Bodhi Linux
Bodhi Linux
Test images available.
http://joggler.exotica.org.uk/img/bodhi ... com.img.gz
http://joggler.exotica.org.uk/img/bodhi ... xt4.img.gz
Not done any configuring of the desktop apart from turn off the seconds on the clock. the brightness app didn't work though, and on first boot you might miss some icons. there is also hidden text under the home screen icons and probably lots of other issues. still, it mostly works, so you can have a play with it.
Re: Bodhi Linux
awesome thanks buzz
verg0
Re: Bodhi Linux
Post by verg0 »
Cool! :D
Re: Bodhi Linux
See first post again.
verg0
Re: Bodhi Linux
Post by verg0 »
Great work BuZz, im likeing the ipad feel this has, Very good choice m8!
guidows
Re: Bodhi Linux
Post by guidows »
thanks!
i will test it :)
Re: Bodhi Linux
wow that is beautiful... well done buzz
verg0
Re: Bodhi Linux
Post by verg0 »
Any further advancements with this image BuZz?
Re: Bodhi Linux
nope. I dont know that I will either. most likely to fix up things like the backlight app means messing about with the code, and i dont really have the time. but it basically works anyway.
kroonen
Re: Bodhi Linux
Post by kroonen »
Is there already a new bodhi image for the o2 joggler?? Boshi 2.0.1 is already there and it;s based on ubuntu also, so i should be possible??
regards Richard
Re: Bodhi Linux
i can do a new build but there are graphical issues, as well as a no working screen brightness app still. i started debugging it, but ran out of time really.
kroonen
Re: Bodhi Linux
Post by kroonen »
What kind of graphical issues??? it's the same emgd driver form ubuntu repo?
Brightness control I don't use.
Re: Bodhi Linux
i think its an enlightenment issue rather than driver issue. some text doesn't appear under icons etc.
kroonen
Re: Bodhi Linux
Post by kroonen »
Than it should also appear when running enlightenment in ubuntu??
Re: Bodhi Linux
not neccessarily (due to other software differences), but im not ruling out the driver. I just remember it looked like an issue related to screen res / layout at the time.
kroonen
Re: Bodhi Linux
Post by kroonen »
Can you make a build of the newest version of Bodhi so we can try what works right now
regards Richard
Re: Bodhi Linux
i will. as soon as I have a spare afternoon - I suffer from having too many spare time projects currently :)
asantaga
Re: Bodhi Linux
Post by asantaga »
nice looking though.. thanks for the time you've spent so far..
Angelo
