1+20181013-2+deb10u2              i386         shared libraries for terminal handling
ii  libncursesw6:i386            6.1+20181013-2+deb10u2              i386         shared libraries for terminal handling (wide character support)
ii  libnet-ssleay-perl           1.85-2+b1                           i386         Perl module for Secure Sockets Layer (SSL)
ii  libnetfilter-conntrack3:i386 1.0.7-1                             i386         Netfilter netlink-conntrack library
ii  libnettle6:i386              3.4.1-1                             i386         low level cryptographic library (symmetric and one-way cryptos)
ii  libnewt0.52:i386             0.52.20-8                           i386         Not Erik's Windowing Toolkit - text mode windowing with slang
ii  libnfnetlink0:i386           1.0.1-3+b1                          i386         Netfilter netlink library
ii  libnftnl11:i386              1.1.2-2                             i386         Netfilter nftables userspace API library
ii  libnghttp2-14:i386           1.36.0-2+deb10u1                    i386         library implementing HTTP/2 protocol (shared library)
ii  libnl-3-200:i386             3.4.0-1                             i386         library for dealing with netlink sockets
ii  libnl-genl-3-200:i386        3.4.0-1                             i386         library for dealing with netlink sockets - generic netlink
ii  libnl-route-3-200:i386       3.4.0-1                             i386         library for dealing with netlink sockets - route interface
ii  libogg0:i386                 1.3.2-1+b1                          i386         Ogg bitstream library
ii  libopenal-data               1:1.19.1-1                          all          Software implementation of the OpenAL audio API (data files)
ii  libopenal1:i386              1:1.19.1-1                          i386         Software implementation of the OpenAL audio API (shared library)
ii  libopus0:i386                1.3-1                               i386         Opus codec runtime library
ii  libossp-uuid16:i386          1.6.2-1.5+b7                        i386         OSSP uuid ISO-C and C++ - shared library
ii  libout123-0:i386             1.25.10-2                           i386         MPEG layer 1/2/3 audio decoder (libout123 shared library)
ii  libp11-kit0:i386             0.23.15-2                           i386         library for loading and coordinating access to PKCS#11 modules - runtime
ii  libpam-modules:i386          1.3.1-5                             i386         Pluggable Authentication Modules for PAM
ii  libpam-modules-bin           1.3.1-5                             i386         Pluggable Authentication Modules for PAM - helper binaries
ii  libpam-runtime               1.3.1-5                             all          Runtime support for the PAM library
ii  libpam0g:i386                1.3.1-5                             i386         Pluggable Authentication Modules library
ii  libpango-1.0-0:i386          1.42.4-7~deb10u1                    i386         Layout and rendering of internationalized text
ii  libpango1.0-0:i386           1.42.4-7~deb10u1                    i386         Layout and rendering of internationalized text (transitional package)
ii  libpangocairo-1.0-0:i386     1.42.4-7~deb10u1                    i386         Layout and rendering of internationalized text
ii  libpangoft2-1.0-0:i386       1.42.4-7~deb10u1                    i386         Layout and rendering of internationalized text
ii  libpangox-1.0-0:i386         0.0.2-5+b2                          i386         pango library X backend
ii  libpangoxft-1.0-0:i386       1.42.4-7~deb10u1                    i386         Layout and rendering of internationalized text
ii  libpci3:i386                 1:3.5.2-1                           i386         Linux PCI Utilities (shared library)
ii  libpcre2-8-0:i386            10.32-5                             i386         New Perl Compatible Regular Expression Library- 8 bit runtime files
ii  libpcre3:i386                2:8.39-12                           i386         Old Perl 5 Compatible Regular Expression Library - runtime files
ii  libpcsclite1:i386            1.8.24-1                            i386         Middleware to access a smart card using PC/SC (library)
ii  libperl5.28:i386             5.28.1-6                            i386         shared Perl library
ii  libpixman-1-0:i386           0.36.0-1                            i386         pixel-manipulation library for X and cairo
ii  libpng16-16:i386             1.6.36-6                            i386         PNG library - runtime (version 1.6)
ii  libpopt0:i386                1.16-12                             i386         lib for parsing cmdline parameters
ii  libportaudio2:i386           19.6.0-1                            i386         Portable audio I/O - shared library
ii  libprocps7:i386              2:3.3.15-2                          i386         library for accessing process information from /proc
ii  libpsl5:i386                 0.20.2-2                            i386         Library for Public Suffix List (shared libraries)
ii  libpulse0:i386               12.2-4+deb10u1                      i386         PulseAudio client libraries
ii  libpython3-stdlib:i386       3.7.3-1                             i386         interactive high-level object-oriented language (default python3 version)
ii  libpython3.7-minimal:i386    3.7.3-2+deb10u1                     i386         Minimal subset of the Python language (version 3.7)
ii  libpython3.7-stdlib:i386     3.7.3-2+deb10u1                     i386         Interactive high-level object-oriented language (standard library, version 3.7)
ii  libreadline7:i386            7.0-5                               i386         GNU readline and history libraries, run-time libraries
ii  librtmp1:i386                2.4+20151223.gitfa8646d.1-2         i386         toolkit for RTMP streams (shared library)
ii  libsamplerate0:i386          0.1.9-2                             i386         Audio sample rate conversion library
ii  libsasl2-2:i386              2.1.27+dfsg-1+deb10u1               i386         Cyrus SASL - authentication abstraction library
ii  libsasl2-modules-db:i386     2.1.27+dfsg-1+deb10u1               i386         Cyrus SASL - pluggable authentication modules (DB)
ii  libseccomp2:i386             2.3.3-4                             i386         high level interface to Linux seccomp filter
ii  libselinux1:i386             2.8-1+b1                            i386         SELinux runtime shared libraries
ii  libsemanage-common           2.8-2                               all          Common files for SELinux policy management libraries
ii  libsemanage1:i386            2.8-2                               i386         SELinux policy management library
ii  libsepol1:i386               2.8-1                               i386         SELinux library for manipulating binary security policies
ii  libslang2:i386               2.3.2-2                             i386         S-Lang programming library - runtime version
ii  libsm6:i386                  2:1.2.3-1                           i386         X11 Session Management library
ii  libsmartcols1:i386           2.33.1-0.1                          i386         smart column output alignment library
ii  libsndfile1:i386             1.0.28-6                            i386         Library for reading/writing audio files
ii  libsndio7.0:i386             1.5.0-3                             i386         Small audio and MIDI framework from OpenBSD, runtime libraries
ii  libsoxr0:i386                0.1.2-3                             i386         High quality 1D sample-rate conversion library
ii  libsqlite3-0:i386            3.27.2-3                            i386         SQLite 3 shared library
ii  libss2:i386                  1.44.5-1+deb10u3                    i386         command-line interface parsing library
ii  libssh2-1:i386               1.8.0-2.1                           i386         SSH2 client-side library
ii  libssl1.1:i386               1.1.1d-0+deb10u2                    i386         Secure Sockets Layer toolkit - shared libraries
ii  libstdc++6:i386              8.3.0-6                             i386         GNU Standard C++ Library v3
ii  libsystemd0:i386             241-7~deb10u3                       i386         systemd utility library
ii  libtasn1-6:i386              4.13-3                              i386         Manage ASN.1 structures (runtime)
ii  libtext-charwidth-perl       0.04-7.1+b1                         i386         get display widths of characters on the terminal
ii  libtext-iconv-perl           1.7-5+b7                            i386         converts between character sets in Perl
ii  libtext-wrapi18n-perl        0.06-7.1                            all          internationalized substitute of Text::Wrap
ii  libthai-data                 0.1.28-2                            all          Data files for Thai language support library
ii  libthai0:i386                0.1.28-2                            i386         Thai language support library
ii  libtinfo6:i386               6.1+20181013-2+deb10u2              i386         shared low-level terminfo library for terminal handling
