Cannot connect to WiFi on SqueezePlay OS, please help!
JonB
Post by JonB »
Hi all
Per the title, I am not able to connect my Joggler to my wireless network in SqueezePlay OS. I keep getting the "No network address has been assigned to the Wireless interface (wlan0)" error.
I have followed the advice given in the SqueezeOS thread but none of it seems to work. My passphrase is long and randomly generated, contains many special characters and takes forever to enter, but I have done it repeatedly and got nowhere.
Some things I know:
  • I have the latest version of the OS (download as of today 8th April 2016). The website says it is "v3.03 for OpenFrame 1 Internal Memory".
  • No problems reflashing / booting
  • My Joggler can connect to my network (had it running one of the other distros before)
  • I am sure I have entered the SSID and passphrase correctly (and double checked them)
  • I am entering them in order and selecting "Accept changes and reboot"
Is there a way I can verify what SSID/passphrase I am using? Are they held in a config file somewhere? Can I enter them without using the touchscreen (into a config file)?
I am currently connected via wired ethernet and will try wireless again (roobarb said this usually works but I'm not hopeful - I did this before).
Anything else I can try?
jonB
Re: Cannot connect to WiFi on SqueezeplayOS, please help!
My advice - change your wifi password to something simple to enter - test. That way you can discover if it's a pass related issue.
You can always switch the router pass back to your 'paranoia' version!
You can edit the network interfaces file - do you know how to use winSCP ?
castalla wrote:My advice - change your wifi password to something simple to enter - test. That way you can discover if it's a pass related issue.
Plus 1 on keeping it simple.
I have had a similar problem this last week.
Re-flashed with OpenPeake and tested the wireless connection-everything fine.
Flashed the internal with SqPos and only the Ethernet would connect to my LMS.
Bizarrely, wireless would connect to Mysqueezebox.com without a problem.
I tried several new flashes before giving up and going to bed.
The next day I restarted the router and away we went with the wireless, no problem.
So my recommendation is to try the Openpeake and then re-start or reset the router.
atb
Ronnie.
JonB
Re: Cannot connect to WiFi on SqueezePlay OS, please help!
Post by JonB »
I have been using OpenPeak up till now, that's how I know it is working. But I suspect that the special characters in my passphrase are causing a problem (especially if there are shell scripts involved). I guess that is the question, is the OS coded to use shell scripts to update the <whatever file it is that stores the passphrase>? And can I configure it myself from the shell? Or, as I asked previously, what are the config files?
(PS, yes I can SSH into it when wired and I am competent with bash). :)
You can edit the following file:
/etc/network/interfaces
Mine only has wifi data for static (never use wired) :-
auto lo
iface lo inet loopback
#auto wlan0
auto wlan0
iface wlan0 inet static
address 192.168.0.20
netmask 255.255.255.0
gateway 192.168.0.1
wpa-ssid SSID
wpa-psk passphrase
The file has owner root group root. So best to edit it as root
I have just set up 3 Jogglers (thanks guys :-) all would not initially connect to wireless until I first plugged in to Ethernet and selected wired in the menus after first inputting the wireless details , give it 5 mins , switch to wireless in settings , re boot and give it a minute to connect , you are done , it will work now , this has been the case for every one and once done it works every time wirelessly ...hope this helps ,
Sent by SlimKat FirePhone
JonB
Post by JonB »
Thanks Hawsey
I tried it but no luck.
Have you got any special characters in your PSK like . ^ ~ { } [ ] ( ) ! , ?
Meanwhile, using instructions here http://askubuntu.com/questions/16584/ho ... n-terminal, I have manually enabled the wireless adapter, invoked wpa_supplicant and connected to my wireless network. The Joggler has two IP addresses in this setup, one for eth0 and the other for wlan0. This proves that the router and Joggler can connect (I am even SSH-ed into it via wireless and wired simultaneously).
