PnP III v3.60 July 2017 Update
vinnielo
Re: PnP III v3.60 July 2017 Update
Post by vinnielo »
I've tried following the instructions to install the SSL add-on.
It doesn't seem to have made any difference to the radio stream I'm listening to and it still errors out.
Now, it may be because I'm still on PnPIII 3.5.0 (gasp!!), but trying to listen to this Cuban webstream: https://icecast.teveo.icrt.cu/9Rnrbjzq still fails.
Is it a must that I use 3.6.0?
mb1
Post by mb1 »
Does anyone know how to get the Thames TV clock onto the screensavers in PnP?
https://625.uk.com/tv_logos/flash/thames_clock.asp?hide
... or any of the other ITV ones?
Thank you.
vinnielo
Post by vinnielo »
What version of LMS does this update include?
vinnielo
Post by vinnielo »
Would it be possible to update the release with a newer version of LMS?
Recent versions have handling of streams with SSL.
vinnielo
Post by vinnielo »
keynet wrote: Fri Oct 20, 2017 7:09 pm I should mention that Squeezeplay does occasionally "lose focus", i.e. the Tango GUI takes over the screen, perhaps related to its screensaver, though Squeezeplay is still running in the background, and can be controlled via the web/LMS, so it can look as if the Squeezeplay is dead. I haven't got any further with that issue atm.
I've noticed it also likes to do this at midnight on the first of each month.