ii  libudev1:i386                241-7~deb10u3                       i386         libudev shared library
ii  libunistring2:i386           0.9.10-1                            i386         Unicode string library for C
ii  libusb-1.0-0:i386            2:1.0.22-2                          i386         userspace USB programming library
ii  libuuid1:i386                2.33.1-0.1                          i386         Universally Unique ID library
ii  libvorbis0a:i386             1.3.6-2                             i386         decoder library for Vorbis General Audio Compression Codec
ii  libvorbisenc2:i386           1.3.6-2                             i386         encoder library for Vorbis General Audio Compression Codec
ii  libvorbisidec1               1.2.1+git20180316-3                 i386         Integer-only Ogg Vorbis decoder, AKA "tremor"
ii  libwrap0:i386                7.6.q-28                            i386         Wietse Venema's TCP wrappers library
ii  libx11-6:i386                2:1.6.7-1                           i386         X11 client-side library
ii  libx11-data                  2:1.6.7-1                           all          X11 client-side library
ii  libx11-xcb1:i386             2:1.6.7-1                           i386         Xlib/XCB interface library
ii  libxau6:i386                 1:1.0.8-1+b2                        i386         X11 authorisation library
ii  libxaw7:i386                 2:1.0.13-1+b2                       i386         X11 Athena Widget library
ii  libxcb-render0:i386          1.13.1-2                            i386         X C Binding, render extension
ii  libxcb-shm0:i386             1.13.1-2                            i386         X C Binding, shm extension
ii  libxcb1:i386                 1.13.1-2                            i386         X C Binding
ii  libxcursor1:i386             1:1.1.15-2                          i386         X cursor management library
ii  libxdmcp6:i386               1:1.1.2-3                           i386         X11 Display Manager Control Protocol library
ii  libxext6:i386                2:1.3.3-1+b2                        i386         X11 miscellaneous extension library
ii  libxfixes3:i386              1:5.0.3-1                           i386         X11 miscellaneous 'fixes' extension library
ii  libxft2:i386                 2.3.2-2                             i386         FreeType-based font drawing library for X
ii  libxi6:i386                  2:1.7.9-1                           i386         X11 Input extension library
ii  libxinerama1:i386            2:1.1.4-2                           i386         X11 Xinerama extension library
ii  libxmu6:i386                 2:1.1.2-2+b3                        i386         X11 miscellaneous utility library
ii  libxmuu1:i386                2:1.1.2-2+b3                        i386         X11 miscellaneous micro-utility library
ii  libxpm4:i386                 1:3.5.12-1                          i386         X11 pixmap library
ii  libxrandr2:i386              2:1.5.1-1                           i386         X11 RandR extension library
ii  libxrender1:i386             1:0.9.10-1                          i386         X Rendering Extension client library
ii  libxt6:i386                  1:1.1.5-1+b3                        i386         X11 toolkit intrinsics library
ii  libxtables12:i386            1.8.2-4                             i386         netfilter xtables library
ii  libxtst6:i386                2:1.2.3-1                           i386         X11 Testing -- Record extension library
ii  libxxf86vm1:i386             1:1.1.4-1+b2                        i386         X11 XFree86 video mode extension library
ii  libyaml-0-2:i386             0.2.1-1                             i386         Fast YAML 1.1 parser and emitter library
ii  libzstd1:i386                1.3.8+dfsg-3                        i386         fast lossless compression algorithm
ii  linux-base                   4.6                                 all          Linux image base package
ii  linux-image-3.16.82op        3.16.82op-1                         i386         Linux kernel, version 3.16.82op
ii  locales                      2.28-10                             all          GNU C Library: National Language (locale) data [support]
ii  login                        1:4.5-1.1                           i386         system login tools
ii  logrotate                    3.14.0-4                            i386         Log rotation utility
ii  lsb-base                     10.2019051400                       all          Linux Standard Base init script functionality
ii  mawk                         1.3.3-17+b3                         i386         a pattern scanning and text processing language
ii  mime-support                 3.62                                all          MIME files 'mime.types' & 'mailcap', and support programs
ii  mount                        2.33.1-0.1                          i386         tools for mounting and manipulating filesystems
ii  mpg123                       1.25.10-2                           i386         MPEG layer 1/2/3 audio player
ii  nano                         3.2-3                               i386         small, friendly text editor inspired by Pico
ii  ncurses-base                 6.1+20181013-2+deb10u2              all          basic terminal type definitions
ii  ncurses-bin                  6.1+20181013-2+deb10u2              i386         terminal-related programs and man pages
ii  net-tools                    1.60+git20180626.aebd88e-1          i386         NET-3 networking toolkit
ii  netbase                      5.6                                 all          Basic TCP/IP networking system
ii  netplan.io                   0.95-2                              i386         YAML network configuration abstraction for various backends
ii  ntpdate                      1:4.2.8p12+dfsg-4                   i386         client for setting system time from NTP servers (deprecated)
ii  openssh-client               1:7.9p1-10+deb10u2                  i386         secure shell (SSH) client, for secure access to remote machines
ii  openssh-server               1:7.9p1-10+deb10u2                  i386         secure shell (SSH) server, for secure access from remote machines
ii  openssh-sftp-server          1:7.9p1-10+deb10u2                  i386         secure shell (SSH) sftp server module, for SFTP access from remote machines
ii  passwd                       1:4.5-1.1                           i386         change and administer password and group data
ii  patch                        2.7.6-3+deb10u1                     i386         Apply a diff file to an original
ii  pciutils                     1:3.5.2-1                           i386         Linux PCI Utilities
ii  perl                         5.28.1-6                            i386         Larry Wall's Practical Extraction and Report Language
ii  perl-base                    5.28.1-6                            i386         minimal Perl system
ii  perl-modules-5.28            5.28.1-6                            all          Core Perl modules
ii  perl-openssl-defaults:i386   3                                   i386         version compatibility baseline for Perl OpenSSL packages
ii  procps                       2:3.3.15-2                          i386         /proc file system utilities
ii  psmisc                       23.2-1                              i386         utilities that use the proc file system
ii  python3                      3.7.3-1                             i386         interactive high-level object-oriented language (default python3 version)
ii  python3-minimal              3.7.3-1                             i386         minimal subset of the Python language (default python3 version)
ii  python3-netifaces            0.10.4-1+b1                         i386         portable network interface information - Python 3.x
ii  python3-yaml                 3.13-2                              i386         YAML parser and emitter for Python3
ii  python3.7                    3.7.3-2+deb10u1                     i386         Interactive high-level object-oriented language (version 3.7)
ii  python3.7-minimal            3.7.3-2+deb10u1                     i386         Minimal subset of the Python language (version 3.7)
ii  readline-common              7.0-5                               all          GNU readline and history libraries, common files
ii  rsync                        3.1.3-6                             i386         fast, versatile, remote (and local) file-copying tool
ii  rsyslog                      8.1901.0-1                          i386         reliable system and kernel logging daemon
ii  sed                          4.7-1                               i386         GNU stream editor for filtering/transforming text
ii  sensible-utils               0.0.12                              all          Utilities for sensible alternative selection
ii  ssh                          1:7.9p1-10+deb10u2                  all          secure shell client and server (metapackage)
ii  sudo                         1.8.27-1+deb10u2                    i386         Provide limited super user privileges to specific users