But what next? How can I make this configuration stick? I suppose I could follow the "configure static IP address" approach linked to on birdslikewires.co.uk but I would really prefer it to work natively from the SqueezePlayer interface.
[EDIT: I tried configuring a static IP but it didn't work :( ]
No I've no special characters ,I would try again , plug in Ethernet , get connected ,then input your wireless details , save and reboot still on wired then on reboot switch to wireless and reboot again , having unplugged your Ethernet cable , it took me ages to get wireless connection and I suspect yours is the same issue ,
Good luck :-)
The only time I've seen a similar situation was when the Joggler was too far from the router, and the signal was weak.
Just a point - how far is the Joggler from the router ?
Also, if the terminal approach gets you running, why bother with the screen?
[I don't want to suggest that your typing skills are deficient, but if your pass is as complicated & as long as you say, then the occasionally 'sticky' screen can easily create a mis-type. ]
@hawsey
Just noticed you're in N'land ..... It's my home county, too!
JonB
Post by JonB »
Hmm, I wonder if this could be the problem?
-- the wpa supplicant won't tell you the keys, we need to parse them from the config file
function _readPSK(self, ssid)
        local param = _readWpaConfig(self, ssid)
        local psk = assert(param["psk"])
        -- remove quotes
        psk = string.match(psk, '^"(.*)"$') or psk
        return psk
end
This code is in SetupSqueezeboxApplet.lua appears to be reading the content of /etc/wpa_supplicant.conf, but stripping out some special characters from the PSK (which means - if I'm reading this code correctly - I will never, ever get it to work with my key and the native setup). So why is it removing special characters? My guess is it's invoking setup commands via the shell.
I can't be the only person using special characters in a PSK...
To answer your questions: Joggler is in range, that's why manual setup is successful. As to not using the screen to set it up, sure, but I don't know how to make my (manually configured) setup stick between boots (as I said before). Any advice?
No idea about the applet.lua.
The easiest way is to change the router pass to something simple, eg. abcdefgh, or aaabbbcc, get connected,
Change the passphrase in /etc/network/interfaces
Reset router pass back to original
JonB
Post by JonB »
No chance, there are too many devices to update.
But I think I have succeeded by following these instructions: https://www.thefanclub.co.za/how-to/how ... ts-startup. The Squeezeplayer UI still thinks it is connected to the wired network, but the cable's not plugged in and it is working from WiFi.
:D
castalla wrote:@hawsey
Success :-) that's great.
Castalla , where abouts ? I live in Bedlington now ( home of the strangely lamb like dog :-))
JonB
Post by JonB »
Tip: To set the AirPlay name of your joggler (which comes up on the iOS device Airplay list), SSH to the Joggler and edit the file
.squeezeplay/userpath/settings/Playback.lua
You are looking to change the value of the playerinit name setting as shown in bold below.
settings = {enableAudio=1,squeezeNetwork=false,serverUuid="c2e23096-8982-4327-b413-69fd2333633c",powerState="on",volume=40,serverInit={mac="00:08:9b:8c:52:f6",ip="10.0.1.2",},serverName="ChavNAS",playerInit={name="SqueezePlay",model="squeezeplay",},captureVolume=40,}
Alter "SqueezePlay" to your preferred name and reboot. This is handy if you have more than one Joggler on your network and you want to use Airplay.
Well done.
I was only suggesting to change the router pass temporarily - this would only affect the Joggler - while you set it up.
But, you've found another way, so all's good!
Originally ... Shiremoor
Spare me please!!!!!!!!!! :roll:
It'll be all whippets, clogs and flat 'ats from now on ;)
Ronnie who lives in Staffordshire, where the mugs come from :)
Ha ha Ronnie , you are right , there are still a few flat cap and whippet men about , a dying breed now .
Shiremoor just down the road from me :-).
joggly
Post by joggly »
JonB wrote:No chance, there are too many devices to update.
:D
interesting....what router do you have and how's DHCP set up? MAC filtering turned on?