ii  systemd                      241-7~deb10u3                       i386         system and service manager
ii  systemd-sysv                 241-7~deb10u3                       i386         system and service manager - SysV links
ii  sysvinit-utils               2.93-8                              i386         System-V-like utilities
ii  tar                          1.30+dfsg-6                         i386         GNU version of the tar archiving utility
ii  tasksel                      3.53                                all          tool for selecting tasks for installation on Debian systems
ii  tasksel-data                 3.53                                all          official tasks used for installation of Debian systems
ii  tcpd                         7.6.q-28                            i386         Wietse Venema's TCP wrapper utilities
ii  tzdata                       2019c-0+deb10u1                     all          time zone and daylight-saving time data
ii  ucf                          3.0038+nmu1                         all          Update Configuration File(s): preserve user changes to config files
ii  udev                         241-7~deb10u3                       i386         /dev/ and hotplug management daemon
ii  unclutter                    8-21                                i386         hides the mouse cursor in X after a period of inactivity
ii  unzip                        6.0-23+deb10u1                      i386         De-archiver for .zip files
ii  usb-modeswitch               2.5.2+repack0-2                     i386         mode switching tool for controlling "flip flop" USB devices
ii  usb-modeswitch-data          20170806-2                          all          mode switching data for usb-modeswitch
ii  usb.ids                      2019.07.27-0+deb10u1                all          USB ID Repository
ii  usbutils                     1:010-3                             i386         Linux USB utilities
ii  util-linux                   2.33.1-0.1                          i386         miscellaneous system utilities
ii  uuid                         1.6.2-1.5+b7                        i386         Universally Unique Identifier Command-Line Tool
ii  vim-common                   2:8.1.0875-5                        all          Vi IMproved - Common files
ii  vim-tiny                     2:8.1.0875-5                        i386         Vi IMproved - enhanced vi editor - compact version
ii  wget                         1.20.1-1.1                          i386         retrieves files from the web
ii  whiptail                     0.52.20-8                           i386         Displays user-friendly dialog boxes from shell scripts
ii  wireless-tools               30~pre9-13                          i386         Tools for manipulating Linux Wireless Extensions
ii  wpasupplicant                2:2.7+git20190128+0c1e29f-6+deb10u1 i386         client support for WPA and WPA2 (IEEE 802.11i)
ii  x11-common                   1:7.7+19                            all          X Window System (X.Org) infrastructure
ii  x11-xserver-utils            7.7+8                               i386         X server utilities
ii  xauth                        1:1.0.10-1                          i386         X authentication utility
ii  xinput                       1.6.2-1+b1                          i386         Runtime configuration and test of XInput devices
ii  xxd                          2:8.1.0875-5                        i386         tool to make (or reverse) a hex dump
ii  zlib1g:i386                  1:1.2.11.dfsg-1                     i386         compression library - runtime
ii  zlibc                        0.9k-4.3                            i386         An on-fly auto-uncompressing C library
And for Bionic:
ii  adduser                    3.116ubuntu1                          all          add and remove users and groups
ii  alsa-utils                 1.1.3-1ubuntu1                        i386         Utilities for configuring and using ALSA
ii  apt                        1.6.12                                i386         commandline package manager
ii  apt-utils                  1.6.12                                i386         package management related utility programs
ii  base-files                 10.1ubuntu2.8                         i386         Debian base system miscellaneous files
ii  base-passwd                3.5.44                                i386         Debian base system master password and group files
ii  bash                       4.4.18-2ubuntu1.2                     i386         GNU Bourne Again SHell
ii  bash-completion            1:2.8-1ubuntu1                        all          programmable completion for the bash shell
ii  bc                         1.07.1-2                              i386         GNU bc arbitrary precision calculator language
ii  bluez                      5.48-0ubuntu3.3                       i386         Bluetooth tools and daemons
ii  bsdutils                   1:2.31.1-0.4ubuntu3.5                 i386         basic utilities from 4.4BSD-Lite
ii  busybox-initramfs          1:1.27.2-2ubuntu3.2                   i386         Standalone shell setup for initramfs
ii  bzip2                      1.0.6-8.1ubuntu0.2                    i386         high-quality block-sorting file compressor - utilities
ii  ca-certificates            20180409                              all          Common CA certificates
ii  console-setup              1.178ubuntu2.9                        all          console font and keymap setup program
ii  console-setup-linux        1.178ubuntu2.9                        all          Linux specific part of console-setup
ii  coreutils                  8.28-1ubuntu1                         i386         GNU core utilities
ii  cpio                       2.12+dfsg-6ubuntu0.18.04.1            i386         GNU cpio -- a program to manage archives of files
ii  cpp                        4:7.4.0-1ubuntu2.3                    i386         GNU C preprocessor (cpp)
ii  cpp-7                      7.5.0-3ubuntu1~18.04                  i386         GNU C preprocessor
ii  cron                       3.0pl1-128.1ubuntu1                   i386         process scheduling daemon
ii  curl                       7.58.0-2ubuntu3.8                     i386         command line tool for transferring data with URL syntax
ii  dash                       0.5.8-2.10                            i386         POSIX-compliant shell
ii  dbus                       1.12.2-1ubuntu1.1                     i386         simple interprocess messaging system (daemon and utilities)
ii  debconf                    1.5.66ubuntu1                         all          Debian configuration management system
ii  debconf-i18n               1.5.66ubuntu1                         all          full internationalization support for debconf
ii  debianutils                4.8.4                                 i386         Miscellaneous utilities specific to Debian
ii  diffutils                  1:3.6-1                               i386         File comparison utilities
ii  distro-info-data           0.37ubuntu0.6                         all          information about the distributions' releases (data files)
ii  dmsetup                    2:1.02.145-4.1ubuntu3.18.04.2         i386         Linux Kernel Device Mapper userspace library
ii  dosfstools                 4.1-1                                 i386         utilities for making and checking MS-DOS FAT filesystems
ii  dpkg                       1.19.0.5ubuntu2.3                     i386         Debian package management system
ii  e2fsprogs                  1.44.1-1ubuntu1.3                     i386         ext2/ext3/ext4 file system utilities
ii  eject                      2.1.5+deb1+cvs20081104-13.2           i386         ejects CDs and operates CD-Changers under Linux
ii  fdisk                      2.31.1-0.4ubuntu3.5                   i386         collection of partitioning utilities
ii  file                       1:5.32-2ubuntu0.3                     i386         Recognize the type of data in a file using "magic" numbers
ii  findutils                  4.6.0+git+20170828-2                  i386         utilities for finding files--find, xargs
ii  fontconfig                 2.12.6-0ubuntu2                       i386         generic font configuration library - support binaries
ii  fontconfig-config          2.12.6-0ubuntu2                       all          generic font configuration library - configuration
ii  gcc-7-base:i386            7.5.0-3ubuntu1~18.04                  i386         GCC, the GNU Compiler Collection (base package)
ii  gcc-8-base:i386            8.3.0-26ubuntu1~18.04                 i386         GCC, the GNU Compiler Collection (base package)
ii  gir1.2-glib-2.0:i386       1.56.1-1                              i386         Introspection data for GLib, GObject, Gio and GModule
ii  gpgv                       2.2.4-1ubuntu1.2                      i386         GNU privacy guard - signature verification tool
ii  grep                       3.1-2build1                           i386         GNU grep, egrep and fgrep
ii  gzip                       1.6-5ubuntu1                          i386         GNU compression utilities
ii  hostname                   3.20                                  i386         utility to set/show the host name or domain name
ii  htop                       2.1.0-3                               i386         interactive processes viewer
ii  i2c-tools                  4.0-2                                 i386         heterogeneous set of I2C tools for Linux
ii  init                       1.51                                  i386         metapackage ensuring an init system is installed
ii  init-system-helpers        1.51                                  all          helper tools for all init systems
ii  initramfs-tools            0.130ubuntu3.9                        all          generic modular initramfs generator (automation)
ii  initramfs-tools-bin        0.130ubuntu3.9                        i386         binaries used by initramfs-tools
ii  initramfs-tools-core       0.130ubuntu3.9                        all          generic modular initramfs generator (core tools)
ii  iproute2                   4.15.0-2ubuntu1                       i386         networking and traffic control tools
ii  iputils-ping               3:20161105-1ubuntu3                   i386         Tools to test the reachability of network hosts
ii  isc-dhcp-client            4.3.5-3ubuntu7.1                      i386         DHCP client for automatically obtaining an IP address
ii  isc-dhcp-common            4.3.5-3ubuntu7.1                      i386         common manpages relevant to all of the isc-dhcp packages
ii  kbd                        2.0.4-2ubuntu1                        i386         Linux console font and keytable utilities
ii  keyboard-configuration     1.178ubuntu2.9                        all          system-wide keyboard preferences
ii  klibc-utils                2.0.4-9ubuntu2                        i386         small utilities built with klibc for early boot
ii  kmod                       24-1ubuntu3.2                         i386         tools for managing Linux kernel modules
ii  less                       487-0.1                               i386         pager program similar to more
ii  libacl1:i386               2.2.52-3build1                        i386         Access control list shared library
ii  libapparmor1:i386          2.12-4ubuntu5.1                       i386         changehat AppArmor library
ii  libapt-inst2.0:i386        1.6.12                                i386         deb package format runtime library
ii  libapt-pkg5.0:i386         1.6.12                                i386         package management runtime library
ii  libargon2-0:i386           0~20161029-1.1                        i386         memory-hard hashing function - runtime library
ii  libasn1-8-heimdal:i386     7.5.0+dfsg-1                          i386         Heimdal Kerberos - ASN.1 library
ii  libasound2:i386            1.1.3-5ubuntu0.2                      i386         shared library for ALSA applications
ii  libasound2-data            1.1.3-5ubuntu0.2                      all          Configuration files and profiles for ALSA drivers
ii  libatm1:i386               1:2.5.1-2build1                       i386         shared library for ATM (Asynchronous Transfer Mode)
ii  libattr1:i386              1:2.4.47-2build1                      i386         Extended attribute shared library
ii  libaudit-common            1:2.8.2-1ubuntu1                      all          Dynamic library for security auditing - common files
ii  libaudit1:i386             1:2.8.2-1ubuntu1                      i386         Dynamic library for security auditing
ii  libblkid1:i386             2.31.1-0.4ubuntu3.5                   i386         block device ID library
ii  libbsd0:i386               0.8.7-1ubuntu0.1                      i386         utility functions from BSD systems - shared library
ii  libbz2-1.0:i386            1.0.6-8.1ubuntu0.2                    i386         high-quality block-sorting file compressor library - runtime
ii  libc-bin                   2.27-3ubuntu1                         i386         GNU C Library: Binaries
ii  libc6:i386                 2.27-3ubuntu1                         i386         GNU C Library: Shared libraries
ii  libcairo2:i386             1.15.10-2ubuntu0.1                    i386         Cairo 2D vector graphics library
ii  libcap-ng0:i386            0.7.7-3.1                             i386         An alternate POSIX capabilities library
ii  libcap2:i386               1:2.25-1.2                            i386         POSIX 1003.1e capabilities (library)
ii  libcap2-bin                1:2.25-1.2                            i386         POSIX 1003.1e capabilities (utilities)
ii  libcom-err2:i386           1.44.1-1ubuntu1.3                     i386         common error description library
ii  libcryptsetup12:i386       2:2.0.2-1ubuntu1.1                    i386         disk encryption support - shared library
ii  libcurl4:i386              7.58.0-2ubuntu3.8                     i386         easy-to-use client-side URL transfer library (OpenSSL flavour)
ii  libdaemon0:i386            0.14-6                                i386         lightweight C library for daemons - runtime library
ii  libdatrie1:i386            0.2.10-7                              i386         Double-array trie library
ii  libdb5.3:i386              5.3.28-13.1ubuntu1.1                  i386         Berkeley v5.3 Database Libraries [runtime]
ii  libdbus-1-3:i386           1.12.2-1ubuntu1.1                     i386         simple interprocess messaging system (library)
ii  libdebconfclient0:i386     0.213ubuntu1                          i386         Debian Configuration Management System (C-implementation library)
ii  libdevmapper1.02.1:i386    2:1.02.145-4.1ubuntu3.18.04.2         i386         Linux Kernel Device Mapper userspace library
ii  libdns-export1100          1:9.11.3+dfsg-1ubuntu1.11             i386         Exported DNS Shared Library
ii  libedit2:i386              3.1-20170329-1                        i386         BSD editline and history libraries
ii  libelf1:i386               0.170-0.4ubuntu0.1                    i386         library to read and write ELF files
ii  libexpat1:i386             2.2.5-3ubuntu0.2                      i386         XML parsing C library - runtime library
ii  libext2fs2:i386            1.44.1-1ubuntu1.3                     i386         ext2/ext3/ext4 file system libraries
ii  libfdisk1:i386             2.31.1-0.4ubuntu3.5                   i386         fdisk partitioning library
ii  libffi6:i386               3.2.1-8                               i386         Foreign Function Interface library runtime
ii  libfftw3-single3:i386      3.3.7-1                               i386         Library for computing Fast Fourier Transforms - Single precision
ii  libflac8:i386              1.3.2-1                               i386         Free Lossless Audio Codec - runtime C library
ii  libfontconfig1:i386        2.12.6-0ubuntu2                       i386         generic font configuration library - runtime
ii  libfreetype6:i386          2.8.1-2ubuntu2                        i386         FreeType 2 font engine, shared library files
ii  libfribidi0:i386           0.19.7-2                              i386         Free Implementation of the Unicode BiDi algorithm
ii  libgcc1:i386               1:8.3.0-26ubuntu1~18.04               i386         GCC support library
ii  libgcrypt20:i386           1.8.1-4ubuntu1.2                      i386         LGPL Crypto library - runtime library
ii  libgdbm-compat4:i386       1.14.1-6                              i386         GNU dbm database routines (legacy support runtime version)
ii  libgdbm5:i386              1.14.1-6                              i386         GNU dbm database routines (runtime version)
ii  libgirepository-1.0-1:i386 1.56.1-1                              i386         Library for handling GObject introspection data (runtime library)
ii  libglib2.0-0:i386          2.56.4-0ubuntu0.18.04.4               i386         GLib library of C routines
ii  libglib2.0-data            2.56.4-0ubuntu0.18.04.4               all          Common files for GLib library
ii  libgmp10:i386              2:6.1.2+dfsg-2                        i386         Multiprecision arithmetic library
ii  libgnutls30:i386           3.5.18-1ubuntu1.3                     i386         GNU TLS library - main runtime library
ii  libgomp1:i386              8.3.0-26ubuntu1~18.04                 i386         GCC OpenMP (GOMP) support library
ii  libgpg-error0:i386         1.27-6                                i386         library for common error values and messages in GnuPG components
ii  libgraphite2-3:i386        1.3.11-2                              i386         Font rendering engine for Complex Scripts -- library
ii  libgssapi-krb5-2:i386      1.16-2ubuntu0.1                       i386         MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii  libgssapi3-heimdal:i386    7.5.0+dfsg-1                          i386         Heimdal Kerberos - GSSAPI support library
ii  libharfbuzz0b:i386         1.7.2-1ubuntu1                        i386         OpenType text shaping engine (shared library)
ii  libhcrypto4-heimdal:i386   7.5.0+dfsg-1                          i386         Heimdal Kerberos - crypto library
ii  libheimbase1-heimdal:i386  7.5.0+dfsg-1                          i386         Heimdal Kerberos - Base library
ii  libheimntlm0-heimdal:i386  7.5.0+dfsg-1                          i386         Heimdal Kerberos - NTLM support library
ii  libhogweed4:i386           3.4-1                                 i386         low level cryptographic library (public-key cryptos)
ii  libhx509-5-heimdal:i386    7.5.0+dfsg-1                          i386         Heimdal Kerberos - X509 support library
ii  libi2c0:i386               4.0-2                                 i386         userspace I2C programming library
ii  libicu60:i386              60.2-3ubuntu3                         i386         International Components for Unicode
ii  libidn11:i386              1.33-2.1ubuntu1.2                     i386         GNU Libidn library, implementation of IETF IDN specifications
ii  libidn2-0:i386             2.0.4-1.1ubuntu0.2                    i386         Internationalized domain names (IDNA2008/TR46) library
ii  libio-socket-ssl-perl      2.060-3~ubuntu18.04.1                 all          Perl module implementing object oriented interface to SSL sockets
ii  libip4tc0:i386             1.6.1-2ubuntu2                        i386         netfilter libip4tc library
ii  libisc-export169:i386      1:9.11.3+dfsg-1ubuntu1.11             i386         Exported ISC Shared Library
ii  libisl19:i386              0.19-1                                i386         manipulating sets and relations of integer points bounded by linear constraints
ii  libiw30:i386               30~pre9-12ubuntu1                     i386         Wireless tools - library
ii  libjson-c3:i386            0.12.1-1.3                            i386         JSON manipulation library - shared library
ii  libk5crypto3:i386          1.16-2ubuntu0.1                       i386         MIT Kerberos runtime libraries - Crypto Library
ii  libkeyutils1:i386          1.5.9-9.2ubuntu2                      i386         Linux Key Management Utilities (library)
ii  libklibc                   2.0.4-9ubuntu2                        i386         minimal libc subset for use with initramfs
ii  libkmod2:i386              24-1ubuntu3.2                         i386         libkmod shared library
ii  libkrb5-26-heimdal:i386    7.5.0+dfsg-1                          i386         Heimdal Kerberos - libraries
ii  libkrb5-3:i386             1.16-2ubuntu0.1                       i386         MIT Kerberos runtime libraries
ii  libkrb5support0:i386       1.16-2ubuntu0.1                       i386         MIT Kerberos runtime libraries - Support library
ii  libldap-2.4-2:i386         2.4.45+dfsg-1ubuntu1.4                i386         OpenLDAP libraries
ii  libldap-common             2.4.45+dfsg-1ubuntu1.4                all          OpenLDAP common files for libraries
ii  liblocale-gettext-perl     1.07-3build2                          i386         module using libc functions for internationalization in Perl
ii  liblz4-1:i386              0.0~r131-2ubuntu3                     i386         Fast LZ compression algorithm library - runtime
ii  liblzma5:i386              5.2.2-1.3                             i386         XZ-format compression library
ii  libmad0:i386               0.15.1b-9ubuntu18.04.1                i386         MPEG audio decoder library
ii  libmagic-mgc               1:5.32-2ubuntu0.3                     i386         File type determination library using "magic" numbers (compiled magic file)
ii  libmagic1:i386             1:5.32-2ubuntu0.3                     i386         Recognize the type of data in a file using "magic" numbers - library
ii  libmount1:i386             2.31.1-0.4ubuntu3.5                   i386         device mounting library
ii  libmpdec2:i386             2.4.2-1ubuntu1                        i386         library for decimal floating point arithmetic (runtime library)
ii  libmpfr6:i386              4.0.1-1                               i386         multiple precision floating-point computation
ii  libmpg123-0:i386           1.25.10-1                             i386         MPEG layer 1/2/3 audio decoder (shared library)
ii  libncurses5:i386           6.1-1ubuntu1.18.04                    i386         shared libraries for terminal handling
ii  libncursesw5:i386          6.1-1ubuntu1.18.04                    i386         shared libraries for terminal handling (wide character support)
ii  libnet-ssleay-perl         1.84-1ubuntu0.2                       i386         Perl module for Secure Sockets Layer (SSL)
ii  libnettle6:i386            3.4-1                                 i386         low level cryptographic library (symmetric and one-way cryptos)
ii  libnewt0.52:i386           0.52.20-1ubuntu1                      i386         Not Erik's Windowing Toolkit - text mode windowing with slang
ii  libnghttp2-14:i386         1.30.0-1ubuntu1                       i386         library implementing HTTP/2 protocol (shared library)
ii  libnl-3-200:i386           3.2.29-0ubuntu3                       i386         library for dealing with netlink sockets
ii  libnl-genl-3-200:i386      3.2.29-0ubuntu3                       i386         library for dealing with netlink sockets - generic netlink
ii  libnss-systemd:i386        237-3ubuntu10.39                      i386         nss module providing dynamic user and group name resolution
ii  libogg0:i386               1.3.2-1                               i386         Ogg bitstream library
ii  libopenal-data             1:1.18.2-2                            all          Software implementation of the OpenAL audio API (data files)
ii  libopenal1:i386            1:1.18.2-2                            i386         Software implementation of the OpenAL audio API (shared library)
ii  libossp-uuid16:i386        1.6.2-1.5build4                       i386         OSSP uuid ISO-C and C++ - shared library
ii  libout123-0:i386           1.25.10-1                             i386         MPEG layer 1/2/3 audio decoder (libout123 shared library)
ii  libp11-kit0:i386           0.23.9-2                              i386         library for loading and coordinating access to PKCS#11 modules - runtime
ii  libpam-cap:i386            1:2.25-1.2                            i386         POSIX 1003.1e capabilities (PAM module)
ii  libpam-modules:i386        1.1.8-3.6ubuntu2.18.04.1              i386         Pluggable Authentication Modules for PAM
ii  libpam-modules-bin         1.1.8-3.6ubuntu2.18.04.1              i386         Pluggable Authentication Modules for PAM - helper binaries
ii  libpam-runtime             1.1.8-3.6ubuntu2.18.04.1              all          Runtime support for the PAM library
ii  libpam-systemd:i386        237-3ubuntu10.39                      i386         system and service manager - PAM module
ii  libpam0g:i386              1.1.8-3.6ubuntu2.18.04.1              i386         Pluggable Authentication Modules library
ii  libpango-1.0-0:i386        1.40.14-1ubuntu0.1                    i386         Layout and rendering of internationalized text
ii  libpango1.0-0:i386         1.40.14-1ubuntu0.1                    i386         Layout and rendering of internationalized text (transitional package)
ii  libpangocairo-1.0-0:i386   1.40.14-1ubuntu0.1                    i386         Layout and rendering of internationalized text
ii  libpangoft2-1.0-0:i386     1.40.14-1ubuntu0.1                    i386         Layout and rendering of internationalized text
ii  libpangox-1.0-0:i386       0.0.2-5                               i386         pango library X backend
ii  libpangoxft-1.0-0:i386     1.40.14-1ubuntu0.1                    i386         Layout and rendering of internationalized text
ii  libpci3:i386               1:3.5.2-1ubuntu1.1                    i386         Linux PCI Utilities (shared library)
ii  libpcre3:i386              2:8.39-9                              i386         Old Perl 5 Compatible Regular Expression Library - runtime files
ii  libpcsclite1:i386          1.8.23-1                              i386         Middleware to access a smart card using PC/SC (library)
ii  libperl5.26:i386           5.26.1-6ubuntu0.3                     i386         shared Perl library
ii  libpipeline1:i386          1.5.0-1                               i386         pipeline manipulation library
ii  libpixman-1-0:i386         0.34.0-2                              i386         pixel-manipulation library for X and cairo
ii  libpng16-16:i386           1.6.34-1ubuntu0.18.04.2               i386         PNG library - runtime (version 1.6)
ii  libpopt0:i386              1.16-11                               i386         lib for parsing cmdline parameters
ii  libprocps6:i386            2:3.3.12-3ubuntu1.2                   i386         library for accessing process information from /proc
ii  libpsl5:i386               0.19.1-5build1                        i386         Library for Public Suffix List (shared libraries)
ii  libpulse0:i386             1:11.1-1ubuntu7.4                     i386         PulseAudio client libraries
ii  libpython3-stdlib:i386     3.6.7-1~18.04                         i386         interactive high-level object-oriented language (default python3 version)
ii  libpython3.6-minimal:i386  3.6.9-1~18.04                         i386         Minimal subset of the Python language (version 3.6)
ii  libpython3.6-stdlib:i386   3.6.9-1~18.04                         i386         Interactive high-level object-oriented language (standard library, version 3.6)
ii  libreadline7:i386          7.0-3                                 i386         GNU readline and history libraries, run-time libraries
ii  libroken18-heimdal:i386    7.5.0+dfsg-1                          i386         Heimdal Kerberos - roken support library
ii  librtmp1:i386              2.4+20151223.gitfa8646d.1-1           i386         toolkit for RTMP streams (shared library)
ii  libsamplerate0:i386        0.1.9-1                               i386         Audio sample rate conversion library
ii  libsasl2-2:i386            2.1.27~101-g0780600+dfsg-3ubuntu2.1   i386         Cyrus SASL - authentication abstraction library
ii  libsasl2-modules-db:i386   2.1.27~101-g0780600+dfsg-3ubuntu2.1   i386         Cyrus SASL - pluggable authentication modules (DB)
ii  libseccomp2:i386           2.4.1-0ubuntu0.18.04.2                i386         high level interface to Linux seccomp filter
ii  libselinux1:i386           2.7-2build2                           i386         SELinux runtime shared libraries
ii  libsemanage-common         2.7-2build2                           all          Common files for SELinux policy management libraries
ii  libsemanage1:i386          2.7-2build2                           i386         SELinux policy management library
ii  libsepol1:i386             2.7-1                                 i386         SELinux library for manipulating binary security policies
ii  libslang2:i386             2.3.1a-3ubuntu1                       i386         S-Lang programming library - runtime version
ii  libsm6:i386                2:1.2.2-1                             i386         X11 Session Management library
ii  libsmartcols1:i386         2.31.1-0.4ubuntu3.5                   i386         smart column output alignment library
ii  libsndfile1:i386           1.0.28-4ubuntu0.18.04.1               i386         Library for reading/writing audio files
ii  libsndio6.1:i386           1.1.0-3                               i386         Small audio and MIDI framework from OpenBSD, runtime libraries
ii  libsqlite3-0:i386          3.22.0-1ubuntu0.3                     i386         SQLite 3 shared library
ii  libss2:i386                1.44.1-1ubuntu1.3                     i386         command-line interface parsing library
ii  libssl1.0.0:i386           1.0.2n-1ubuntu5.3                     i386         Secure Sockets Layer toolkit - shared libraries
ii  libssl1.1:i386             1.1.1-1ubuntu2.1~18.04.5              i386         Secure Sockets Layer toolkit - shared libraries
ii  libstdc++6:i386            8.3.0-26ubuntu1~18.04                 i386         GNU Standard C++ Library v3
ii  libsystemd0:i386           237-3ubuntu10.39                      i386         systemd utility library
ii  libtasn1-6:i386            4.13-2                                i386         Manage ASN.1 structures (runtime)
ii  libtext-charwidth-perl     0.04-7.1                              i386         get display widths of characters on the terminal
ii  libtext-iconv-perl         1.7-5build6                           i386         converts between character sets in Perl
ii  libthai-data               0.1.27-2                              all          Data files for Thai language support library
ii  libthai0:i386              0.1.27-2                              i386         Thai language support library
ii  libtinfo5:i386             6.1-1ubuntu1.18.04                    i386         shared low-level terminfo library for terminal handling
ii  libudev1:i386              237-3ubuntu10.39                      i386         libudev shared library
ii  libunistring2:i386         0.9.9-0ubuntu2                        i386         Unicode string library for C
ii  libusb-1.0-0:i386          2:1.0.21-2                            i386         userspace USB programming library
ii  libuuid1:i386              2.31.1-0.4ubuntu3.5                   i386         Universally Unique ID library
ii  libvorbis0a:i386           1.3.5-4.2                             i386         decoder library for Vorbis General Audio Compression Codec
ii  libvorbisenc2:i386         1.3.5-4.2                             i386         encoder library for Vorbis General Audio Compression Codec
ii  libvorbisidec1             1.0.2+svn18153-1+deb9u1build0.18.04.1 i386         Integer-only Ogg Vorbis decoder, AKA "tremor"
ii  libwind0-heimdal:i386      7.5.0+dfsg-1                          i386         Heimdal Kerberos - stringprep implementation
ii  libwrap0:i386              7.6.q-27                              i386         Wietse Venema's TCP wrappers library
ii  libx11-6:i386              2:1.6.4-3ubuntu0.2                    i386         X11 client-side library
ii  libx11-data                2:1.6.4-3ubuntu0.2                    all          X11 client-side library
ii  libxau6:i386               1:1.0.8-1                             i386         X11 authorisation library
ii  libxaw7:i386               2:1.0.13-1                            i386         X11 Athena Widget library
ii  libxcb-render0:i386        1.13-2~ubuntu18.04                    i386         X C Binding, render extension
ii  libxcb-shm0:i386           1.13-2~ubuntu18.04                    i386         X C Binding, shm extension
ii  libxcb1:i386               1.13-2~ubuntu18.04                    i386         X C Binding
ii  libxcursor1:i386           1:1.1.15-1                            i386         X cursor management library
ii  libxext6:i386              2:1.3.3-1                             i386         X11 miscellaneous extension library
ii  libxft2:i386               2.3.2-1                               i386         FreeType-based font drawing library for X
ii  libxinerama1:i386          2:1.1.3-1                             i386         X11 Xinerama extension library
ii  libxml2:i386               2.9.4+dfsg1-6.1ubuntu1.3              i386         GNOME XML library
ii  libxmu6:i386               2:1.1.2-2                             i386         X11 miscellaneous utility library
ii  libxmuu1:i386              2:1.1.2-2                             i386         X11 miscellaneous micro-utility library
ii  libxt6:i386                1:1.1.5-1                             i386         X11 toolkit intrinsics library
ii  libxtables12:i386          1.6.1-2ubuntu2                        i386         netfilter xtables library
ii  libxxf86vm1:i386           1:1.1.4-1                             i386         X11 XFree86 video mode extension library
ii  libyaml-0-2:i386           0.1.7-2ubuntu3                        i386         Fast YAML 1.1 parser and emitter library
ii  libzstd1:i386              1.3.3+dfsg-2ubuntu1.1                 i386         fast lossless compression algorithm
ii  linux-base                 4.5ubuntu1                            all          Linux image base package
ii  locales                    2.27-3ubuntu1                         all          GNU C Library: National Language (locale) data [support]
ii  login                      1:4.5-1ubuntu2                        i386         system login tools
ii  logrotate                  3.11.0-0.1ubuntu1                     i386         Log rotation utility
ii  lsb-base                   9.20170808ubuntu1                     all          Linux Standard Base init script functionality
ii  lsb-release                9.20170808ubuntu1                     all          Linux Standard Base version reporting utility
ii  mawk                       1.3.3-17ubuntu3                       i386         a pattern scanning and text processing language
ii  mime-support               3.60ubuntu1                           all          MIME files 'mime.types' & 'mailcap', and support programs
ii  mount                      2.31.1-0.4ubuntu3.5                   i386         tools for mounting and manipulating filesystems
ii  mpg123                     1.25.10-1                             i386         MPEG layer 1/2/3 audio player
ii  multiarch-support          2.27-3ubuntu1                         i386         Transitional package to ensure multiarch compatibility
ii  nano                       2.9.3-2                               i386         small, friendly text editor inspired by Pico
ii  ncurses-base               6.1-1ubuntu1.18.04                    all          basic terminal type definitions
ii  ncurses-bin                6.1-1ubuntu1.18.04                    i386         terminal-related programs and man pages
ii  net-tools                  1.60+git20161116.90da8a0-1ubuntu1     i386         NET-3 networking toolkit
ii  netbase                    5.4                                   all          Basic TCP/IP networking system
ii  netcat-openbsd             1.187-1ubuntu0.1                      i386         TCP/IP swiss army knife
ii  netplan.io                 0.98-0ubuntu1~18.04.1                 i386         YAML network configuration abstraction for various backends
ii  networkd-dispatcher        1.7-0ubuntu3.3                        all          Dispatcher service for systemd-networkd connection status changes
ii  nplan                      0.98-0ubuntu1~18.04.1                 all          YAML network configuration abstraction - transitional package
ii  ntpdate                    1:4.2.8p10+dfsg-5ubuntu7.1            i386         client for setting system time from NTP servers
ii  openssh-client             1:7.6p1-4ubuntu0.3                    i386         secure shell (SSH) client, for secure access to remote machines
ii  openssh-server             1:7.6p1-4ubuntu0.3                    i386         secure shell (SSH) server, for secure access from remote machines
ii  openssh-sftp-server        1:7.6p1-4ubuntu0.3                    i386         secure shell (SSH) sftp server module, for SFTP access from remote machines
ii  openssl                    1.1.1-1ubuntu2.1~18.04.5              i386         Secure Sockets Layer toolkit - cryptographic utility
ii  passwd                     1:4.5-1ubuntu2                        i386         change and administer password and group data
ii  patch                      2.7.6-2ubuntu1.1                      i386         Apply a diff file to an original
ii  pciutils                   1:3.5.2-1ubuntu1.1                    i386         Linux PCI Utilities
ii  perl                       5.26.1-6ubuntu0.3                     i386         Larry Wall's Practical Extraction and Report Language
ii  perl-base                  5.26.1-6ubuntu0.3                     i386         minimal Perl system
ii  perl-modules-5.26          5.26.1-6ubuntu0.3                     all          Core Perl modules
ii  perl-openssl-defaults:i386 3build1                               i386         version compatibility baseline for Perl OpenSSL packages
ii  procps                     2:3.3.12-3ubuntu1.2                   i386         /proc file system utilities
ii  psmisc                     23.1-1ubuntu0.1                       i386         utilities that use the proc file system
ii  python3                    3.6.7-1~18.04                         i386         interactive high-level object-oriented language (default python3 version)
ii  python3-dbus               1.2.6-1                               i386         simple interprocess messaging system (Python 3 interface)
ii  python3-gi                 3.26.1-2ubuntu1                       i386         Python 3 bindings for gobject-introspection libraries
ii  python3-minimal            3.6.7-1~18.04                         i386         minimal subset of the Python language (default python3 version)
ii  python3-netifaces          0.10.4-0.1build4                      i386         portable network interface information - Python 3.x
ii  python3-yaml               3.12-1build2                          i386         YAML parser and emitter for Python3
ii  python3.6                  3.6.9-1~18.04                         i386         Interactive high-level object-oriented language (version 3.6)
ii  python3.6-minimal          3.6.9-1~18.04                         i386         Minimal subset of the Python language (version 3.6)
ii  readline-common            7.0-3                                 all          GNU readline and history libraries, common files
ii  rsync                      3.1.2-2.1ubuntu1.1                    i386         fast, versatile, remote (and local) file-copying tool
ii  rsyslog                    8.32.0-1ubuntu4                       i386         reliable system and kernel logging daemon
ii  sed                        4.4-2                                 i386         GNU stream editor for filtering/transforming text
ii  shared-mime-info           1.9-2                                 i386         FreeDesktop.org shared MIME database and spec
ii  ssh                        1:7.6p1-4ubuntu0.3                    all          secure shell client and server (metapackage)
ii  sudo                       1.8.21p2-3ubuntu1.2                   i386         Provide limited super user privileges to specific users
ii  systemd                    237-3ubuntu10.39                      i386         system and service manager
ii  systemd-sysv               237-3ubuntu10.39                      i386         system and service manager - SysV links
ii  sysvinit-utils             2.88dsf-59.10ubuntu1                  i386         System-V-like utilities
ii  tar                        1.29b-2ubuntu0.1                      i386         GNU version of the tar archiving utility
ii  tcpd                       7.6.q-27                              i386         Wietse Venema's TCP wrapper utilities
ii  tzdata                     2019c-0ubuntu0.18.04                  all          time zone and daylight-saving time data
ii  ubuntu-advantage-tools     17                                    all          management tools for Ubuntu Advantage
ii  ubuntu-keyring             2018.09.18.1~18.04.0                  all          GnuPG keys of the Ubuntu archive
ii  ubuntu-minimal             1.417.4                               i386         Minimal core of Ubuntu
ii  ucf                        3.0038                                all          Update Configuration File(s): preserve user changes to config files
ii  udev                       237-3ubuntu10.39                      i386         /dev/ and hotplug management daemon
ii  unzip                      6.0-21ubuntu1                         i386         De-archiver for .zip files
ii  usb-modeswitch             2.5.2+repack0-2ubuntu1                i386         mode switching tool for controlling "flip flop" USB devices
ii  usbutils                   1:007-4build1                         i386         Linux USB utilities
ii  util-linux                 2.31.1-0.4ubuntu3.5                   i386         miscellaneous system utilities
ii  uuid                       1.6.2-1.5build4                       i386         Universally Unique Identifier Command-Line Tool
ii  vim-common                 2:8.0.1453-1ubuntu1.1                 all          Vi IMproved - Common files
ii  vim-tiny                   2:8.0.1453-1ubuntu1.1                 i386         Vi IMproved - enhanced vi editor - compact version
ii  wget                       1.19.4-1ubuntu2.2                     i386         retrieves files from the web
ii  whiptail                   0.52.20-1ubuntu1                      i386         Displays user-friendly dialog boxes from shell scripts
ii  wireless-tools             30~pre9-12ubuntu1                     i386         Tools for manipulating Linux Wireless Extensions
ii  wpasupplicant              2:2.6-15ubuntu2.5                     i386         client support for WPA and WPA2 (IEEE 802.11i)
ii  x11-common                 1:7.7+19ubuntu7.1                     all          X Window System (X.Org) infrastructure
ii  x11-xserver-utils          7.7+7build1                           i386         X server utilities
ii  xdg-user-dirs              0.17-1ubuntu1                         i386         tool to manage well known user directories
ii  xinput                     1.6.2-1build1                         i386         Runtime configuration and test of XInput devices
ii  xkb-data                   2.23.1-1ubuntu1.18.04.1               all          X Keyboard Extension (XKB) configuration data
ii  xxd                        2:8.0.1453-1ubuntu1.1                 i386         tool to make (or reverse) a hex dump
ii  xz-utils                   5.2.2-1.3                             i386         XZ-format compression utilities
ii  zlib1g:i386                1:1.2.11.dfsg-0ubuntu2                i386         compression library - runtime
I'll be honest, I've barely looked at either of these, but if anyone spots anything they think is daft, please post.
The idea behind the included packages is that the device should be able to do at least something useful out of the box; my baseline was "can it play some music from the internet", which it achieves with mpg123.
Hi roobarb!
I thought to try building Jivelite and maybe installing LMS but have had no luck at the first hurdle.
login as: ronnie
ronnie@192.168.1.23's password:
Linux openframe 3.16.82op #1 Wed Feb 12 03:37:03 GMT 2020 i686
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
ronnie@openframe:~$ sudo apt update
[sudo] password for ronnie:
Err:1 http://security.debian.org/debian-security buster/updates InRelease
  Temporary failure resolving 'security.debian.org'
Err:2 http://deb.debian.org/debian buster InRelease
  Temporary failure resolving 'deb.debian.org'
Err:3 http://deb.debian.org/debian buster-updates InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://deb.debian.org/debian/dists/buster/InRelease  Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://security.debian.org/debian-security/dists/buster/updates/InRelease  Temporary failure resolving 'security.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/buster-updates/InRelease  Temporary failure resolving 'deb.debian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
ronnie@openframe:~$
ronnie
Man in a van wrote: Sat Mar 14, 2020 12:53 pm I thought to try building Jivelite and maybe installing LMS but have had no luck at the first hurdle.
This'll fix it:
systemctl enable systemd-resolved.service
Already fixed in the overlay, the server should rebuild the images sometime overnight.
ARJunior
Post by ARJunior »
Hi roobarb!
Same problem here despite executing command above.
Another suggestion ?
ARJunior
Post by ARJunior »
Problem resolved.
Wrong nameserver defined by default :
root@openframe:~# cat /etc/resolv.conf
nameserver 127.0.0.1
#nameserver 213.186.33.99
#search ovh.net
ARJunior wrote: Sun Mar 15, 2020 5:59 pm Problem resolved.
#search ovh.net
So what exactly, does one do to reolve the problem ?
I have commented out the two lines as shown in your post and it still gives the same error message.
Tried both with the previous image (adding the cmdl instruction) and burning the replacement image.
ronnie
ARJunior
Post by ARJunior »
ronnie
Just use Google DNS (8.8.8.8) or your gateway as DNS server.
Seems OVH DNS 213.186.33.99 is unreachable
After a day of struggle with the Bionic 3.16 and 5.4 kernels I though I would look again at this.
First it seems the wi-fi thing is .yaml or whatever it is called.
I thought debian 10 (when I have installed it on an old 32 bit shuttle use wpa_supplicant. I know these aren't the correct technical terms, but I hope you get my drift.
Anyway, I connected a passive usb hub, keyboard and mouse and tried my luck.
I had no luck at all with the standard joggler, it would not complete the boot.
Tried the same set up with my Cisco joggler and after repeated attempts, each one making a little more progress, I arrived at a log in screen.
Only it wouldn't.
I had lots of messages on the screen, the most popular was
Failed to start Network Time Syncronisation
It's really disappointing, especially when on is a bear of little brain.
ronnie
Hey roobarb!
I hope the person formally known as "rusk biter" is up and about and healthy, also her parents.
Stay safe
Man in a van wrote: Thu Apr 02, 2020 6:19 pm After a day of struggle with the Bionic 3.16 and 5.4 kernels I though I would look again at this.
Stay well away from the 5.4 kernels - even I don't use those. I was asked by someone who had a specific purpose for the 5.4 kernel to generate that one and I've just left it there, it really is only for development purposes. In fact, I'll remove the link from the post.
Man in a van wrote: Thu Apr 02, 2020 6:19 pm First it seems the wi-fi thing is .yaml or whatever it is called.
Yup, there's a network.yaml file on the boot partition now, so it can be edited from your PC and have networking up and running without messing on the OpenFrame itself.
Man in a van wrote: Thu Apr 02, 2020 6:19 pm I thought debian 10 (when I have installed it on an old 32 bit shuttle use wpa_supplicant. I know these aren't the correct technical terms, but I hope you get my drift.
It does, but that's just the 'back end' that deals with wifi. Your interaction with it would be via that network.yaml configuration file, which controls netplan. Honestly, I'd stick with the Bionic 3.16.82op image right now - that's had the most testing. There are also certainly issues with the Buster image I don't know about yet.
Man in a van wrote: Thu Apr 02, 2020 6:19 pm Anyway, I connected a passive usb hub, keyboard and mouse and tried my luck.
That sounds like an issue with your USB setup - the Joggler is remarkably tricksy in that regard. Try it again with no keyboard or mouse - just the stick in the side. Does it then boot? If not, try another stick. If still not, download a new copy of the image file and try again. I use those exact 3.16 images on a bunch o' OpenFrames, so I know they'll at least boot. ;)
Only it wouldn't.
If it's being that flaky it must be a USB issue - either the combination of hub and USB stick, or just the stick - try with nothing but the stick attached. I know you won't be able to control it without peripherals (unless you SSH in) but it'll prove where the sticking point is.
Hey roobarb!
Stay safe
Thank you, sir! She is way past the rusks now and causing trouble around the house these days. She's big into chicken pies. :D
We've also got the BBC Model B back up and running, which was my Dad's and I spent a lot of time in front of as a kid, so we were enjoying Dare Devil Denis this afternoon!
jimeney
Post by jimeney »
What's the state of hardware support on Buster? is the GMA500 fully supported for hardware acceleration? Toying with building a minimal desktop environment to launch VLC and transcode on the fly a hdmi video source (already have a hdmi over ip device that directs a transport stream to an IP address) into h264 if the chipset will sufficiently offload this away from the CPU?
jimeney wrote: Sun Apr 05, 2020 8:43 pm What's the state of hardware support on Buster? is the GMA500 fully supported for hardware acceleration?
It's the open source GMA500 driver only, not the Intel EMGD driver. So you get OpenGL, but not hardware accelerated video decoding.
jimeney wrote: Sun Apr 05, 2020 8:43 pm Toying with building a minimal desktop environment to launch VLC and transcode on the fly a hdmi video source (already have a hdmi over ip device that directs a transport stream to an IP address) into h264 if the chipset will sufficiently offload this away from the CPU?
I don't know about hardware accelerated video encoding at all, but if you're using an OpenFrame 2 you might be able to replace the internal mini-PCI wifi card with an encoder. I have no idea what hardware is available, if any, though.
I tested the Openframe 2 KODI with a Crystal HD miniPCIE card and it worked fine years ago.
BUT that was Ubuntu 14.X and I am not sure whether drivers are around today for the Crystal HD cards. That said you can probably purchase one for $10.
pete wrote: Thu Apr 09, 2020 2:43 am I tested the Openframe 2 KODI with a Crystal HD miniPCIE card and it worked fine years ago.
The last version of the kernel with the Crystal HD driver is 3.16, which is exactly the version which works perfectly with the OpenFrames.
I have it configured as a module, so you should just be able to drop one into the socket and boot the image. 8-)
Yeah here tested it on an Openframe that was totally extracted from the case and another partially disassembled OpenFrame 2.
Thinking I posted a pictorial here someplace relating to this endeavor.
That said opening the case is easy peasey if you go baby steps. (the following is from memory as I have not done this in a very long time).
1 - Power off and disconnect the power supply
2 - use a long skinny screwdriver in the two holes on the bottom of the Openframe 2 case - be gental. I believe that Openpeak had a special tool with two long protrusions on it to remove the LCD screen from the front and used a plastic wedge to lift on the LCD screen.
3 - feel for two plastic tabs which hold the screen in place
4 - using a plastic tool or wedge or credit card pry up on the LCD screen at the bottom of it one side at a time while putting pressure on the left or right tab
5 - the screen lifts off and there is a ribbon cable going to the motherboard.
6 - I do not remember now if it was plastic or the metal heat shield to take off next to see the motherboard and the mini-pcie combo WLAN / Bluetooth card.
7 - the combo device had built in antennas so removing this device is easy. I purchased an extender to install the Crystal HD card.
What worked nicely was 1080 movies and live streaming television (mostly all 1080 here locally). You can purchase a combo USB stick today with Bluetooth / WlAN on it. I just installed one recently to one of my carpcs in Linux. You have to install the drivers manually but it is no big thing.
Re: Debian Buster for OpenFrame
Will try making a tool here using a coat hanger as pushing on the two tabs to remove the LCD screen will be easier than pushing on one tab with a screwdriver.
OK tried to pull up on the touchscreen using a plastic wedge tool and it does move. I have seen a picture of the disassemble tool which goes inside of the Openframe 2 and either pulls or pushes the plastic tabs keeping the touchscreen in place.
